C:\WINCE600\PLATFORM\HFRK2410A\src\drivers\GPIO\sources
Starting Build: set WINCEREL=1&&build&&makeimg
BUILD: [Thrd:Sequence:Type ] Message
BUILD: [00:0000000000:PROGC ] Build started with parameters:
BUILD: [00:0000000001:PROGC ] Build started in directory: C:\WINCE600\PLATFORM\HFRK2410A\src\drivers\GPIO
BUILD: [00:0000000002:PROGC ] Checking for C:\WINCE600\sdk\bin\i386\srccheck.exe.
BUILD: [00:0000000003:PROGC ] Running passes WCEFILES0, MIDL, MC, ASN, THUNK, PRECOMPHEADER, COMPILE, LIB, LINK, MANAGEDRESX, MANAGEDMOD, MANAGEDDLL, MANAGEDEXE, MANAGEDWIN for ARM.
BUILD: [00:0000000004:PROGC ] Loading database "C:\WINCE600\PLATFORM\HFRK2410A\Build.dat".
BUILD: [00:0000000005:PROGC ] Done.
BUILD: [00:0000000006:PROGC ] Computing include file dependencies:
BUILD: [00:0000000007:PROGC ] Checking for SDK include directory: C:\WINCE600\sdk\CE\inc.
BUILD: [00:0000000008:PROGC ] Scan C:\WINCE600\PLATFORM\HFRK2410A\src\drivers\GPIO\
BUILD: [00:0000000009:PROGC ] Done.
BUILD: [00:0000000010:PROGC ] Files Warnings Errors
BUILD: [00:0000000011:PROGC ] Midl 0 0 0
BUILD: [00:0000000012:PROGC ] Message 0 0 0
BUILD: [00:0000000013:PROGC ] Precomp Header 0 0 0
BUILD: [00:0000000014:PROGC ] Resource 0 0 0
BUILD: [00:0000000015:PROGC ] MASM 0 0 0
BUILD: [00:0000000016:PROGC ] SHASM 0 0 0
BUILD: [00:0000000017:PROGC ] ARMASM 0 0 0
BUILD: [00:0000000018:PROGC ] MIPSASM 0 0 0
BUILD: [00:0000000019:PROGC ] C++ 0 0 0
BUILD: [00:0000000020:PROGC ] C 0 0 0
BUILD: [00:0000000021:PROGC ] Static Libraries 0 0 0
BUILD: [00:0000000022:PROGC ] Exe's 0 0 0
BUILD: [00:0000000023:PROGC ] Dll's 0 0 0
BUILD: [00:0000000024:PROGC ] Preprocess deffile 0 0 0
BUILD: [00:0000000025:PROGC ] Resx 0 0 0
BUILD: [00:0000000026:PROGC ] CSharp Compile 0 0 0
BUILD: [00:0000000027:PROGC ] Other 0 0 0
BUILD: [00:0000000028:PROGC ]
BUILD: [00:0000000029:PROGC ] Total 0 0 0
BUILD: [00:0000000030:PROGC ]
BUILD: [00:0000000031:PROGC ] 0 Warnings, 0 Errors
BUILD: [00:0000000032:PROGC ] GetSystemTimes (seconds): Idle: 3 Kernel: 3 User: 0
BUILD: [00:0000000033:PROGC ] Elapsed time (seconds): 2
Build for Windows CE (Release 601) (Built on Aug 17 2006 15:18:52)
File names: Build.log Build.wrn Build.err Build.dat
makeimg for Windows CE (Release) (Built on Jul 10 2006 16:41:09)
makeimg: Change directory to C:\WINCE600.
makeimg: run command: cmd /C C:\WINCE600\public\common\oak\misc\pbpremakeimg
Generating PBWorkspace Custom makeimg build step batch Files to C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\Wince600\HFRK2410A_ARMV4I\oak
Done Generating PBWorkspace Custom makeimg build step batch Files
makeimg: Check for C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\PreMakeImg.bat to run.
makeimg: Found localization settings.
makeimg: LOCALE: 0804 LOCALE3: (null) TargetDir: 0804 CodePage=936 LocaleId: 804 PrimaryLandId: 4 SubLangId: 2
makeimg: Building international version for locale 0804
makeimg: Check C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\tokens\0804\ for tokens.
makeimg: Read string substitutions from C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\intltrns\0409\
makeimg: No .str files found.
makeimg: Copy files from C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\intlfile\0409\ to release directory.
makeimg: Read string substitutions from C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\intltrns\0804\
makeimg: Copy files from C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\intlfile\0804\ to release directory.
makeimg: Creating C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\nlscfg.out because C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\postproc\nlscfg.inf doesn't exist.
makeimg: run command: fmerge -nls C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\nlscfg.out C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\postproc\nlscfg.inf
fmerge for Windows CE (Release) (Built on Apr 5 2006 11:32:16)
Error - cannot open input file C:\WINCE600\OSdesigns\2410\OSDesign1\OSDesign1\RelDir\HFRK2410A_ARMV4I_Debug\postproc\nlscfg.inf
makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec).
C:\WINCE600\PLATFORM\HFRK2410A\src\drivers\GPIO\sources - 3 error(s), 0 warning(s) |
