zhengyang 发表于 2012-6-6 08:20 ![](static/image/common/back.gif)
以下是匯編源碼:
MTG-12864
以下是C源碼:
#include <reg51.h>
#include <ctype.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
/* AM12864系列??程序 1.0 */
/* Designed by Andorin LCM R&D Group */
/* 2003.04.23 */
/* Define the register command code */
#define Disp_On 0x3f
#define Disp_Off 0x3e
#define Col_Add 0x40
#define Page_Add 0xb8
#define Start_Line 0xc0
#define Lcd_Bus P1 //MCU P1<------> LCM
sbit Mcs=P3^3; //Master chip enable
sbit Scs=P3^4; //Slave chip enable
sbit Enable=P3^0; //6800 mode Enable single
sbit Di=P3^5; //Data or Instrument Select
sbit RW=P3^6; //Write or Read
sbit Lcd_Rst=P3^2; //Lcm reset
sbit Test_Key=P3^1;
char code ce[]={
/*-- 文字: ? --*/
/*-- 宋体12; 此字体下??的???:?x高=16x16 --*/
0x08,0x31,0x86,0x60,0x00,0xFE,0x02,0xF2,0x02,0xFE,0x00,0xF8,0x00,0x00,0xFF,0x00,
0x04,0xFC,0x03,0x00,0x80,0x47,0x30,0x0F,0x10,0x67,0x00,0x07,0x40,0x80,0x7F,0x00
char code shi[]={
/*-- 文字: ? --*/
0x40,0x42,0xDC,0x08,0x00,0x90,0x90,0x90,0x90,0x90,0xFF,0x10,0x12,0x1C,0x10,0x00,
0x00,0x00,0x7F,0x20,0x10,0x20,0x20,0x1F,0x10,0x10,0x01,0x06,0x18,0x20,0x78,0x00
char code kai[]={
/*-- 文字: ? --*/
0x40,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x00,
0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x00
char code shi3[]={
/*-- 文字: 始 --*/
0x10,0x90,0x70,0x1F,0x12,0xF0,0x00,0x20,0x70,0x28,0x27,0x22,0x28,0x70,0x20,0x00,
0x40,0x21,0x12,0x0C,0x06,0x09,0x30,0x00,0x7F,0x21,0x21,0x21,0x21,0x7F,0x00,0x00
char code wan[]={
/*-- 文字: 完 --*/
0x00,0x90,0x8C,0xA4,0xA4,0xA4,0xA5,0xA6,0xA4,0xA4,0xA4,0xA4,0x94,0x8C,0x04,0x00,
0x00,0x80,0x40,0x20,0x18,0x07,0x00,0x00,0x00,0x3F,0x40,0x40,0x40,0x70,0x00,0x00
char code bi[]={
/*-- 文字: ? --*/
0x00,0x00,0xFF,0x88,0x48,0x28,0x08,0x80,0x7F,0x88,0x88,0x88,0x84,0x84,0xE0,0x00,
0x04,0x04,0x04,0x04,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00
/* AM12864B系列??首??示?容 */
/* ANDORIN */
/* 安的利光?科技*/
/* AM12864 */
/* ??程序 1.0 */
unsigned char code FirstPage[]={
/*-- ?入了一幅?像:\\Andorin-server\??部\arin\12864.bmp --*/
/*-- ?度x高度=128x64 --*/
0x00,0x00,0x00,0x80,0xF0,0xFE,0x7E,0x0E,0x7E,0xFE,0xF0,0x80,0x00,0x00,0x00,0x00,
0xFE,0xFE,0xFE,0x3C,0xF0,0xE0,0x80,0x00,0x00,0xFE,0xFE,0xFE,0x00,0x00,0x00,0xFE,
0xFE,0xFE,0x0E,0x0E,0x0E,0x0E,0x0E,0x3E,0xFC,0xF8,0xE0,0x00,0x00,0xE0,0xF8,0xFC,
0x3C,0x1E,0x0E,0x0E,0x0E,0x0E,0x1E,0x3C,0xFC,0xF8,0xE0,0x00,0x00,0x00,0xFE,0xFE,
0xFE,0x8E,0x8E,0x8E,0x8E,0x8E,0xFE,0xFC,0xF8,0x00,0x00,0x00,0xFE,0xFE,0xFE,0x00,
0x00,0xFE,0xFE,0xFE,0x3C,0xF0,0xE0,0x80,0x00,0x00,0xFE,0xFE,0xFE,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x80,0xF0,0xFE,0x7F,0x1F,0x1D,0x1C,0x1C,0x1C,0x1D,0x1F,0x7F,0xFE,0xF0,0x80,0x00,
0xFF,0xFF,0xFF,0x00,0x00,0x03,0x0F,0x3E,0x78,0xFF,0xFF,0xFF,0x00,0x00,0x00,0xFF,
0xFF,0xFF,0xE0,0xE0,0xE0,0xE0,0xE0,0x70,0x7F,0x3F,0x0F,0x00,0x00,0x0F,0x3F,0x7F,
0x78,0xF0,0xE0,0xE0,0xE0,0xE0,0xF0,0x78,0x7F,0x3F,0x0F,0x00,0x00,0x00,0xFF,0xFF,
0xFF,0x03,0x03,0x03,0x0F,0x1F,0x7D,0xF9,0xE0,0x80,0x00,0x00,0xFF,0xFF,0xFF,0x00,
0x00,0xFF,0xFF,0xFF,0x00,0x00,0x03,0x0F,0x3E,0x78,0xFF,0xFF,0xFF,0x00,0x00,0x00,
0x00,0x00,0x00,0x40,0x30,0x10,0x10,0x10,0xD0,0x12,0x1C,0x10,0x10,0x10,0x10,0x50,
0x30,0x00,0x00,0x00,0x00,0xF0,0x10,0x18,0x16,0x10,0xF0,0x80,0x40,0x30,0x1E,0x10,
0x10,0x10,0xF8,0x10,0x00,0x00,0x40,0x48,0x48,0x48,0xC8,0xF8,0x44,0x46,0x44,0x40,
0x00,0xF8,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x10,0x60,0x00,0x00,
0xFE,0x00,0x80,0x60,0x18,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0xF0,0x10,0x10,0x10,
0x10,0xFE,0x10,0x10,0x10,0x10,0x10,0xF8,0x10,0x00,0x00,0x00,0x48,0x48,0x48,0x44,
0xFC,0x42,0x42,0x40,0x80,0x08,0x30,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x20,0x20,
0x20,0xFE,0x20,0x20,0x00,0x20,0x20,0x20,0xFE,0x20,0x20,0x20,0x30,0x20,0x00,0x00,
0x00,0x00,0x01,0x01,0x01,0x01,0x09,0x8F,0x91,0x51,0x21,0x21,0x59,0x47,0x81,0x81,
0x81,0x01,0x00,0x00,0x00,0xFF,0x42,0x42,0x42,0x42,0xFF,0x00,0x00,0x01,0x0E,0x80,
0x00,0x80,0x7F,0x00,0x00,0x00,0x20,0x10,0x08,0x06,0x01,0xFF,0x01,0x02,0x0C,0x00,
0x00,0x1F,0x80,0x00,0xFF,0x00,0x00,0x00,0x01,0x01,0x01,0x81,0x41,0x3F,0x01,0x01,
0x01,0xFF,0x01,0x01,0x01,0x01,0x01,0xF1,0x00,0x00,0x00,0x00,0x1F,0x09,0x09,0x09,
0x09,0xFF,0x09,0x09,0x09,0x09,0x09,0x1F,0xC0,0x00,0x00,0x00,0x10,0x08,0x04,0x03,
0xFF,0x01,0x06,0x10,0x10,0x13,0x08,0x08,0x08,0xFF,0x04,0x04,0x00,0x00,0x04,0x84,
0x02,0xFF,0x01,0x01,0x00,0x81,0x87,0x59,0x21,0x51,0x4D,0x83,0x81,0x80,0x00,0x00,
0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x01,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x80,0xF1,0x7C,0x0C,0x7C,0xF0,0x80,
0x01,0x00,0x00,0xFC,0xFC,0x3C,0xF8,0xC0,0x00,0x00,0x00,0xC1,0xF8,0x3C,0xFC,0xFC,
0x00,0x00,0x00,0x61,0x30,0x18,0xFC,0xFC,0x01,0x01,0x01,0x00,0x30,0x38,0x1C,0x0C,
0x0C,0x1C,0xF9,0xF1,0x01,0x01,0x71,0xF9,0x8C,0x8C,0x8C,0x8C,0xF8,0x70,0x00,0x00,
0xE0,0xF8,0x1D,0x8D,0x8D,0x8D,0x19,0x11,0x01,0x00,0x00,0xC0,0xE0,0x38,0xFC,0xFC,
0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x01,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x7C,0x1F,0x07,0x06,0x06,0x06,0x07,0x1F,
0x7C,0x60,0x00,0x7F,0x7F,0x00,0x01,0x1F,0x7C,0x60,0x7C,0x1F,0x01,0x00,0x7F,0x7F,
0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x7F,0x00,0x00,0x00,0x00,0x60,0x70,0x78,0x6C,
0x66,0x63,0x61,0x60,0x00,0x00,0x1E,0x3F,0x61,0x61,0x61,0x61,0x3F,0x1E,0x00,0x00,
0x0F,0x3F,0x73,0x61,0x61,0x61,0x3F,0x1E,0x00,0x0E,0x0F,0x0D,0x0C,0x0C,0x7F,0x7F,
0x0C,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x61,0x06,0xC0,
0x00,0xFE,0x02,0xF2,0x02,0xFE,0x00,0x00,0xF8,0x00,0xFF,0x00,0x00,0x00,0x80,0x82,
0x84,0x8C,0x00,0x10,0x90,0x90,0x90,0x90,0x90,0xFF,0x10,0x12,0x14,0x10,0x00,0x00,
0x24,0x24,0xA4,0xFE,0xA2,0x23,0x22,0x80,0xBE,0xA2,0xA2,0xA2,0xA2,0xA2,0xBF,0x82,
0x00,0x00,0x00,0x00,0xFC,0x04,0x14,0x14,0x14,0x15,0x56,0x94,0x54,0x34,0x14,0x14,
0x06,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x30,0x18,0xFC,0xFC,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xF8,0x1C,0x0C,0x0C,0x1C,0xF8,0xF0,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x7E,0x81,
0x40,0x27,0x10,0x0F,0x10,0x67,0x00,0x00,0x4F,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,
0x00,0x7F,0x20,0x10,0x20,0x60,0x3F,0x10,0x10,0x03,0x1C,0x20,0x40,0xF0,0x00,0x00,
0x10,0x0E,0x01,0xFF,0x00,0x03,0x80,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0xC8,
0x80,0x00,0x80,0x60,0x1F,0x00,0x01,0x01,0x01,0x41,0x81,0x7F,0x01,0x01,0x01,0x05,
0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x7F,0x00,
0x00,0x00,0x00,0x00,0x60,0x60,0x00,0x00,0x1F,0x3F,0x70,0x60,0x60,0x70,0x3F,0x1F,
/*------------------延?子程序-----------------------------*/
void delay(unsigned int t)
unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<10;j++)
/*------------------?命令到LCD------------------------------*/
void write_com(unsigned char cmdcode)
Di=0;
RW=0;
Lcd_Bus=cmdcode;
delay(0);
Enable=1;
delay(0);
Enable=0;
/*-------------------??据到LCD----------------------------*/
void write_data(unsigned char Dispdata)
Di=1;
RW=0;
Lcd_Bus=Dispdata;
delay(0);
Enable=1;
delay(0);
Enable=0;
/*-------------------?LCD?据----------------------------*/
unsigned char read_data()
unsigned char tmpin;
Di=1;
RW=1;
delay(0);
Enable=1;
delay(0);
Enable=0;
tmpin=Lcd_Bus;
return tmpin;
/*------------------?示?框-------------------------------*/
void frame()
unsigned char i;
Mcs=1;
Scs=1;
write_com(Page_Add+0);
write_com(Col_Add+0);
for(i=0;i<64;i++) write_data(0x01);
write_com(Page_Add+7);
for(i=0;i<64;i++) write_data(0x80);
for(i=0;i<8;i++)
Mcs=0;
Scs=1;
write_com(Page_Add+i);
write_com(Col_Add+63);
write_data(0xff);
Mcs=1;
Scs=0;
write_data(0xff);
/*------------------清除?存---------------*/
void Clr_Scr()
unsigned char j,k;
Mcs=1;Scs=1;
for(k=0;k<8;k++){
write_com(Page_Add+k);
for(j=0;j<64;j++)write_data(0x00);
/*------------------?示12864?片---------------------------*/
void Disp_Img(unsigned char code *img)
unsigned char j,k;
for(k=0;k<8;k++){
Mcs=1;Scs=0;delay(10);
for(j=0;j<64;j++) write_data(img[k*128+j]);
Mcs=0;Scs=1; delay(10);
for(j=64;j<128;j++) write_data(img[k*128+j]);
/*------------------?示?---------------------------*/
void Disp_H_Line()
unsigned char i,j;
Mcs=1;
Scs=1;
write_com(Disp_On);
write_com(Page_Add);
write_com(Start_Line);
write_com(Col_Add);
for(j=0;j<8;j++)
write_com(Page_Add+j);
// write_com(Start_Line+0);
for(i=0;i<64;i++)write_data(0x55);
/*------------------?示列-----------------------------*/
void Disp_V_Line()
unsigned char i,j;
write_com(Disp_On);
write_com(Col_Add);
for(j=0;j<8;j++)
for(i=0;i<32;i++)
write_data(0x00);
write_data(0xff);
/*------------------棋?-----------------------------*/
void Disp_Cross_Line(unsigned char mode)
unsigned char i,j;
unsigned char data1,data2;
if(mode==0) {data1=0xaa;data2=0x55;}
else if(mode==1) {data1=0x55;data2=0xaa;}
else return;
Mcs=1;Scs=1;
write_com(Disp_On);
write_com(Col_Add);
for(j=0;j<8;j++)
for(i=0;i<32;i++){
write_data(data1);
write_data(data2);
/*---------------------指定位置?示?字16*16-----------------------*/
void hz_disp16(unsigned char pag,unsigned char col, unsigned char code *hzk)
unsigned char j=0,i=0;
for(j=0;j<2;j++){
write_com(Page_Add+pag+j);
write_com(Col_Add+col);
for(i=0;i<16;i++) write_data(hzk[16*j+i]);
/*------------------初始化LCD屏--------------------------*/
void init_lcd()
Lcd_Rst=0;
delay(100);
Lcd_Rst=1;
delay(100);
Mcs=1;
Scs=1;
delay(100);
write_com(Disp_Off);
write_com(Disp_On);
/*------------------------------信息?示------------------------*/
void Msg(int flg)
Clr_Scr();
frame();
if(flg==0){ //?示“???始”
Mcs=1;Scs=0;
hz_disp16(3,32,ce);
delay(2000);
hz_disp16(3,48,shi);
delay(2000);
Mcs=0;Scs=1;
hz_disp16(3,0,kai);
delay(2000);
hz_disp16(3,16,shi3);
delay(2000);
else if(flg==1){ //?示“??完?”
Mcs=1;Scs=0;
hz_disp16(3,32,ce);
Mcs=0;Scs=1;
hz_disp16(3,0,wan);
hz_disp16(3,16,bi);
/*--------------------------------???描-------------------------*/
void Key_Scan()
while(Test_Key);
while(~Test_Key);
/*--------------------主程序---------------------------------*/
main()
unsigned char i=0;
while(1){
// Key_Scan();
init_lcd();
Disp_Img(FirstPage);
delay(10000);
// Key_Scan();
Msg(0);
delay(10000);
Disp_H_Line();
delay(10000);
Disp_V_Line();
delay(10000);
Msg(1);
delay(10000);
