大家好,最近想做Dfb移植,所以先在fedora上安装DFB,但装了几天了,却老是不能装好,请知道的大虾知声,情况是这样的:
我安装了dfb 1.4.10,也安装了dfb_extra 1.2.0,最后安装了dfb_example 1.2.0,修改后,例子编译通过,但我在执行例子的时候,却出现这样的错误:
执行df_window时
~~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.4.10 |~~~~~~~~~~~~~~~~~~~~~~~~~~
(c) 2001-2010 The world wide DirectFB Open Source Community
(c) 2000-2004 Convergence (integrated media) GmbH
(*) DirectFB/Core: Single Application Core. (2012-04-17 07:33)
(*) Direct/Modules: suppress module 'x11input'
(*) Direct/Thread: Started 'SDL Input' (25524) [INPUT OTHER/OTHER 0/0] <10485760>...
(*) DirectFB/Input: SDL Input 0.1 (Denis Oliver Kropp)
(*) DirectFB/Genefx: MMX detected and enabled
(*) DirectFB/Graphics: SDL Graphics 0.1 (directfb.org)
(*) Direct/Thread: Started 'Screen Update' (25525) [OUTPUT OTHER/OTHER 0/0] <10485760>...
(*) DirectFB/Core/WM: Default 0.3 (directfb.org)
(!) Core/LayerRegion: Could not lock region surface for SetRegion()!
--> Not supported!
--> Not supported!
(!) [25523: 0.000] --> Caught signal 11 (at 0x38, invalid address) <--
(!!!) *** WARNING [still objects in 'Layer Region Pool'] *** [object.c:241 in fusion_object_pool_destroy()]
(!!!) *** WARNING [still objects in 'Layer Context Pool'] *** [object.c:241 in fusion_object_pool_destroy()]
(!!!) *** WARNING [still objects in 'Surface Pool'] *** [object.c:241 in fusion_object_pool_destroy()]
(!) Direct/Thread: Canceling 'Screen Update' (25525)!
还有一些例子也出现错误,例如执行./df_fire
(*) Direct/Thread: Started 'SDL Input' (25556) [INPUT OTHER/OTHER 0/0] <10485760>...
(*) Direct/Thread: Started 'Screen Update' (25557) [OUTPUT OTHER/OTHER 0/0] <10485760>...
(!) DirectFB/Genefx: Could not lock destination!
--> Not supported!
--> Not supported!
(!) Core/LayerRegion: realize_region() in dfb_layer_region_flip_update() failed!
--> Not supported!
(#) DirectFBError [IDirectFBSurface::Lock() failed]: Object is suspended!
请问有兄弟遇到过类似的情况吗?谢谢!
