小弟初学ARM,对汇编的知识底子不够,在看IAR中的LPC2XXX的启动文件有很多地方不明白,希望各位高手能够指点小弟一下,入题
下面这一段代码高手们应该很熟悉吧,这是IAR自己生成的启动代码的一块,我把问题注释到程序旁边显眼的地方,方便各位帮小弟解答
MODULE ?RESET
COMMON INTVEC:CODE:NOROOT(2)
PUBLIC __program_start
EXTERN ?cstartup
EXTERN undef_handler, swi_handler, prefetch_handler
EXTERN data_handler, irq_handler, fiq_handler
CODE32 ; Always ARM mode after reset
org 0x00
__program_start
ldr pc,[pc,#24] ; Absolute jump can reach 4 GByte
; ldr b,?cstartup ; Relative branch allows remap, limited to 32 MByte
; Vectors can be enabled by removing the comments below or by
; using #pragma vector from C code.
org 0x04 //这里使用了ORG伪指令;
ldr pc,[pc,#24] ; Branch to undef_handler
org 0x08
; ldr pc,[pc,#24] ; Branch to swi_handler
org 0x0c
; ldr pc,[pc,#24] ; Branch to prefetch_handler
org 0x10
; ldr pc,[pc,#24] ; Branch to data_handler
org 0x18
; ldr pc,[pc,#24] ; Branch to irq_handler
org 0x1c
; ldr pc,[pc,#24] ; Branch to fiq_handler
; Constant table entries (for ldr pc) will be placed at 0x20
; Exception vectors can be specified in C code by #pragma vector or by filling
; in the vectors below. The vector address is the ARM vector number + 0x20.
org 0x20
dc32 ?cstartup
org 0x24
; dc32 undef_handler
org 0x28
; dc32 swi_handler
org 0x2c
; dc32 prefetch_handler
org 0x30
; dc32 data_handler
org 0x38
; dc32 irq_handler
org 0x3c
; dc32 fiq_handler
LTORG
; ENDMOD __program_start
ENDMOD
下面这段启动代码是在IAR官网上下载的,听说是一个老师写的,我的汇编知识不行,所以有很多疑问的地方
PROGRAM ?RESET
COMMON INTVEC:CODE(3)
EXTERN Reset_Handler, Undef_Handler, SWI_Handler, PAbt_Handler, DAbt_Handler, FIQ_Handler
__program_start
LDR PC, =Reset_Handler //这是我第一个疑问的地方,这里没有用ORG,是不是因为程序从0地址开始,并且前面声明
LDR PC, =Undef_Handler //CODE32,所以后面指令都是32位的,因此地址排列顺序是从0x00,0x04,0x08...所以可以不用ORG
LDR PC, =SWI_Handler
LDR PC, =PAbt_Handler
LDR PC, =DAbt_Handler //第二个疑问的地方就是这个B.的含义及作用,我查到好像是无限循环,但放在这里具体作用是啥我很茫然
B . ;点代表当前地址
LDR PC, [PC, #-0x0120] ; Vector from VicVectAddr
LDR PC, =FIQ_Handler
LTORG
ENDMOD
先谢谢各位高手了,问题已经在注释里了,很短的几句话,希望大家停下脚步帮小弟看看,不甚感激啊~~ |
