型号 LINKSYS WRT54GP2A-AT 54M无线路由+2口VOIP网络电话
CPU Intel IXP425 RAM 32M FLASH 8M
内部的WIFI网卡插在PCI接口 INPROCOMM IPN2220 54M无线内置网卡
收到货马上配置好,竟然没问题, (用了几天也没发现问题,就是信号差点)
验明正身后当然就要开始剥衣服了 ,剥完衣服观摩一番后就开始找可以进入的地方了
JTAG很容易就看出来了,因为是20脚,有一边很多地线的
串口(系统控制台)稍微试了一下也找到了TX RX 脚,通信参数搞多了的都猜得到是115200 8N1 无流控
Pin(s) Desig. Dest Desig.
1,2 Vcc
3 tts/1 TXD
4 tts/0 TXD
5 tts/1 RXD
6 tts/0 RXD
7,8 NC
9,10 GND GND
连上超级终端
Starting EthAcc component ...
0x1fffe68 (tRootTask): ixQMgrInit: IxQMgr initialise
ixe ETH PHY 0 Hard Coded MAC address is: 00:12:17:cc:72:2b
ixe ETH PHY 1 Hard Coded MAC address is: 00:12:17:cc:72:2c
VxWorks System Boot
Copyright 1984-2002 Wind River Systems, Inc.
CPU: WRT54GP2A-AT
Version: VxWorks5.5.1
BSP version: 1.3/3
Boot version: 0.00.f
Creation date: Sep 29 2004, 14:17:09
Press any key to stop auto-boot...
0
auto-booting...
boot device : tffs:
unit number : 0
processor number : 0
file name : /fl/vxWorksB.sys
inet on ethernet (e) : 192.168.1.1:ffffff00
host inet (h) : 192.168.1.100
user (u) : target
flags (f) : 0x0
target name (tn) : targetname
other (o) : ixe
Attaching to TFFS... done.
Loading /fl/vxWorksB.sys... 3302292
Starting at 0xa80000...
PCI Device Table
Bus Slot Func Vendor Device BAR
00 00 00 0x17fe 0x2220 0x100000
Host Name: bootHost
Return ixp425 wlan name string..
Parsed unit number 0
Start call i2220ap_priv_create
End call i2220ap_priv_create
Mem setup complete
Done load Wlan
Attached TCP/IP interface to ixe unit 0
Attaching network interface lo0... done.
Multicast MAC: 01:00:5e:00:00:01 ( ff:ff:ff:ff:ff:ff )
Constituent Addresses:
01:00:5e:00:00:01
Adding 21903 symbols for standalone.
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version 5.5.1
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.6
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-2003
CPU: . Processor #0.
Memory Size: 0x2000000. BSP version 1.3/3.
check file system now !
dosChkLib : CLOCK_REALTIME is being reset to FRI APR 13 06:13:00 2012
Value obtained from file system volume descriptor pointer: 0x17dfef0
The old setting was THU JAN 01 00:00:00 1970
Accepted system dates are greater than THU DEC 27 00:00:00 1990
/fl/ - Volume is OK
ixdp425EthEndStartUp: Forcing Hard Coded IP Address for ixe1
01:00:5e:00:00:01
ixdp425EthEndStartUp: ixe1: IP Addr set to 192.168.60.1
bridgePortAdd ******** for ixe0*****************
bridgePortAdd ******** for Frisbee0*****************
_____________ get mac[4] = 0x72 mac[5] = 0x2b
-> prio = 150,snmpdTaskOptions=0,stackSize=28672,traceLevel Log Length=0
Start Initial MEM Drv
Copy OK: 57470 bytes copied
CC module initialized successfully
FlshFormatFileSystem: Invalid Filesys ID -1
vxBitsInit
aIfName = mirror0
!!!!!!!!!!!!!!Find Interface mirror0
aIfName = ixe1
!!!!!!!!!!!!!!Find Interface ixe1
aIfName = Frisbee0
Error 0xffffffff Couldn't add Input Hooks
WAN Initialisation [SUCCESS]
PPPoE Initialised
PPTP Initialised
L2TP Initialization success
Firewall INIT completed
AD Init completed FW initalized
** before calling dhcpc http register function **
TFTPD:Initializatinion ok ...............
IGWIpRsmInit(): ....End
Initialising UPnP Stack DEBUG: IGWHttpServStart: server is now running
UPnP Stack InitialisedRegistered MsgClnt
load<==>ulTotalLen = 1708, ulFlashchecksum=133958, ulCheckSum = 20b46
IGWUPNLdSvInit 54
IGWIGDLoadAndSaveInit: success
../../ldsvcbk/firewall/kukildsv.c(76): FWCookieLdsvInit: SUCCESS
* LDSV Flash VERSION [1.6] *
* matching code LDSV VERSION , OK *
IpAddRoute : iproute->ifname ixe1
Loading RIP configuration records - success.
Loaded RIP database
standard_tftp_server launched on port 69.
DNSRDLoad Done
DNSRDLoadSysDName Done
Firewall load database completed Loaded Security database
Dns ALG loaded
IGWIGD: Loading data
lTotalRecs is 2
IGWUPnPIGDGetWanConnStatus: WanGetExactStatsByUser : DIM : No Such DiUser
IGWIGDSetIface/Ethernet/PPP Conn Service: No PPP Interface found with name ----
IGWIGDLoadEnable :lTotalRecs is 1
UPnPPeriodicAdvertiseRestatr: Starting Advt.
IGWIGDLoad: IGWIGDLoad() success
IGWUPN: Loading data
IGWUPNLoadData 74
IGWUPNLoadHostRec 266
IGWUPNLoadServRec 352
IGWUPNLoadServRec: DbGetRecordInfo Failed IGMPPoly DefaultDMZ is 21
test 2 - fffffff7 = b
Sucess Init Wireless.
Httpd_Register_TagArray
Wake up packet recvived
index = 1
DLcid 02050100-01
* Intel IXP400 DSP Software *
* Release 2.5 EAR *
* Jan 23 2004, 16:27:18 *
* Intel Corporation *
Initializing Slic's, please wait...
*** DnsResolveAPI PeerIp:2030708891 host:sasvp.callvantage.att.com***
当然也可以像U-BOOT那样在系统启动时按任意键进入BOOTLOADER
[VxWorks Boot]: ?
? - print this list
@ - boot (load and go)
p - print boot params
c - change boot params
l - load boot file
g adrs - go to adrs
d adrs[,n] - display memory
m adrs - modify memory
f adrs, nbytes, value - fill memory
t adrs, adrs, nbytes - copy memory
e - print fatal exception
v - print boot logo with version
n netif - print network interface device address
$dev(0,procnum)host:/file h=# e=# b=# g=# u=usr [pw=passwd] f=#
tn=targetname s=script o=other
boot device: tffs=drive,removable file name: /tffs0/vxWorks
Boot flags:
0x02 - load local system symbols
0x04 - don't autoboot
0x08 - quick autoboot (no countdown)
0x20 - disable login security
0x40 - use bootp to get boot parameters
0x80 - use tftp to get boot image
0x100 - use proxy arp
available boot devices:Enhanced Network Devices
ixe0 ixe1 tffs
[VxWorks Boot]:
有点失望是VXWORK而不是LINUX系统,也就没第三方固件可以刷了,但好消息是DD-WRT(第三方路由器固件,可以下载源码)正在移植LINUX到这个设备上,网上貌似也有人移植LINUX成功了
其实WRT54GP2A-AT 可以安装redboot 后再装XScale架构版本的openwrt,但是VOIP就失效了,不过性能和功能要增强很多
这二天预备潜心研究一下wrt54gp2a-at,让它跑openwrt。 今天的成果,基本完成redboot的。
RedBoot(tm) bootstrap and debug environment [ROM]
Red Hat certified release, version 2.02 - built 00:07:02, May 9 2010
Platform: Linksys WRT54GP2A-AT (IXP42X 400MHz) BE
Copyright (C) 2000, 2007, 2008, 2009, 2010 Red Hat, Inc.
RAM: 0x00000000-0x02000000, [0x000249f0-0x01fd1000] available
FLASH: 0x50000000 - 0x50800000, 64 blocks of 0x00020000 bytes each.
== Executing boot script in 2.000 seconds - enter ^C to abort
今天完成openwrt。
RedBoot> fis load linux
RedBoot> exec
Using base address 0x00024c00 and length 0x000c865c
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.32.10 (openwrt@localhost.localdomain) (gcc version 4.3.3 (GCC) ) #1 Sun May 9 15:13:09 CST 2010
CPU: XScale-IXP42x Family [690541d1] revision 1 (ARMv5TE), cr=000039ff
CPU: VIVT data cache, VIVT instruction cache
Machine: Linksys WRT54GP2A-AT
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line: root=/dev/mtdblock2 rootfstype=squashfs,jffs2 noinitrd console=ttyS0,115200
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 32MB = 32MB total
Memory: 30164KB available (2064K code, 130K data, 88K init, 0K highmem)
Hierarchical RCU implementation.
NR_IRQS:32
Calibrating delay loop... 398.95 BogoMIPS (lpj=1994752)
CPU: Testing write buffer coherency: ok
IXP4xx: Using 16MiB expansion bus window size
PCI: IXP4xx is host
PCI: IXP4xx Using direct access for memory space
PCI: bus0: Fast back to back transfers disabled
pci 0000:00:01.0: dmabounce: registered device
bio: create slab <bio-0> at 0
Switching to clocksource OSTS
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
IXP4xx Queue Manager initialized.
squashfs: version 4.0 (2009/01/31) Phillip Lougher
Registering mini_fo version $Id$
JFFS2 version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 58
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xc8001000 (irq = 13) is a XScale
console [ttyS0] enabled
IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x7e0000
5 RedBoot partitions found on MTD device IXP4XX-Flash.0
Creating 5 MTD partitions on "IXP4XX-Flash.0":
0x000000000000-0x000000060000 : "RedBoot"
0x000000060000-0x000000140000 : "linux"
0x000000140000-0x0000007e0000 : "rootfs"
mtd: partition "rootfs" set to be root filesystem
mtd: partition "rootfs_data" created automatically, ofs=400000, len=3E0000
0x000000400000-0x0000007e0000 : "rootfs_data"
0x0000007e0000-0x0000007ff000 : "FIS directory"
0x0000007ff000-0x000000800000 : "RedBoot config"
IXP4xx MII Bus: probed
eth0: MII PHY 32 on NPE-B
eth1: MII PHY 1 on NPE-C
i2c /dev entries driver
IXP4xx Watchdog Timer: heartbeat 60 sec
TCP westwood registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
XScale DSP coprocessor detected.
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing init memory: 88K
Please be patient, while OpenWrt loads ...
- preinit -
Press the [f] key and hit [enter] to enter failsafe mode
- regular preinit -
switching to jffs2
mini_fo: using base directory: /
mini_fo: using storage directory: /overlay
- init -
Please press Enter to activate this console. net eth0: firmware: requesting NPE-B
NPE-B: firmware's license can be found in /usr/share/doc/LICENSE.IPL
NPE-B: firmware functionality 0x2, revision 0x2:1
eth0: link up, speed 0 Mb/s, full duplex
device eth0 entered promiscuous mode
br-lan: port 1(eth0) entering forwarding state
net eth1: firmware: requesting NPE-C
NPE-C: firmware's license can be found in /usr/share/doc/LICENSE.IPL
NPE-C: firmware functionality 0x5, revision 0x2:1
Generic kernel compatibility enabled based on linux-next next-20100113
cfg80211: Calling CRDA to update world regulatory domain
cfg80211: World regulatory domain updated:
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
(2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
(5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
PCI: enabling device 0000:00:01.0 (0140 -> 0142)
Registered led device: rt2500pci-phy0::radio
Registered led device: rt2500pci-phy0::quality
PPP generic driver version 2.4.2
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ip_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 24
nf_conntrack version 0.5.0 (472 buckets, 1888 max)
CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or
sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
IMQ driver loaded successfully.
Hooking IMQ before NAT on PREROUTING.
Hooking IMQ after NAT on POSTROUTING.
xt_time: kernel timezone is -0000
device wlan0 entered promiscuous mode
br-lan: port 2(wlan0) entering forwarding state
device wlan0 left promiscuous mode
br-lan: port 2(wlan0) entering disabled state
BusyBox v1.15.3 (2010-05-09 14:54:15 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
Backfire (10.03, r21402) --------------------------
* 1/3 shot Kahlua In a shot glass, layer Kahlua
* 1/3 shot Bailey's on the bottom, then Bailey's,
* 1/3 shot Vodka then Vodka.
root@OpenWrt:/# ifconfig
br-lan Link encap:Ethernet HWaddr 00:03:47F:32:A8
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:1 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:402 (402.0 B)
eth0 Link encap:Ethernet HWaddr 00:03:47F:32:A8
collisions:0 txqueuelen:100
eth1 Link encap:Ethernet HWaddr 00:03:47F:32:AA
UP BROADCAST MULTICAST MTU:1500 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encapocal Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
mon.wlan0 Link encap:UNSPEC HWaddr 00-18-01-E3-D5-99-00-00-00-00-00-00-00-00-00-00
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
collisions:0 txqueuelen:1000
RX bytes:254 (254.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr 00:18:01:E35:99
RX bytes:0 (0.0 B) TX bytes:420 (420.0 B)
root@OpenWrt:/# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 2816 2816 0 100% /rom
tmpfs 15128 40 15088 0% /tmp
tmpfs 512 0 512 0% /dev
/dev/mtdblock3 3968 408 3560 10% /overlay
mini_fo:/overlay 2816 2816 0 100% /
root@OpenWrt:/# free
total used free shared buffers
Mem: 30252 13140 17112 0 1672
Swap: 0 0 0
Total: 30252 13140 17112
root@OpenWrt:/# cat /proc/cpuinfo
Processor : XScale-IXP42x Family rev 1 (v5b)
BogoMIPS : 398.95
Features : swp half fastmult edsp
CPU implementer : 0x69
CPU architecture: 5TE
CPU variant : 0x0
CPU part : 0x41d
CPU revision : 1
Hardware : Linksys WRT54GP2A-AT
Revision : 0000
Serial : 0000000000000000
root@OpenWrt:/# lspci
00:01.0 Network controller: RaLink RT2500 802.11g Cardbus/mini-PCI (rev 01)
root@OpenWrt:/#
