发表于 2012-6-5 11:21:11
- * INCLUDE HEADER FILES
- //#pragma src
- #include "cpu.h"
- #include <math.h>
- #include "adc0.h"
- * ntc对应采样电压值数组
- * 注释第一行:对应温度
- * 测量温度范围定为-10℃-150℃(可能会有零点几的数据出入)
- static int16u code ntc_adc[] =
- 4018, 3990, 3961, 3932, 3901, 3869, 3836, 3802,
- 3767, 3731, 3694, 3656, 3617, 3577, 3536, 3494,
- 3451, 3407, 3363, 3318, 3271, 3225, 3177, 3129,
- 3080, 3031, 2981, 2931, 2881, 2830, 2779, 2728,
- 2676, 2625, 2573, 2522, 2470, 2419, 2368, 2317,
- 2267, 2216, 2167, 2117, 2068, 2020, 1972, 1925,
- 1878, 1832, 1787, 1742, 1698, 1655, 1612, 1571,
- 1530, 1490, 1450, 1412, 1374, 1337, 1301, 1265,
- 1231, 1197, 1164, 1132, 1101, 1070, 1040, 1011,
- 983, 956, 929, 903, 877, 853, 829, 805,
- 783, 761, 739, 718, 698, 678, 659, 641,
- 623, 605, 588, 572, 556, 541, 526, 511,
- 497, 483, 470, 457, 444, 432, 420, 409,
- 398, 387, 377, 367, 357, 347, 338, 329,
- 320, 312, 304, 296, 288, 280, 273, 266,
- 259, 253, 246, 240, 234, 228, 222, 217,
- 211, 206, 201, 196, 191, 186, 182, 177,
- 173, 169, 165, 161, 157, 153, 150, 146,
- 143, 139, 136, 133, 130, 127, 124, 121,
- 119, 116, 113, 111, 108, 106, 103, 101,
- 99, 97, 95, 93, 91, 89, 87, 85,
- 83, 81, 80,
- #define NTC_ADC_ARRAY_NUM (sizeof(ntc_adc)/sizeof(int16u))
- #define INDEX_MAX (NTC_ADC_ARRAY_NUM-3) /* 数组下标的最大可用取值,对应 80℃采样值下标 */
- #define INDEX_MIN 3 /* 数组下标的最小可用取值,对应-10℃采样值下标 */
- #define TEMPER_REF -15 /* 温度基准点,即下标为0时对应的温度 */
- #define TEMPER_LAST 155 /* 温度最后值,即数组最后一个对应的温度 */
- * 函数名称: search_data()
- * 输 入: search_value 查找基准值
- * 输 出:
- * 作 者:
- * 日 期: 2010.08.11
- * 功能描述: 二分查找adc采样值
- *注 意:
- * 1. 返回值为查找表格中第一个小于查找值(search_value)的下标;
- * 2. 查找值(search_value)大于查找表格中最大值时,返回1
- * 查找值(search_value)小于查找表格中最小值时,返回查找表格数量,即最大下标+1
- static int16u search_data(int16u search_value)
- int16u max = NTC_ADC_ARRAY_NUM - 1;
- int16u min = 1;
- int16u mid;
- while(min <= max)
- mid = (max + min) / 2;
- if(search_value > ntc_adc[mid])
- max = mid - 1;
- else
- min = mid + 1;
- return min;
- * 函数名称: temper_calc()
- * 输 入: index 数组下标
- * adc0_value ad滤波后的采样值
- * 输 出: ntc温度测量值
- * 作 者:
- * 日 期: 2010.10.26
- * 功能描述: 温度计算(分段线性插值算法)
- static int16s temper_calc(int16u index, int16u adc0_value)
- if (index > INDEX_MAX || index < INDEX_MIN)
- return TEMPER_ERROR; // 返回错误采样温度
- // else if (index < INDEX_MIN)
- // return -150; // 返回-15.0℃
- else
- === 直线近似计算 ===
- y1 = kx1+b x <-> adc_value
- y2 = kx2+b y <-> temper
- yn = kxn+b
- y2 - y1 yn - y1
- k = --------- = ---------
- x2 - x1 xn - x1
- (y2 - y1)*(xn - x1)
- yn = --------------------- + y1
- (x2 - x1)
- int16s temper;
- temper = 10*(ntc_adc[index-1] - adc0_value); // 放大10倍,temper放大10倍
- temper /= (ntc_adc[index-1] - ntc_adc[index]); // (xn - x1)
- temper += 10*(index + TEMPER_REF - 1);
- return temper;
- * 函数名称: adc0_temper_calc()
- * 输 入: adc0_sample_index 温度采样序列值
- * adc0_sample_num ad采样次数
- * 输 出:
- * 作 者:
- * 日 期:
- * 功能描述:
- void adc0_temper_calc(int8u adc0_sample_index, int8u adc0_sample_num)
- static int8u cnt[ST_MAX]; // 采样滤波计数
- if (adc0_sample_index < ST_MAX) // 温度采样索引值在预定义范围内
- int16u adc0_filter; // 滤波处理的ad采样值
- int16s temper; // 温度值
- int16u index; // 查表下标值
- // 算术平均滤波(采样值求和后平均)处理
- adc0_filter = arithmetic_average_filter(&adc0_sample_value[0], adc0_sample_num);
- index = search_data(adc0_filter); // 取温度数组下标
- temper = temper_calc(index, adc0_filter); // 温度计算
- if (abs(battery_info.battery_temper[adc0_sample_index] - temper) > 5) // 两次温度采样相差0.5℃以上
- cnt[adc0_sample_index] += 1;
- if (cnt[adc0_sample_index] > 1)
- cnt[adc0_sample_index] = 0;
- battery_info.battery_temper[adc0_sample_index] = temper; // 赋值NTC温度
- else
复制代码 |
