![](http://blog.dianyuan.com/upload/t/space/2012/05/31/1338466783-668791-big.jpg)
仿真没什么问题,就是上实物出现这样的问题。。。
#include <reg52.h>
#include <intrins.h>
#define uint unsigned int
#define ulong unsigned long
sbit key1=P3^2;
sbit key2=P3^3;
unsigned char rate=50;
volatile uchar n=0;
unsigned char ucHigh = 0;
unsigned char ucLow = 0;
uchar code tosin[256]={
0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,
0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,
0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,
0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,0xf5,
0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,
0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,
0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,
0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,
0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,
0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,0x80,0x7c,0x79,0x76,
0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,
0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,
0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,
0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,
0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,
0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,
0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,
0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e,
0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,
0x76,0x79,0x7c,0x80 };/*正弦波码 */
#if 1
void Delay(uint t)
uint j;
for(;t>0;t--)
for(j=100;j>0;j--);
函数:KeyScan()
功能:键盘扫描
返回:扫描码
#if 1
unsigned char KeyScan(void)
unsigned char k = '\0';
if ( !key1 ) k = '1';
if ( !key2 ) k = '2';
return k;
void main()
TMOD=0x10;
rate = 1;
ET1=1;
TR1=1;
EA=1;
ucHigh = (-3922/rate)/256;
ucLow = (-3922/rate)%256;
unsigned char k;
for (;;)
Delay(1);
k = KeyScan();
if ( k != '\0' )
switch(k)
case '1':
if (rate <= 50)
rate += 1;
case '2':
if (rate > 6)
rate -= 1;
for (;;) //松手检测
Delay(1);
if ( KeyScan() == '\0' ) break;
void t1(void) interrupt 3 using 2 //T1工作在定时状态下,
TR1=0;
TH1=ucHigh;
TL1=ucLow;
P0 = tosin[n++]; //0.2V˙秈
TR1=1;
实现功能就是 按键调频。。。 |
