Supports ARM7/ARM9/ARM11 and Cortex-M/R/A cores
Seamless integration into the IAR Embedded Workbench IDE
Fully plug-and-play compatible
Hi-speed USB 2.0 interface (480Mbps)
No power supply required, powered entirely by the USB port
Target power of up to 400mA can be supplied from I-jet with overload protection
Target power consumption can be measured with ~200µA resolution at 200kHz
JTAG and Serial Wire Debug (SWD) clocks up to 32MHz (no limit on the MCU clock speed)
Serial Wire Viewer (SWV) with UART and Manchester encoding
Support for SWO speeds of up to 60MHz
Embedded Trace Buffer (ETB) support
Download speed of up to 1MByte/sec
Automatic core recognition
Support for multiple JTAG devices with automatic chain detection and graphical display
Direct download into flash memory of most popular microcontrollers
Support for JTAG adaptive clocking (RTCK)
Automatic JTAG/SWD detection
JTAG voltage measurement and monitoring
Supports target voltage range from 1.65V to 5V
Standard MIPI-20 and MIPI-10 JTAG cables are included
ARM-20 (0.1in x 0.1in) JTAG adapter is included
