[root@localhost jolyxie]# ./scripts_pl/RunAll.pl
MODULE: 00 verify training files
O.S. is case sensitive ("A" != "a").
Phones will be treated as case sensitive.
Phase 1: DICT - Checking to see if the dict and filler dict agrees with the phonelist file.
Found 8 words using 16 phones
Phase 2: DICT - Checking to make sure there are not duplicate entries in the dictionary
Phase 3: CTL - Check general format; utterance length (must be positive); files exist
Phase 4: CTL - Checking number of lines in the transcript should match lines in control file
Phase 5: CTL - Determine amount of training data, see if n_tied_states seems reasonable.
Estimated Total Hours Training: 0.00451944444444444
This is a small amount of data, no comment at this time
Phase 6: TRANSCRIPT - Checking that all the words in the transcript are in the dictionary
Words in dictionary: 5
Words in filler dictionary: 3
Phase 7: TRANSCRIPT - Checking that all the phones in the transcript are in the phonelist, and all phones in the phonelist appear at least once
MODULE: 01 Train LDA transformation
Skipped (set $CFG_LDA_MLLT = 'yes' to enable)
MODULE: 02 Train MLLT transformation
MODULE: 05 Vector Quantization
Skipped for continuous models
MODULE: 10 Training Context Independent models for forced alignment and VTLN
Skipped: $ST::CFG_FORCEDALIGN set to 'no' in sphinx_train.cfg
Skipped: $ST::CFG_VTLN set to 'no' in sphinx_train.cfg
MODULE: 11 Force-aligning transcripts
MODULE: 12 Force-aligning data for VTLN
MODULE: 20 Training Context Independent models
Phase 1: Cleaning up directories:
accumulator...logs...qmanager...models...
Phase 2: Flat initialize
Phase 3: Forward-Backward
Baum welch starting for 1 Gaussian(s), iteration: 1 (1 of 1)
Waiting for /root/Desktop/jolyxie/model_parameters/my_db.ci_cont_flatinitial/mixture_weights
Only 0 parts of 1 of Baum Welch were successfully completed
Parts 1 failed to run!
Training failed in iteration 1
Something failed: (/root/Desktop/jolyxie/scripts_pl/20.ci_hmm/slave_convg.pl)
直接上错误的数据,这是怎么一回事呢,谢谢~~ |
