http://www.youtube.com/watch?v=UflfER-q66E
http://micro.arocholl.com/index. ... ticle&Itemid=64
$129.00
Feature
Pocket size and light weight
Solid aluminum metal case
Spectrum Analyzer mode with Peak Max and Hold, Normal, Overwrite and Averaging modes
Integrated RF Signal Generator
Lifetime free firmware upgrades available, open to community requested features
High capacity Lipo for 16hs+ of continuous run, rechargeable by USB
Windows PC client Open Source
Can be extended with internal Expansion Modules for additional band and functionality
Specification
Frequency band:430-440 MHz
Frequency span: 112 KHz-10 MHz(enhanced to 30 MHz if an Expansion Module is connected)
Graphics LCD 128x64 pixels, great visibility outdoors
PC Windows client supports Windows XP/Vista/Win7 both 32 and 64bits
Backlight for great indoor visibility
Standard SMA 50 ohms connector, a matching antenna is included
Amplitude resolution: 0.5dBm
Dynamic range: -115dBm to 0dBm
Absolute Max input power: +5dBm
Average noise level (typical): -110dBm
RF Generator amplitude: 0dBm to 20dBm
Frequency stability and accuracy (typical): +-10ppm
Amplitude stability and accuracy (typical): +-3dBm
Frequency resolution: 1Khz
Resolution bandwidth (RBW): automatic 2.6Khz to 80Khz
Weight: 185g
RF Explorer handling care suggested link
RF Explorer currently supported workflows
Monitor continuous wave (CW) and temporary transmissions in specific ISM band.
Detect whether a device is transmitting in the expected frequency and with expected power
Check whether an antenna or amplifier change makes a difference in power, orientation and noise
Detect band occupancy to move your gadget to a different channel
Works as RF Generator to transmit pure RF tone so you can test your RF link in seconds
Works completely automatic so you do not need to be an expert to use it. It will resolve RBW, Sweep time, for you.
Offer spectrum data in Normal, Average, Peak Maximum calculator modes
Open source PC client software for Windows and Mac OSX, unlimited capture and post-processing storage
Optimized for all worldwide Sub-1Ghz ISM bands: Any frequency between 240 and 960Mhz, including 433Mhz, 868Mhz or 915Mhz.
Optimized for 2.4Ghz (Bluetooth, ZigBee, WiFi) with specific WiFi Analyzer functionality. Check out this model map for more info.
RF Explorer future extensions
Transmission test tones in OOK and FSK
Digital transmission decoding and packet sniffing for OOK and FSK, including Manchester code support
Logging features for multi-hour transmission monitoring
Frequency counter
Automatic peak detection
Storage for up to 5 screenshots in internal memory or 1000』s screenshots in expanded memory.
Expansion modules for additional ISM band support, expanded RF Generator and Tracking Generator for circuit analysis, etc.
For an example of how easy and powerful RF Explorer is in a real use case, check this tutorial.
Additional information
If you just received your RF Explorer and want to start playing with it, please go to the Getting Started page.
RF Explorer Detailed Specifications
RF Explorer model map
Free Downloads, including User Manual and firmware upgrades
Windows PC Client - download it for free and check some of the included examples to try RF Explorer right now!
Mac OSX Client - download it for free.
Uploading new firmware is easy and safe
Example of an RFBee transceiver monitored with a RF Explorer
Do you want to know what people say about RF Explorer? Check some of the reference threads online
