c8051f023串口发送数据实验在keil v4下仿真成功,但下载到目标板中串口无输出,大虾看看!
// Generated Initialization File //
#include "C8051F020.h"
#include "string.h"
// Peripheral specific initialization functions,
// Called from the Init_Device() function
sbit PowerOn=P1^4;
void Reset_Sources_Init()
WDTCN = 0xDE;
WDTCN = 0xAD;
void Timer_Init()
CKCON = 0x10;
TCON = 0x40;
TMOD = 0x20;
TH1 = 0xC4;
void UART_Init()
SCON0 = 0x40;
void Port_IO_Init()
P0MDOUT = 0x03;
P1MDOUT = 0x10;
XBR0 = 0x04;
XBR2 = 0x40;
void Oscillator_Init()
int i = 0;
OSCXCN = 0x67;
for (i = 0; i < 3000; i++); // Wait 1ms for initialization
while ((OSCXCN & 0x80) == 0);
OSCICN = 0x0E;
void Interrupts_Init()
//IE = 0x10;
// Initialization function for device,
// Call Init_Device() from your main program
void Init_Device(void)
Reset_Sources_Init();
Timer_Init();
UART_Init();
Port_IO_Init();
Oscillator_Init();
Interrupts_Init();
void delayms(int dlt)
int i,j;
for (i=0; i<=dlt; i++)
for (j=0; j<=3000; j++)
void SendStringToCom0(char *TestStr,int StrLen)
int i;
char ts='1';
char *p;
p=TestStr;
for (i=0; i<=StrLen; i++)
ts= p[0];
SBUF0 = ts ; //送入缓冲区
while(TI0 == 0); //等待发送完毕
TI0 = 0; //软件清零
p++;
void main()
char *TestStr="Uart0 Port Test is running!";
int InfoLen=strlen(TestStr);
Init_Device();
PowerOn=1;
delayms(1000);
while (1)
SendStringToCom0(TestStr,InfoLen);
delayms(3000);
