发表于 2012-6-2 12:02:54
xiaomaoci 发表于 2012-6-2 10:44
公司做产品有用0511,晶振用的是4.19M的陶瓷晶振
小弟不太懂这个怎么配置。
void SetclkCrystal(void)
unsigned char ucTemp1,ucTemp2;
Initialize the clock generators
OSTS =0x05;
OSCCTL=0X40; /*if clock is used OSC,OSCclk>10M,set AMPH bit*/
MSTOP = 0; //start extclk
ucTemp1=0x1f;
#ifndef DEBUG_SIM
do{
ucTemp2=OSTC;
ucTemp2&=ucTemp1;
}while(ucTemp1!=ucTemp2); //wait ext clk is ok
MCM=0X05; //hispeed system&device clk is set as extclk
RSTOP = 0; //stop inner hi speed clk
XTSTART = 0; //subclk pin use as gpio
PCC=0X00; //fxp=fosc/2
LSRSTOP = 0; //stop inner low speed clk
给你这段程序,这个程序是用晶振的4M,大于10M的OSCCTL=0X40;这句要改改 |
