比如4位共阳数码管,我希望它显示0123,结果只显示012,段码接P0口,位码接P2.0到P2.3.
程序如下:- #include <at89x52.h>
- #define uchar unsigned char
- uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- uchar i=0;
- sbit h4=P2^3; //共阳,低电平有效
- sbit h3=P2^2;
- sbit h2=P2^1;
- sbit h1=P2^0;
- void timer0()interrupt 1
- TH0=(65536-10000)/256;
- TL0=(65536-10000)%256;
- switch(i)
- case 0:
- h1=1;h2=0;h3=0;h4=0;P0=tab[0];
- };break;
- case 1:
- h1=0;h2=1;h3=0;h4=0;P0=tab[1];
- };break;
- case 2:
- h1=0;h2=0;h3=1;h4=0;P0=tab[2];
- };break;
- case 3:
- h1=0;h2=0;h3=0;h4=1;P0=tab[3];
- };break;
- i++;
- if(i==4)
- i=0;
- main()
- TMOD=0X01;
- EA=1;
- ET0=1;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- TR0=1;
- while(1);
复制代码 结果如下:
