发表于 2012-5-3 19:52:50
贴上ttl信息,求助。。
U-Boot 1.1.4 (Dec 31 2011 - 13:38:52)
U-boot MI124
DRAM: 32 MB
id read 0x100000ff
flash size 4MB, sector count = 64
Flash: 4 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ag934x_enet_initialize...
No valid address in Flash. Using fixed address
wasp reset mask:c03300
WASP ----> S17 PHY *
: cfg1 0x7 cfg2 0x7114
eth0: ba:be:fa:ce:08:41
athrs17_reg_init: complete
eth0 up
eth0
Autobooting in 1 seconds
## Booting image at 9f020000 ...
Uncompressing Kernel Image ... OK
Starting kernel ...
[ 0.000000] Linux version 3.3.3 (gzanan@qq810091899) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #2 Sun Apr 29 17:03:03 CST 2012
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 0001974c (MIPS 74Kc)
[ 0.000000] SoC: Atheros AR9342 rev 1
[ 0.000000] Clocks: CPU:525.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 02000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00002000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00002000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: board=TL-WR1041N-v2 console=ttyS0,115200 rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 29288k/32768k available (2087k kernel code, 3480k reserved, 399k data, 200k init, 0k highmem)
[ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:48
[ 0.000000] Calibrating delay loop... 261.73 BogoMIPS (lpj=1308672)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.090000] NET: Registered protocol family 16
[ 0.090000] gpiochip_add: registered GPIOs 0 to 22 on device: ath79
[ 0.100000] MIPS: machine is TP-LINK TL-WR1041N v2
[ 0.310000] bio: create slab <bio-0> at 0
[ 0.320000] Switching to clocksource MIPS
[ 0.320000] NET: Registered protocol family 2
[ 0.330000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.330000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.340000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.340000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.350000] TCP reno registered
[ 0.350000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.360000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.360000] NET: Registered protocol family 1
[ 0.390000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.390000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.400000] msgmni has been set to 57
[ 0.410000] io scheduler noop registered
[ 0.410000] io scheduler deadline registered (default)
[ 0.420000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.440000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
[ 0.450000] console [ttyS0] enabled, bootconsole disabled
[ 0.460000] m25p80 spi0.0: found en25q32b, expected m25p80
[ 0.470000] m25p80 spi0.0: en25q32b (4096 Kbytes)
[ 0.480000] 5 tp-link partitions found on MTD device spi0.0
[ 0.480000] Creating 5 MTD partitions on "spi0.0":
[ 0.490000] 0x000000000000-0x000000020000 : "u-boot"
[ 0.490000] 0x000000020000-0x0000000fd8e4 : "kernel"
[ 0.500000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 0.510000] 0x0000000fd8e4-0x0000003f0000 : "rootfs"
[ 0.520000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 0.530000] mtd: partition "rootfs" set to be root filesystem
[ 0.540000] mtd: partition "rootfs_data" created automatically, ofs=330000, len=C0000
[ 0.550000] 0x000000330000-0x0000003f0000 : "rootfs_data"
[ 0.560000] 0x0000003f0000-0x000000400000 : "art"
[ 0.560000] 0x000000020000-0x0000003f0000 : "firmware"
[ 0.810000] ag71xx_mdio: probed
[ 0.930000] ag71xx_mdio: probed
[ 0.940000] eth0: Atheros AG71xx at 0xb9000000, irq 4
[ 1.520000] eth0: AR8327 switch driver attached.
[ 1.650000] ag71xx ag71xx.0: eth0: connected to PHY at ag71xx-mdio.0:00 [uid=004dd033, driver=Atheros AR8216/AR8236/AR8316]
[ 1.670000] TCP westwood registered
[ 1.670000] NET: Registered protocol family 17
[ 1.670000] 8021q: 802.1Q VLAN Support v1.8
[ 1.680000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[ 1.690000] Freeing unused kernel memory: 200k freed
- preinit -
Press the [f] key and hit [enter] to enter failsafe mode
[ 4.680000] eth0: link up (1000Mbps/Full duplex)
- regular preinit -
[ 6.770000] JFFS2 notice: (469) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 18 of xref (0 dead, 5 orphan) found.
switching to jffs2
- init -
[ 6.880000] eth0: link down
Please press Enter to activate this console. [ 8.420000] Compat-wireless backport release: compat-wireless-2012-04-17-1-r31481
[ 8.430000] Backport based on wireless-testing.git master-2012-04-17
[ 8.460000] cfg80211: Calling CRDA to update world regulatory domain
[ 8.820000] cfg80211: World regulatory domain updated:
[ 8.820000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 8.830000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.840000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 8.850000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 8.850000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.860000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.100000] usbcore: registered new interface driver usbfs
[ 9.110000] usbcore: registered new interface driver hub
[ 9.110000] usbcore: registered new device driver usb
[ 9.600000] ieee80211 phy0: Atheros AR9340 Rev:0 mem=0xb8100000, irq=47
[ 9.610000] cfg80211: Calling CRDA for country: US
[ 9.670000] cfg80211: Regulatory domain changed to country: US
[ 9.680000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 9.690000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
[ 9.700000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
[ 9.710000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.710000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.720000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.730000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
[ 9.740000] PPP generic driver version 2.4.2
[ 9.890000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.070000] NET: Registered protocol family 24
[ 10.100000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 10.130000] nf_conntrack version 0.5.0 (460 buckets, 1840 max)
[ 10.570000] xt_time: kernel timezone is -0000
[ 12.820000] eth0: link up (1000Mbps/Full duplex) |
