发表于 2012-5-11 16:37:56
The LSM333D is an inertial module capable of providing 9 DOF (degrees of freedom) inertial sensing by combining a 3D accelerometer, a 3D gyroscope and a 3D magnetometer in a system-in-package.
The LSM333D has linear acceleration full-scales of ±2g/±4g/±8g/±16g, a magnetic field full-scale of ±2/±4/±8/±12 gauss and an angular rate of 250/±500/±2000 dps. All full-scales available are fully selectable by the user.
The LSM333D includes an I2C serial bus interface supporting standard and Fast mode 100 kHz and 400 kHz, and SPI serial standard interface.
The system can be configured to generate interrupt signals, on dedicated pins, motion and magnetic field detection. Thresholds and the timing of interrupt generators are programmable by the end user.
Magnetic, accelerometer and gyroscope sensing can be enabled or set in Power-down mode separately for smart power management.
The LSM333D is available in a plastic land grid array package (LGA) and it is guaranteed to operate over an extended temperature range from -40 °C to +85 °C.
DATASHEET
Key Features
3 acceleration channels, 3 angular rate channels, 3 magnetic field channels
±2/±4/±8/±16 g dynamically selectable linear acceleration full-scale
±2/±4/±8/±12 gauss dynamically selectable magnetic full-scale
±250/±500/±2000 dps dynamically selectable angular rate full-scale
16-bit data output
SPI / I2C serial interfaces
Analog supply voltage 2.4 V to 3.6 V
Power-down mode / Low-power mode
Programmable interrupt generators
Embedded temperature sensor
Embedded FIFO
ECOPACK® RoHS and “Green” compliant
官方参考价格$3.1
http://www.st.com/cn/analog/product/253513.jsp![](static/image/smiley/default/titter.gif) |
