哪位老大能帮忙解释下下段FPGA中的TCL脚本啊?
set_global_assignment -name FAMILY "Cyclone III"
set_global_assignment -name DEVICE EP3C25Q240C8
set_global_assignment -name TOP_LEVEL_ENTITY LED8
set_global_assignment -name ORIGINAL_QUARTUS_VERSION 8.0
set_global_assignment -name PROJECT_CREATION_TIME_DATE "21:24:14 AUGUST 29, 2009"
set_global_assignment -name LAST_QUARTUS_VERSION 9.0
set_global_assignment -name USE_GENERATED_PHYSICAL_CONSTRAINTS OFF -section_id eda_palace
set_global_assignment -name NOMINAL_CORE_SUPPLY_VOLTAGE 1.2V
set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top
set_global_assignment -name PARTITION_COLOR 14622752 -section_id Top
set_global_assignment -name LL_ROOT_REGION ON -section_id "Root Region"
set_global_assignment -name LL_MEMBER_STATE LOCKED -section_id "Root Region"
set_global_assignment -name STRATIX_DEVICE_IO_STANDARD "3.3-V LVTTL"
set_global_assignment -name RESERVE_ALL_UNUSED_PINS_WEAK_PULLUP "AS INPUT TRI-STATED"
set_global_assignment -name TIMEQUEST_MULTICORNER_ANALYSIS ON
set_global_assignment -name TIMEQUEST_DO_CCPP_REMOVAL ON
set_global_assignment -name VERILOG_FILE LED8.v
set_global_assignment -name MIN_CORE_JUNCTION_TEMP 0
set_global_assignment -name MAX_CORE_JUNCTION_TEMP 85
set_global_assignment -name USE_CONFIGURATION_DEVICE ON
set_global_assignment -name CYCLONEIII_CONFIGURATION_DEVICE EPCS16
set_global_assignment -name FORCE_CONFIGURATION_VCCIO ON
set_global_assignment -name MISC_FILE "F:/Projects/ICDev/EP3c16Q240_Verilog/led/led8.dpf"
set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to RESET
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to light[7]
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GCLKP1 |
