发表于 2012-6-3 14:34:04
NRF2401的驱动文件:
//无线通信模块nrf2401
//版本: 在版本v0中固定发送4个字节数据,这个版本改成了9个数据;
// 可以设置超时时间;
//芯片: AVR芯片
nrf2401 组件
CONFIG(N8) = ACI const 0x00, //'Config'
EN_AA(N8) = ACI const 0x01, //'Enable Auto Acknowledgment'
EN_RXADDR(N8) = ACI const 0x02, //'Enabled RX addresses'
SETUP_AW(N8) = ACI const 0x03, //'Setup address width'
SETUP_RETR(N8) = ACI const 0x04, //'Setup Auto. Retrans'
RF_CH(N8) = ACI const 0x05, //'RF channel'
RF_SETUP(N8) = ACI const 0x06, //'RF setup'
STATUS(N8) = ACI const 0x07, //'Status'
OBSERVE_TX(N8) = ACI const 0x08, //'Observe TX'
CD(N8) = ACI const 0x09, //'Carrier Detect'
RX_ADDR_P0(N8) = ACI const 0x0A, //频道0接收数据地址
RX_ADDR_P1(N8) = ACI const 0x0B, //'RX address pipe1'
RX_ADDR_P2(N8) = ACI const 0x0C, //'RX address pipe2'
RX_ADDR_P3(N8) = ACI const 0x0D, //'RX address pipe3'
RX_ADDR_P4(N8) = ACI const 0x0E, //'RX address pipe4'
RX_ADDR_P5(N8) = ACI const 0x0F, //'RX address pipe5'
TX_ADDR(N8) = ACI const 0x10, //'TX address'
RX_PW_P0(N8) = ACI const 0x11, //接收频道0接收数据长度
RX_PW_P1(N8) = ACI const 0x12, //'RX payload width, pipe1'
RX_PW_P2(N8) = ACI const 0x13, //'RX payload width, pipe2'
RX_PW_P3(N8) = ACI const 0x14, //'RX payload width, pipe3'
RX_PW_P4(N8) = ACI const 0x15, //'RX payload width, pipe4'
RX_PW_P5(N8) = ACI const 0x16, //'RX payload width, pipe5'
FIFO_STATUS(N8) = ACI const 0x17, //'FIFO Status Register'
//SPI(nRF24L01) commands
READ_REG(N8) = ACI const 0x00, //Define read command to register
WRITE_REG(N8) = ACI const 0x20, //Define write command to register
RD_RX_PLOAD(N8) = ACI const 0x61, //Define RX payload register address
WR_TX_PLOAD(N8) = ACI const 0xA0, //Define TX payload register address
FLUSH_TX(N8) = ACI const 0xE1, //Define flush TX register command
FLUSH_RX(N8) = ACI const 0xE2, //Define flush RX register command
REUSE_TX_PL(N8) = ACI const 0xE3, //Define reuse TX payload register command
NOP(N8) = ACI const 0xFF, //Define No Operation, might be used to read status register
公开 本机地址([N8*5]), //本机地址
time_out(N16),
引擎(公开)
初始化
CE_ddr = 1,
CE_port = 0,
CSN_ddr = 1,
CSN_port = 1,
IRQ_ddr = 0,
//spi接口初始化
spi init[],
set[ CONFIG, 0b0000_1111 ], //CRC使能,16位CRC校验,上电,接收模式
set[ EN_AA, 0x01 ], //使能接收通道0自动应答
set[ EN_RXADDR, 0x01 ], //使能接收通道0
set[ SETUP_AW, 0x03 ], //设置地址宽度 5个字节
set[ SETUP_RETR, 0xff ], //自动重发延时等待4000us+86us,自动重发15次
set[ RF_CH, 40 ], //选择射频通道40
set[ RF_SETUP, 0x07 ], //数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
status(N8) = get[ STATUS ], //返回状态寄存器
write_command[ FLUSH_TX ],
write_command[ FLUSH_RX ],
set[ STATUS, status | 0b0111_0000 ],//清除TX_DS或MAX_RT中断标志
//设置超时时间
time_out = 0xffff,
引擎(公开)
工作正常(T)
set[ RF_CH, 0x03 ],
如果 get[ RF_CH ] != 0x03,
返回 false.
set[ RF_CH, 0x40 ],
如果 get[ RF_CH ] != 0x40,
返回 false.
返回 true,
引擎(公开)
转换到正常模式
c(N8) = get[ CONFIG ],
c | 0b0000_0010,
set[ CONFIG, c ],
引擎(公开)
转换到掉电模式
c & 0b1111_1101,
set[ CONFIG, c ],
引擎(公开)
time(N16),
设置超时时间
time_out = time,
引擎(公开)
设置为接收模式
CE_port = 0,
//写入接收通道地址
write_buffer[ WRITE_REG + RX_ADDR_P0, 本机地址, 5 ],
c | 0b0000_0001,
set[ CONFIG, c ],
CE_port = 1,
引擎(公开)
设置为发射模式
CE_port = 0,
c & 0b1111_1110,
set[ CONFIG, c ],
CE_port = 1,
引擎(公开)
buffer([N8*?]), length(N8), TX_address([N8*?]),
发射数据
//接收通道0选择和发送通道相同有效数据宽度
set[ RX_PW_P0, length ],
CE_port = 0,
//写数据包到TX FIFO
write_buffer[ WR_TX_PLOAD, buffer, length ],
//写入发送地址
write_buffer[ WRITE_REG + TX_ADDR, TX_address, 5 ],
//为了应答接收设备,接收通道0地址和发送地址相同
write_buffer[ WRITE_REG + RX_ADDR_P0, TX_address, 5 ],
CE_port = 1,
//等待应答
反复执行 直到 IRQ_pin == 0, ...
set[ STATUS, status ], //清除TX_DS或MAX_RT中断标志
引擎(公开)
buffer([N8*?]), length(N8), is_time_out(T),
接收到数据(T)
times(N16) = 0,
如果 is_time_out,
times + 1,
如果 times == time_out,
返回 false.
sta(N8) = get[ STATUS ],
set[ STATUS, sta ],
read_buffer[ RD_RX_PLOAD, buffer, length ],
返回 true,
//把p_buf缓存中的数据写入到nRF24L01,通常用来写入发射通道数据或接收/发送地址
引擎()
reg(N8), p_buf([N8*?]), length(N8),
write_buffer
CSN_port = 0,
spi write_byte[ reg ],
反复执行 初始 i(N8) = 0, 每次 i + 1, 直到 i == length,
spi write_byte[ p_buf i ],
CSN_port = 1,
//写一个命令
引擎()
cmd(N8),
write_command
CSN_port = 0,
spi write_byte[ cmd ],
CSN_port = 1,
//读取nRF2401某个缓冲区内容
引擎()
read_buffer
CSN_port = 0,
p_buf i = spi read_byte[],
CSN_port = 1,
//写寄存器
引擎()
addr(N8), data(N8),
set
CSN_port = 0,
spi write_byte[ WRITE_REG + addr ],
spi write_byte[ data ],
CSN_port = 1,
//读寄存器
引擎()
addr(N8),
get(N8)
CSN_port = 0,
spi write_byte[ READ_REG + addr ],
data(N8) = spi read_byte[],
CSN_port = 1,
返回 data,
公开 link CE_port(N1),
公开 link CE_ddr(N1),
公开 link IRQ_pin(N1),
公开 link IRQ_ddr(N1),
公开 link CSN_port(N1),
公开 link CSN_ddr(N1),
//SPI串行接口元件,高位在前,低位在后
公开 spi 组件
//初始化
引擎(公开)
init
SCK_ddr = 1,
SCK_port = 0,
MOSI_ddr = 1,
MOSI_port = 0,
MISO_ddr = 0,
//写一个字节
引擎(公开)
data(N8),
write_byte
反复执行 8 次,
MOSI_port = data 7(N1),
#asm "nop"
SCK_port = 1,
#asm "nop"
SCK_port = 0,
data << 1,
//读一个字节
引擎(公开)
read_byte(N8)
MOSI_port = 0,
data(N8),
反复执行 8 次,
data << 1,
SCK_port = 1,
#asm "nop"
data 0(N1) = MISO_pin,
#asm "nop"
SCK_port = 0,
返回 data,
公开 link SCK_port(N1), //时钟线
公开 link SCK_ddr(N1), //时钟线
公开 link MISO_pin(N1), //读数据端口
公开 link MISO_ddr(N1), //读数据端口
公开 link MOSI_port(N1), //写数据端口
公开 link MOSI_ddr(N1), //写数据端口
