很多人都喜欢研究程序,这里提供GU900D模块的OPEN AT的自动化单元代码。
//////////////////////////////////////////////////// custom_app.c ///////////////////////////////////////////////////////////////////////////////////////
#include "gu_sdk.h"
extern void ut_at_result_handler(gu_message_req_struct *msg_req);
extern void ut_keypad_handler(gu_message_req_struct *msg_req);
extern void ut_eint_handler(gu_message_req_struct *msg_req);
extern void ut_uart_data_handler(gu_message_req_struct *msg_req);
extern void ut_timer_expire_handler();
static gu_uint8 gImage_hfy[] = {
0xFF,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x01,
0x01,
0x01,
0x01,
0x01,
0x01,
0xFF,
0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xE0,0x60,0x40,
0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x40,0x40,0xE0,
0xE0,
0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x00,0x00,0x40,0x40,0x40,0xC0,0xE0,
0x20,
0x20,0x40,0xC0,0x80,0x00,0xE0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,
0x00,
0x00,0x00,0x00,0x00,0xE0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,
0xFF,
0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x0C,0x86,0xC3,0x79,0x39,0x13,
0xFF,
0xFD,0x11,0x31,0xE5,0xC7,0x83,0x01,0x00,0x84,0x84,0xC5,0x65,0x75,0xDD,0x8F,
0xF7,
0xF5,0x8D,0xDD,0x75,0x65,0xE5,0xC4,0x44,0x00,0x82,0xC2,0x72,0x3E,0xFF,0xFF,
0x9A,
0x92,0x84,0xDD,0x59,0x40,0xFF,0xFF,0x20,0x20,0x00,0x21,0x21,0x31,0xFF,0xFF,
0x0D,
0x05,0x19,0x79,0xE9,0x8F,0xCF,0x79,0x39,0x09,0x01,0x00,0x00,0x00,0x00,0x00,
0x00,
0x00,
0xFF,
0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x03,0x01,0x00,0x00,0x08,0x18,
0x1F,
0x0F,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x04,0x04,0x06,0x02,0x0B,0x19,
0x1F,
0x0F,0x01,0x03,0x06,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,
0x00,
0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x00,0x00,0x80,0x80,0x08,0x18,0x1F,0x0F,
0x88,
0x88,0x0C,0x86,0x83,0x01,0x03,0x06,0x0C,0x0C,0x04,0x80,0x80,0x00,0x00,0x00,
0x00,
0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,
0xFF,
0x00,
0x00,0x00,0x04,0x04,0xFE,0xFE,0x00,0x00,0x00,0x00,0x00,0x1C,0x1E,0x02,0x82,
0xE2,
0x7E,0x1C,0x00,0x00,0x1C,0xBE,0xE2,0x42,0xE2,0xBE,0x1C,0x00,0x00,0x20,0x60,
0xE0,
0xA0,0xE0,0x60,0x20,0x00,0x00,0xF8,0xFC,0x66,0x22,0x66,0xC6,0x80,0x00,0x00,
0xC0,
0xF0,0x38,0x0C,0xFE,0xFE,0x00,0x00,0xC4,0xF4,0xFF,0xFF,0x34,0x25,0x7D,0x7D,
0x57,
0xD7,0xD5,0x57,0x7F,0x7D,0x01,0x00,0x00,0x04,0x04,0xFF,0xFF,0x44,0x44,0x42,
0x42,
0xFF,0xFF,0x42,0x42,0x7E,0x7E,0x40,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,
0xFF,
0x00,
0x00,0x00,0x08,0x08,0x0F,0x0F,0x08,0x08,0x00,0x00,0x00,0x0C,0x0E,0x0B,0x09,
0x08,
0x0C,0x0C,0x00,0x00,0x07,0x0F,0x08,0x08,0x08,0x0F,0x07,0x00,0x00,0x08,0x0C,
0x0F,
0x0B,0x0F,0x0C,0x08,0x00,0x00,0x03,0x07,0x0C,0x08,0x0C,0x07,0x03,0x00,0x00,
0x01,
0x01,0x09,0x09,0x0F,0x0F,0x09,0x00,0x00,0x00,0x3F,0x3F,0x00,0x21,0x21,0x31,
0x1D,
0x0F,0x07,0x0D,0x19,0x39,0x31,0x11,0x00,0x02,0x06,0x07,0x03,0x21,0x31,0x1C,
0x0F,
0x03,0x01,0x03,0x06,0x0C,0x1C,0x18,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,
0xFF,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0xFF,
0xFF,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x80,
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x80,
0x80,
0x80,
0x80,
0x80,
0x80,
0xFF,
static void LCD_display_fb(gu_uint8 *fb)
gu_uint8 Pages,Columns;
gu_uint16 k=0;
gu_lcd_send_cmd(0x40); //display start line set *?*
for (Pages=0; Pages<=7; Pages++)
gu_lcd_send_cmd(0xb0 + Pages); //page address set
gu_lcd_send_cmd(0x10);
gu_lcd_send_cmd(0x00); //set column address
for (Columns=0; Columns < 128; Columns++)
gu_lcd_send_data(fb[k++]);
static void ut_message_handler(gu_message_req_struct *msg_req)
switch (msg_req->msg_type)
case GU_MSG_AT_RESULT:
ut_at_result_handler(msg_req);
case GU_MSG_KEYPAD_EVT:
ut_keypad_handler(msg_req);
case GU_MSG_EINT_EVT:
ut_eint_handler(msg_req);
case GU_MSG_UART_DATA_EVT:
ut_uart_data_handler(msg_req);
case GU_MSG_TIMER_EXPIRE:
default:
void gu_main_task()
const char *test_str = "GU900D unit test start....\r\n";
gu_message_req_struct *msg_req = NULL;
// execute the ut_timer_expire_handler after 5 seconds
gu_app_start_timer(3000);
LCD_display_fb(gImage_hfy);
gu_uart2_send_data((gu_uint8*)test_str, strlen(test_str));
gu_gpio_mode_setup(GU_PIN_CTS, GU_IO_MODE_5);
gu_gpio_mode_setup(GU_PIN_RTS, GU_IO_MODE_5);
while (1) {
if ((msg_req = gu_get_message())) {
// Process the current message
ut_message_handler(msg_req);
gu_free_message(msg_req);
//////////////////////////////////////////////////// custom_unit_test.c ///////////////////////////////////////////////////////////////////////////////////////
#include "gu_sdk.h"
#include "stdlib.h"
extern void Uart_Printf(char * fmt, ...);
/////////// macro definitions ////////////////////////////////////////////
#define NUM_ELEMS(x) (sizeof(x)/sizeof(x[0]))
#define UNIT_TEST_OK(feature) do { \
Uart_Printf("[%s] unit test OK\r\n", feature); \
} while (0);
#define UNIT_TEST_ERR(feature, code) do { \
Uart_Printf("[%s] unit test ERR, %d\r\n", feature, code); \
return; \
} while (0);
#define UNIT_TEST_DBG(feature, fmt, ...) do {\
Uart_Printf("[%s] ", feature); \
Uart_Printf(fmt, __VA_ARGS__); \
Uart_Printf("\r\n"); \
} while(0)
#define GU_AUDIO_TEST "AUDIO"
#define GU_MEM_TEST "MEM"
#define GU_FLASH_ACCESS "FLASH"
#define GU_AT_RESULT "AT RET"
#define GU_ADC_VOL "ADC"
#define GU_KEYPAD_EVENT "KEYPAD"
#define GU_EINT_EVENT "EINT"
#define GU_UART_EVENT "UART"
static gu_uint8 gu_test_func_id = 0;
static gu_uint16 gu_at_cmd_index = 0;
typedef struct {
gu_char *cmd;
gu_char *expect_str;
}gu_at_cmd_expect_struct;
/////////// gloabl / module variant ////////////////////////////////////////////
static gu_at_cmd_expect_struct gu_at_cmd_ut_list[] = {
{"AT\r\n", "OK"},
{"ATE0\r\n", "OK"},
{"AT+CMGF=1\r\n", "OK"},
{"AT+CSQ\r\n", "OK"},
{"AT+CPIN?\r\n", "OK"},
{"AT+CREG=2\r\n", "OK"},
{"AT+CIPSCONT?\r\n", "OK"},
{"AT+CIPSTART?\r\n", "OK"},
//{"ATD10010;\r\n", "OK"},
{"ATD10086;\r\n", "OK"},
{"ATH\r\n", "OK"},
{"AT+ENBR\r\n", "OK"},
{NULL, NULL}
static const char * s_finalResponsesError[] = {
"ERROR",
"+CMS ERROR:",
"+CME ERROR:",
"NO CARRIER", /* sometimes! */
"NO ANSWER",
"NO DIALTONE",
static const char * s_finalResponsesSuccess[] = {
"OK",
"CONNECT" /* some stacks start up data on another channel */
/** returns 1 if line starts with prefix, 0 if it does not */
int strStartsWith(const char *line, const char *prefix)
for ( ; (*line != '\0' || *line != '\r') && *prefix != '\0' ; line++, prefix++)
if (*line != *prefix)
return 0;
return (*prefix == '\0');
static int isFinalResponseError(const char *line)
gu_uint8 i;
for (i = 0 ; i < NUM_ELEMS(s_finalResponsesError) ; i++)
if (strStartsWith(line, s_finalResponsesError[i]))
return 1;
return 0;
static int isFinalResponseSuccess(const char *line)
gu_uint8 i;
for (i = 0 ; i < NUM_ELEMS(s_finalResponsesSuccess) ; i++)
if (strStartsWith(line, s_finalResponsesSuccess[i]))
return 1;
return 0;
// Play all audio id
void ut_audio_test_func()
static gu_uint16 i = GU_RING_IMY_01;
gu_bool ret;
if (i == GU_TONE_KEY_STAR)
i = GU_RING_IMY_01;
gu_send_at_command("AT+CLVL=6\r\n", 11);
else if (i == GU_RING_IMY_10)
gu_test_func_id++;
UNIT_TEST_DBG(GU_AUDIO_TEST, "stop %d\r\n", i - 1);
gu_app_stop_audio(i - 1);
UNIT_TEST_DBG(GU_AUDIO_TEST, "play %d", i);
ret = gu_app_play_audio(i, GU_AUDIO_PLAY_ONCE, GU_DEVICE_SPEAKER);
UNIT_TEST_DBG(GU_AUDIO_TEST, "%d\r\n", ret);
//kal_sleep_task(kal_milli_secs_to_ticks(i >= GU_RING_IMY_01 ? 10000:1000));
//gu_app_stop_audio(i);
i = i++;
unsigned char buf_al[ 8 *1024];
unsigned char buf_al2[ 10 *1024];
unsigned char buf_al3[ 16 *1024];
void ut_mem_test_func()
unsigned char buf_tmpl[2 *1024];
unsigned char buf_tmpl2[ 2 *1024];
gu_uint8 *p_alloc ;
p_alloc = gu_app_malloc(2*1024);
memset(buf_al, 10, sizeof(buf_al));
memset(buf_al2, 10, sizeof(buf_al2));
memset(buf_al3, 10, sizeof(buf_al3));
memset(buf_tmpl, 0xFF, sizeof(buf_tmpl));
memset(p_alloc, 0xFF, sizeof(1024));
UNIT_TEST_DBG(GU_MEM_TEST, "buf_al: %X", &buf_al[0]);
UNIT_TEST_DBG(GU_MEM_TEST, "buf_al2: %X", &buf_al2[0]);
UNIT_TEST_DBG(GU_MEM_TEST, "buf_al3: %X", &buf_al3[0]);
UNIT_TEST_DBG(GU_MEM_TEST, "buf_tmpl: %X", &buf_tmpl[0]);
UNIT_TEST_DBG(GU_MEM_TEST, "buf_tmpl2: %X", &buf_tmpl2[0]);
UNIT_TEST_DBG(GU_MEM_TEST, "p_alloc: %X", p_alloc);
gu_app_free(p_alloc);
gu_test_func_id++;
void ut_flash_access_func()
gu_int16 ret;
gu_char str_buf[512];
gu_int32 max_size = 1024 * 1024; // 1MB
gu_uint8 rec_id = 0;
int i = 0;
// Flash access Unit test code
for (rec_id = 0; rec_id < 10; rec_id++)
UNIT_TEST_DBG(GU_FLASH_ACCESS, "File %d, %d", rec_id, max_size / sizeof(str_buf));
ret = gu_flash_alloc(rec_id, max_size);
if (ret != GU_FLASH_NO_ERROR)
gu_test_func_id++;
UNIT_TEST_OK(GU_FLASH_ACCESS);
return;
for (i = 0; i < max_size / sizeof(str_buf); i++)
memset(str_buf, 0, sizeof(str_buf));
sprintf(str_buf, "unit test. %d, %d\r\n", rec_id, i);
ret = gu_flash_write(rec_id, i * sizeof(str_buf), str_buf,sizeof(str_buf));
UNIT_TEST_ERR(GU_FLASH_ACCESS, 2);
//UNIT_TEST_DBG(GU_FLASH_ACCESS, "write rec=%d", i);
// Write the data exceed the max_size of flash
ret = gu_flash_write(rec_id, max_size, str_buf, sizeof(str_buf));
if (ret == GU_FLASH_NO_ERROR)
UNIT_TEST_ERR(GU_FLASH_ACCESS, 3);
// Read all data in possible
ret = gu_flash_read(rec_id, i * sizeof(str_buf), str_buf, sizeof(str_buf));
UNIT_TEST_ERR(GU_FLASH_ACCESS, 4);
//UNIT_TEST_DBG(GU_FLASH_ACCESS, "read rec=%s", str_buf);
// Read the data exceed the max_size of flash
ret = gu_flash_read(rec_id, max_size, str_buf, sizeof(str_buf));
UNIT_TEST_ERR(GU_FLASH_ACCESS, 5);
gu_test_func_id++;
extern int AtexBytes2String(const unsigned char* pSrc, char* pDst, int nSrcLength) ;
void ut_dump_to_uart_hex(gu_uint8 *data_buf, gu_int16 data_len)
gu_uint8 data[5];
gu_uint8 buffer[64];
gu_int16 idx;
sprintf(buffer, "HEX %d:\r\n", data_len);
gu_uart1_send_data(buffer, strlen(buffer));
data[0] = '\0';
buffer[0] = '\0';
for (idx = 0; idx < data_len; idx++)
AtexBytes2String(&data_buf[idx], (char*)data, 1);
data[2] = ' ';
data[3] = '\0';
strcat((char*)buffer, (char*)data);
if ((idx + 1) % 20 == 0)
strcat((char*)buffer, "\r\n");
gu_uart1_send_data(buffer, strlen((char*)buffer));
buffer[0] = '\0';
idx = strlen((char*)buffer);
if (idx > 0)
gu_uart1_send_data(buffer, idx);
gu_uart1_send_data((gu_uint8*)"\r\n", 2);
gu_char at_result[GU_MAX_UART_LEN + 1];
gu_char *at_ptr = at_result;
gu_uint8 i;
gu_bool at_completed = GU_FALSE;
gu_uint16 curr = 0, len = 0;
gu_uint16 ulen = 128;
memcpy(at_result, msg_req->data, msg_req->data_length);
at_result[msg_req->data_length] = '\0';
ut_dump_to_uart_hex(msg_req->data, msg_req->data_length);
gu_uart1_send_data((gu_char*)msg_req->data, msg_req->data_length);
return;
do {
while(*at_ptr == '\r' || *at_ptr == '\n')
at_ptr++;
if (*at_ptr == '\0')
if (isFinalResponseError(at_ptr))
at_completed = GU_TRUE;
else if (isFinalResponseSuccess(at_ptr))
} while ((at_ptr = (gu_char*)strstr(at_ptr, "\r")));
if (!at_completed)
return;
if (gu_at_cmd_index >= NUM_ELEMS(gu_at_cmd_ut_list) - 1)
gu_test_func_id++;
//ut_timer_expire_handler();
gu_app_start_timer(100);
void ut_at_cmd_list_func()
gu_uint8 cmd_idx = gu_at_cmd_index % (NUM_ELEMS(gu_at_cmd_ut_list) - 1);
if (gu_at_cmd_ut_list[cmd_idx].cmd)
Uart_Printf("[%d]=%s", gu_at_cmd_index, gu_at_cmd_ut_list[cmd_idx].cmd);
gu_send_at_command(gu_at_cmd_ut_list[cmd_idx].cmd,
strlen(gu_at_cmd_ut_list[cmd_idx].cmd));
gu_at_cmd_index++;
gu_key_evt_struct *key_evt = (gu_key_evt_struct*)msg_req->data;
UNIT_TEST_DBG(GU_KEYPAD_EVENT, "KEY CODE=%d, KEY TYPE=%d\r\n", key_evt->key_code, key_evt->key_type);
void ut_adc_vol_test_func()
UNIT_TEST_DBG(GU_ADC_VOL, "ext1 adc=%d\r\n", gu_app_get_adc_val(GU_ADC_EXT1));
UNIT_TEST_DBG(GU_ADC_VOL, "vbat adc=%d\r\n", gu_app_get_adc_val(GU_ADC_VBAT));
gu_eint_evt_struct *eint_evt = (gu_eint_evt_struct*)msg_req->data;
UNIT_TEST_DBG(GU_EINT_EVENT, "dev=%d, on_off=%d\r\n", eint_evt->dev_id, eint_evt->on_off);
// This sample is to test the case of inputting AT command from uart1 or uart2
// The user uses the uart connection like as the normal AT command module
gu_uart_data_evt_struct *uart_data = (gu_uart_data_evt_struct*)msg_req->data;
if (uart_data->port == GU_UART_PORT1) {
Uart_Printf((gu_char*)uart_data->data);
// Handle Custome AT command
if (memcmp(uart_data->data, "MIC1", 4) == 0)
gu_set_input_mic(GU_INPUT_MIC_1);
else if (memcmp(uart_data->data, "MIC2", 4) == 0)
gu_set_input_mic(GU_INPUT_MIC_2);
gu_send_at_command(uart_data->data, uart_data->data_length);
else if (uart_data->port == GU_UART_PORT2) {
Uart2_Printf((gu_char*)uart_data->data);
UNIT_TEST_ERR(GU_UART_EVENT, 1);
extern void AtexSetSleepModeReq(gu_uint8 index);
void ut_timer_expire(void* arg)
//Uart_Printf("ut_timer_expire\r\n");
//gu_start_timer(1, ut_timer_expire, NULL, 1000);
switch (gu_test_func_id)
case 0:
ut_audio_test_func();
gu_app_start_timer(5000);
case 1:
ut_mem_test_func();
gu_app_start_timer(1000);
case 2:
ut_flash_access_func();
case 3:
ut_at_cmd_list_func();
case 4:
ut_adc_vol_test_func();
