请大家帮忙看下下面程序,为什么在我写一个地址(比如0X02地址)的数据为0x05,可是为什么我读前256地址时,读出来的都是0x05????????单片机是8051内核的....
void I2CInit(void)
I2C_SDA_H();
I2C_SCL_H();
void I2C_SCL_H(void)
P2CR=P2CR|Bin(00000010);/*p2_1=SCL OUT=1*/
P2_1=1; //时钟输出高
void I2C_SCL_L(void)
P2CR=P2CR|Bin(00000010);/*p2_1=SCL OUT=0*/
P2_1=0; //时钟输出低
void I2C_SDA_H(void)
P2CR=P2CR|Bin(00000001);/*p2_0=SDA OUT=1*/
P2_0=1; //数据输出高
void I2C_SDA_L(void)
P2CR=P2CR|Bin(00000001);/*p2_0=SDA OUT=0*/
P2_0=0; //数据输出低
bit I2C_SDA_IN(void)
P2CR=P2CR&Bin(11111110);/*p2_0=SDA DIR=IN*/
if(P2_0==1)
return 1;
return 0;
void WriteByte(unsigned int dat,unsigned int address) //随即写
dat=dat&0x00ff;
I2C_Start();
I2C_Send_Byte( 0xa0 ); //Slave Address
if(IICRecAck()==1) return;
I2C_Send_Byte( address>>8);
I2C_Send_Byte( address&0x00ff);
I2C_Send_Byte( dat );
I2C_Stop();
void I2C_Send_Byte(unsigned int dat)
unsigned int i = 8;
while( i-- )
I2C_SCL_L();
if ( dat &0x0080 ) I2C_SDA_H();
else I2C_SDA_L();
Delay_2_uS();
I2C_SCL_H();
Delay_2_uS();
dat = dat << 1;
unsigned int IICRecAck(void)
unsigned int temp;
I2C_SCL_L();
Delay_2_uS();
I2C_SCL_H();
Delay_2_uS();
temp=I2C_SDA_IN();
I2C_SCL_L();
P2CR=P2CR|Bin(00000001);/*p2_0=SDA DIR=OUT*/
return(temp);
unsigned int ReadRandom(unsigned int address) //随即读
unsigned int dat=0;
I2C_Start();
if(IICRecAck()==1) return 0;
I2C_Send_Byte( address>>8 );
I2C_Send_Byte( address&0x00ff );
I2C_Start();
I2C_Send_Byte( 0xa1 );
dat= I2C_Receive_Byte();
I2C_NoAck();
I2C_Stop();
return dat;
unsigned int I2C_Receive_Byte(void)
unsigned int i = 8, dat;
dat=0;
I2C_SCL_L();
Delay_2_uS();
while ( i--)
dat = dat << 1;
Delay_2_uS();
I2C_SCL_H();
Delay_2_uS();
if ( I2C_SDA_IN() ) dat++;
Delay_2_uS();
I2C_SCL_L();
Delay_2_uS();
return dat;
void I2C_Start(void)
I2C_SDA_H();
I2C_SCL_H();
Delay_2_uS();
I2C_SDA_L();
Delay_2_uS();
void I2C_Stop(void)
I2C_SCL_L();
Delay_2_uS();
I2C_SDA_L();
I2C_SCL_H();
Delay_2_uS();
I2C_SDA_H();
//I2C_SCL_L();
Delay_40_uS();
void Delay_2_uS(void)
unsigned int i=160;
while(i--);
void Delay_40_uS(void)
unsigned int i=3200;
while(i--);
void I2C_NoAck(void)
I2C_SDA_H();
I2C_SCL_H();
Delay_2_uS();
I2C_SCL_L();
