用的是c8051f040单片机! 和spi 总线的dataflash
读不到id和寄存器状态!全部都是FF! 谢谢大家帮忙,等调试通过了奉献出来!~
下面是硬件接口!
P11->SO
P12->SI
P13->SCK
P14->CS
P15->WP
P16->RST
P17->RDY/BUSY
初始化io程序
void InitPortIO( )
SFRPAGE = 0x0F;
// P0MDOUT = 0x01; // Output configuration for P0
P1MDOUT = 0xff; // Output configuration for P1
// P2MDOUT = 0x15; // Output configuration for P2
// P3MDOUT = 0x00; // Output configuration for P3,P3.6 and P3.7 used for RTC communication
// P4MDOUT = 0x15; // Output configuration for P4
// P5MDOUT = 0xAA; // Output configuration for P5
P6MDOUT = 0x0f; // Output configuration for P6
// P7MDOUT = 0x2A; // Output configuration for P7
P1MDIN |= 0x82; // Input configuration for P1
// P2MDIN = 0xFF; // Input configuration for P2
// P3MDIN = 0xff; // Input configuration for P3
P0 = 0xff;
P1 = 0xff;
P2 = 0xff;
P3 = 0xff;
P4 = 0xff;
P5 = 0xff;
P6 = 0x00;
P7 = 0xff;
SFRPAGE = 0x0F;
// XBR0 = 0x34; // XBAR0: Initial Reset Value
// XBR0 = 0x0e;
XBR1 = 0x00; // XBAR1: Initial Reset Value
// XBR2 = 0x42; // XBAR2: Initial Reset Value
// XBR3 = 0x80; // XBAR3: Configure CAN TX pin (CTX) as push-pull digital output
SFRPAGE = 0x0F;
P1MDOUT = 0x7d; // Output configuration for P1
P2MDOUT = 0x00; // Output configuration for P2
P4MDOUT = 0x00; // Output configuration for P4
P5MDOUT = 0xA8; // Output configuration for P5
P6MDOUT |= 0x0F; // Output configuration for P6
SFRPAGE = 0x00;
EMI0CF = 0x03; // External Memory Configuration Register
下面是初始化内部振荡器
void InitOSC( )
xdata unsigned int n = 0;
EA = 0;
SFRPAGE = CONFIG_PAGE;
// 0x0f
// OSCXCN = 0x67; // EXTERNAL Oscillator Control Register
// Use external Crystal Oscillator
// Use OSC as system clock
// 11.092MHz
for (n = 0; n < 2550; n++);
// wait for osc to start
// while ( (OSCXCN & 0x80) == 0 ); // wait for xtal to stabilize
OSCICN=0x82;
CLKSEL = 0x00; // 内部晶振
// CLKSEL = 0x01; // select external crystal as sysclk
// sysclk = 18.432MHz
n = CLKSEL;
// OSCICN = 0x80; // Internal Oscillator Control Register
// internal clk freqent = 24.5MHz/8 = 3.1MHz;
// EA = 1;
下面是驱动SPI的几个开始的函数
* 函数原型:unsigned char SPI_MCUReadByte(void);
* 名 称:SPI_MCUReadByte
* 功 能:从AT45DB161B通过AT_SO口读入1BYTE数据
* 入口参数:无
* 出口参数:返回读入的1BYTE数据
unsigned char SPI_MCUReadByte(void) //读
unsigned char n;
unsigned int rByte=0;
// unsigned char SFRPAGE_SAVE = SFRPAGE;
// SFRPAGE = CONFIG_PAGE;
AT_CS=0;
for(n=0;n<8;n++)
{ AT_SCK=0;
delayus(5);
AT_SCK=1;
delayus(5);
rByte<<=1;
rByte|=AT_SO;
//SFRPAGE = SFRPAGE_SAVE;
AT_CS=1;
return rByte;
* 函数原型:void SPI_MCUWriteByte(unsigned char wByte);
* 名 称:SPI_MCUWriteByte
* 功 能:将1字节数据wByte由AT_SI口写入AT45DB161B
* 入口参数:要写入的1BYTE数据
* 出口参数:无
void SPI_MCUWriteByte(unsigned char rByte) //写
unsigned char m;
//SFRPAGE = CONFIG_PAGE;
AT_CS=0;
AT_SCK=0;
for(m=0;m<8;m++)
{ if(rByte&0x80)
AT_SI=1;
else{AT_SI=0;}
AT_SCK=0;
delayus(5);
AT_SCK=1;
delayus(5);
rByte<<=1;
AT_CS=1;
// SFRPAGE = SFRPAGE_SAVE;
unsigned char SPI_FLASH_ReadID() //读取id
unsigned char ID;
AT_CS = 0; //片选打开
delayus(5);
SPI_MCUWriteByte(0X9F); //9FH是读取状态的命令字
ID = SPI_MCUReadByte(); //读取状态字节
AT_CS = 1; //片选关闭
delayms(5);
return ID;
* 函数原型:unsigned char DF_status(void);
* 名 称:DF_status
* 功 能:由AT_SI口读AT45DB161B的状态字
* 入口参数:无
* 出口参数:返回状态字
/*Status Register Format: */
/* | bit7 | bit6 | bit5 | bit4 | bit3 | bit2 | bit1 | bit0 | */
/* |RDY/BUSY| COMP | 0 | 1 | 1 | 1 | X | X | */
/* bit7 - 忙标记,0为忙1为不忙。 */
/* 当DF_status的位0移出之后,接下来的时钟脉冲序列将使SPI器件继续*/
/* 将最新的状态字节送出。 */
/* bit6 - 标记最近一次Main Memory Page和Buffer的比较结果,0相同,1不同。 */
/* bit5 */
/* bit4 */
/* bit3 */
/* bit2 - 这4位用来标记器件密度,对于AT45DB161B,这4位应该是0111,一共能标记 */
/* 16种不同密度的器件。 */
/* bit1 */
/* bit0 - 这2位暂时无效 */
unsigned char DF_status() //读取状态字
unsigned char status;
AT_CS = 0; //片选打开
delayus(5);
SPI_MCUWriteByte(READ_STATE_REGISTER); //D7H是读取状态的命令字
status = SPI_MCUReadByte(); //读取状态字节
AT_CS = 1; //片选关闭
delayms(5);
return status;
