今天参考了TI有关提供的ADC12的例程,想通过仿真来查看ADC12MEMx的转换结果,不过仿真的时候程序一直停留在main函数里面,根本没进中断服务函数,望大家帮忙看看到底是什么问题,simulation里的interrupt steup 的中断向量也已经设置成ADC12_VECTOR了,下面是代码- //******************************************************************************
- // MSP-FET430P140 Demo - ADC12, Sequence of Conversions (non-repeated)
- // Description: This example shows how to perform A/D conversions on a sequence
- // of channels. A single sequence of conversions is performed - one conversion
- // each on channels A0, A1, A2, and A3. Each conversion uses AVcc and AVss for
- // the references. The conversion results are stored in ADC12MEM0, ADC12MEM1,
- // ADC12MEM2, and ADC12MEM3 respectively and are moved to 'results[]' upon
- // completion of the sequence. Test by applying voltages to pins A0, A1, A2,
- // and A3, then setting and running to a break point at the "_BIC..."
- // instruction in the ISR. To view the conversion results, open a watch window
- // in debugger and view 'results' or view ADC12MEM0, ADC12MEM1, ADC12MEM2, and
- // ADC12MEM3 in an ADC12 SFR window.
- // This can run even in LPM4 mode as ADC has its own clock
- // Note that a sequence has no restrictions on which channels are converted.
- // For example, a valid sequence could be A0, A3, A2, A4, A2, A1, A0, and A7.
- // See the MSP430x1xx User's Guide for instructions on using the ADC12.
- // MSP430F149
- // Vin0 -->|P6.0/A0 |
- // Vin1 -->|P6.1/A1 |
- // Vin2 -->|P6.2/A2 |
- // Vin3 -->|P6.3/A3 |
- // M. Mitchell
- // Texas Instruments Inc.
- // Feb 2005
- // Built with IAR Embedded Workbench Version: 3.21A
- #include <msp430x14x.h>
- static unsigned int results[4]; // Needs to be global in this example
- // Otherwise, the compiler removes it
- // because it is not used for anything.
- void main(void)
- WDTCTL = WDTPW+WDTHOLD; // Stop watchdog timer
- P6SEL = 0x0F; // Enable A/D channel inputs
- ADC12CTL0 = ADC12ON+MSC+SHT0_2; // Turn on ADC12, set sampling time
- ADC12CTL1 = SHP+CONSEQ_1; // Use sampling timer, single sequence
- ADC12MCTL0 = INCH_0; // ref+=AVcc, channel = A0
- ADC12MCTL1 = INCH_1; // ref+=AVcc, channel = A1
- ADC12MCTL2 = INCH_2; // ref+=AVcc, channel = A2
- ADC12MCTL3 = INCH_3+EOS; // ref+=AVcc, channel = A3, end seq.
- ADC12IE = 0x08; // Enable ADC12IFG.3
- ADC12CTL0 |= ENC; // Enable conversions
- while(1)
- ADC12CTL0 |= ADC12SC; // Start conversion
- _BIS_SR(LPM0_bits + GIE); // Enter LPM0, Enable interrupts
- #pragma vector=ADC_VECTOR
- __interrupt void ADC12ISR (void)
- results[0] = ADC12MEM0; // Move results, IFG is cleared
- results[1] = ADC12MEM1; // Move results, IFG is cleared
- results[2] = ADC12MEM2; // Move results, IFG is cleared
- results[3] = ADC12MEM3; // Move results, IFG is cleared
- _BIC_SR_IRQ(LPM0_bits); // Clear LPM0, SET BREAKPOINT HERE
复制代码 |
