发表于 2012-10-22 16:28:32
for Altium Designer available【可下载】
【】Announcement: Update 22 for Altium Designer
FollowIryna Akhmetshyna18 Oct, 2012
The Altium Development team is pleased to announce the 22nd update for Altium Designer.
This release focuses on additional enhancements to Altium Designer, with the key highlights being:
Delete selected objects:
We have included a new feature in PCB Editor for deleting of selected objects (through the shortcut keys Ctrl+Delete), which then selects adjacent routed objects for further unrouting. When single end-of-route object is selected, Backspace shortcut now deletes selection and auto-selects connected singular route object. Each of these shortcuts can be used in a successive manner to incrementally unwind routed paths.
Read more in the Wiki.
New module for output of IDF:
This release has the addition of a new plugin “Output - IDF” found in the Output Generators category. This new plugin provides IDF export capability in the OutJob “Export Outputs” section.
Updated FPGA Device and Vendor Tools Support:
Xilinx ISE v14.2 and Lattice Diamond 2.0 are now supported. Ultra and micro fineline ball grid array (UBGA & MBGA) devices have been added to the Altera Cyclone4E Nexus driver.
There are an additional 25 new enhancements included in this release, with many a result of requests made through BugCrunch forum posts and support cases. Full details of this update can be found in the
release notes.
Accessing the Update
To update your Altium Designer installation, first ensure you are using a license with valid subscription. Proceed to the Plug-in page (DXP >> Plug-ins and Updates) and select “Update All”. If you don’t see the update, use the “Refresh” link in the top right hand corner of the Plugins page.
This release includes changes to our Run Time Libraries, which requires the majority of modules to be updated. For those users who experience a lengthy update process due to anti-virus programs, using the full download option becomes a much faster process. For more info, see Wiki.
Installation of the updated modules will bring their revision up to 10.1271.26245. The Platform Build number will also update to 10.1271.26245 as the Altium Designer Base module is updated.
Note: If you are using a Private Server license or Standalone license and you have renewed your subscription since activation, you will be required to reactivate your license to obtain this and future updates.
For those who installed directly from DVD, you can access the updates by changing a setting in preferences: System >> Installation Manager, change the Remote Repository Location to http://installation.altium.com
If you are wanting to install a new build containing this update, the Installer and Uninstaller can be downloaded from the Software page in AltiumLive - download the latest Installer/Uninstaller.
工具
Release notes for Altium Designer Update 22 (10.1271.26245)
Additional Resources
Complete list of Altium Designer updates
Update 22: Updated plug-ins from release 10.1181.24817 to 10.1271.26245
Date: 19 October 2012
Key highlights
We have included a new feature in PCB Editor for deleting of selected objects (through the shortcut keys Ctrl+Delete), which then selects adjacent routed objects for further unrouting. When single end-of-route object is selected, Backspace shortcut now deletes selection and auto-selects connected singular route object. Each of these shortcuts can be used in a successive manner to incrementally unwind routed paths. View BugCrunch report #916. View wiki info.
This release has the addition of a new plugin “Output - IDF” found in the Output Generators category. This new plugin provides IDF export capability in the OutJob “Export Outputs” section. View BugCrunch report #1363. View wiki info.
Updated FPGA device and vendor tools support
System Components: Altium Designer Base
6366 Give a better file name of each library report image while creating a browser style library report. View BugCrunch report #1560.
6397 Footprints included by PCBLib but not by DBLib can now be found. View BugCrunch report #1506.
6416 Net class directives attached to Blanket objects no longer produce incorrect "Duplicate Net Names Wire N000-1 (inferred)" compiler messages. View BugCrunch report #1944.
System Components: Altium Designer Localization
6204 Traditional Chinese localization of Altium Designer has been updated.
6387 Japanese localization of Altium Designer has been updated.
6388 Simplified Chinese localization of Altium Designer has been updated.
System Components: PCB System
5922 The interactive router option Allow Diagonal Pad Exits now works correctly for surface mount pads.
6373 PCB Tools >> Reannotate now allows the start index to be set.
6413 Fixed Interactive Diff-Pair router crash that would cause PCB to hang.
5504 Fixed slow response/hang when dragging a track near very large keepout arcs.
6494 Fixed problem with Copy Room Formats that would cause tracks in the room to not have their net assignment updated correctly after the copy.
6527 Fixed bug in Copy Room Format where vias sometimes would not be copied.
6432 PCB Editor Ctrl+Delete shortcut now deletes selection and auto-selects all route objects connected to deleted ones. When single end-of-route object is selected, Backspace shortcut now deletes selection and auto-selects connected singular route object. View BugCrunch report #916.
System Components: Schematic Support
6406 Internal memory options for FPGA LAX have been extended to support 8K, 16K, 32K and 64K entries. View BugCrunch report #1457.
System Components: Schematic System
6360 Place full circle is now available in Schematic: Place >> Drawing Tools >> Full Circle. View BugCrunch report #1050.
6391 Images in schematic document can be rotated now.
System Components: Soft Design Support
System Components: Soft Design System
6407 Lattice Diamond version 2.0 is now supported.
6403 Xilinx ISE 14.2 is now supported.
6374 Ultra and micro fineline ball grid array (UBGA & MBGA) devices have been added to the Altera Cyclone4E Nexus driver.
System Components: Cyclone4E
FPGA Components: Instrument - Logic Analyser
Importers and Exporters: Exporter - IDF
6379 IDF Export is now handling the units and the board origin offset correctly. View BugCrunch report #513.
Importers and Exporters: Importer - IDF
Importers and Exporters: Importer - Allegro
5716 Allegro Importer into PcbDoc now detects objects of Class "Constraint Region" and imports them as Mechanical 1 layer outlines.
Output Generators: Output - AdvSim
Output Generators: Output - Gerber
6405 Gerber flashes are now created correctly for solder/paste mask features created automatically (from solder/mask expansion properties) for fills, tracks and arcs when mirrored Embedded Board Arrays are used.
Output Generators: Output - IDF (New Module)
6385 Added a new module "Output - IDF' to supply IDF Exporter capability in the OutJob "Export Outputs" section. View BugCrunch report #1363.
Development updating various modules
The development made for the following tickets required changes to our Run Time Libraries, and as a result require majority of the modules to be updated.
6281 Auto-increment will now increment trailing numbers that are preceded by a period "." or hyphen "-" for Smart Paste, shift-duplication, designators while placing parts, pins, components, pads, and for SchLib Component Rule Check. View BugCrunch report #1503.
4583 A run-time error (wbtc.exe) dialog no longer pops up during the build flow while multiple versions of Xilinx ISE have been installed on the same computer.
Редактировать | Профиль | Сообщение | Цитировать | Сообщить модератору
Altium Designer (ранее Protel DXP)
Текущая версия: 10.1271.26245, 19 Октября 2012
(Где Altium 12? Здесь: начиная с Update 18 (10.1051.23878) Altium считается Altium 12 — смена названия это скорей маркетинговый ход)
Боекомплекты (Наш колумбарий): Дополнительные библиотеки, примеры, референсные дизайны убраны, поскольку прекрасно качаются с хомяка
Если вы новичок в работе с Altium Designer и в данной теме, прочитайте Altium Designer 10. Ru-board FAQ [?].
Рекомендуется также почитать Installation and Content Management (вики хомяка)
11.0: Altium Designer 10.1271.26245 [?] — Полный репозитарий + Документация + Unified Components
Раздача на free-torrents ведуший — наш бензиновый король (Gazolini)
Altium Private License Server 9.0.0.17655 [?]
Внимание! То, что не занесено в шапку, не проверялось. Что там — АЕЗ. Если скачали и поимели траблы, в топик не писать, искать автора и ему бить морду.
Дополнения от разработчика
Документация к Altium Designer 10 [?]
Примеры, библиотеки, референсные дизайны на хомяке [?] Свободный доступ
Русская страница на Altium Wiki Свободный доступ
Примеры из ливера хомяка [?]
Видео с Altium Live [?]
Unified Components — Библиотеки с Altium Vault [?] Все новые библиотеки, недоступны для свободного скачиваниях
Полезняшки
Апдейтер от Partizannen [?]
Апдейтер от Evgeny972 [?]
Распаковщик репозитария Altium Designer [?]
Скрипт распаковки репозитария от Partizannen [?]
Pentalogix ViewMate [?] Очень хороший Gerber-viewer
Репозитарий 3D-моделей [?] Содержит 3D модели, предоставленные членами нашего кружка
Старые версии:
Altium Designer 9.4.0.20159 Summer 09 SP4 [?] и Atmel QTouch Pack [?]
Набор доктора Пилюлькина (для всех версий) [?] Обновлен 13-10-2011 Читать обязательно!!!
Если не оговорено специально, используется стандартный пароль [?]
Бесплатные дополнения к Altium Designer (Altium Designer addons)
Фичи Altium Designer и прочее [?] Сборник всяких полезных и вредных советов по работе с сабжем, не Альтумовские руководства, использование выходов Altium в других программах, и т.д. и т.п.
Просьба ко всем: Если у вас возникли проблемы, и вы обращаетесь за помощью, указывайте хотя бы минимальные сведения, а не просто вопль Видоплясова Не работает!!!. Кашпировских и Глоб в этой теме нет.
下载地址:如下
Evgeny972
Gold Member Редактировать | Профиль | Сообщение | Цитировать | Сообщить модератору
Полный комплект. Запакованный репозитарий. 19 Октября 2012
1. Сабж уже вылеченный, после установки нет необходимости заменять какие нибудь файлы.
После установки: DXP -> My Account -> Add standalone license file и указать файл из папки Licenses!
2. Licenses:
Содержит 10 Standalone лицензий.
Так же содержит полный набор доктора Пилюлькина для тех кто хочет сгенерировать свои лицензии
(включая Floating для Private License Server) — читайте Лечение Altium Designer.pdf
3. Private License Server 9.0.0.17655:
Помогает, если в сети более 1-й установки.
Читаем Установка Private License Server.pdf
4. Utilities — полезняшки:
AD-update-1.0.0.15 — апдейтер от Partizannen
ADUpdater-1.7.0.257 — апдейтер от Evgeny972
ADRUnpacker — распаковщик репозитария 1.0.3.65
5. Altium Extras\Altium Designer Documentation 1.1 — файлы офлайн справки
6. Altium Extras\Altium Unified Components — библиотеки с Altium Vault.
7. Medicine.rar: Оригинальные и вакцинированые файлы (на всякий пожарный).
Altium Designer Update 22 — линк на страницу с описанием изменений
Altium Designer Updates v1.9.pdf — описание всех изменений до Update 21 (фишка у них теперь такая, последний апдейт в документ не включать).
!!! Внимание! В этой версии альтиумовцы нахомутали что-то с инсталлятором:
1. При начальной установке доступна только опция Soft Design.
Поэтому все остальное ручками: DXP -> Plug-ins and updates
2. Косяк с запуском альтиевского апдейтера.
После выбора изменений (DXP -> Plug-ins and updates) не щелкайте по … changes ready. Click to apply., а закрывайте AD.
Запустите AD Run as Administrator.
То же самое после использования ADUpdater-1.7.0.257 (и, наверное, AD-update-1.0.0.15), запустите AD Run as Administrator.
(Всё это есть в !!! Read Me !!!.txt)
Линки на скачку [?]下载地址 23个包【Линки на скачку [?]下载地址 23个包 点击哪个连接就可以,然后要注册就OK....http://forum.ru-board.com/topic. ... limit=1&m=1#1..】
Evgeny972
Контрольные суммы
Часть 1
Часть 2
Часть 3
Часть 4
Часть 5
Часть 6
Часть 7
Часть 8
Часть 9
Часть 10
Часть 11
Часть 12
Часть 13
Часть 14
Часть 15
Часть 16
Часть 17
Часть 18
Часть 19
Часть 20
Часть 21
Часть 22
Часть 23
http://rs546p2.rapidshare.com/cg ... p;dlauth=0123456789
http://rs544p10.rapidshare.com/c ... p;dlauth=0123456789
http://rs182p5.rapidshare.com/cg ... p;dlauth=0123456789
http://rs296p2.rapidshare.com/cg ... p;dlauth=0123456789
http://rs158p3.rapidshare.com/cg ... p;dlauth=0123456789
http://rs57p11.rapidshare.com/cg ... p;dlauth=0123456789
http://rs769p6.rapidshare.com/cg ... p;dlauth=0123456789
http://rs536p4.rapidshare.com/cg ... p;dlauth=0123456789
http://rs948p6.rapidshare.com/cg ... p;dlauth=0123456789
http://rs653p4.rapidshare.com/cg ... p;dlauth=0123456789
http://rs945p5.rapidshare.com/cg ... p;dlauth=0123456789
http://rs906p1.rapidshare.com/cg ... p;dlauth=0123456789
http://rs506p1.rapidshare.com/cg ... p;dlauth=0123456789
http://rs723p10.rapidshare.com/c ... p;dlauth=0123456789
http://rs521p5.rapidshare.com/cg ... p;dlauth=0123456789
http://rs471p11.rapidshare.com/c ... p;dlauth=0123456789
http://rs438p2.rapidshare.com/cg ... p;dlauth=0123456789
http://rs457p4.rapidshare.com/cg ... p;dlauth=0123456789
http://rs702p3.rapidshare.com/cg ... p;dlauth=0123456789
http://rs886p9.rapidshare.com/cg ... p;dlauth=0123456789
http://rs409p7.rapidshare.com/cg ... p;dlauth=0123456789
http://rs252p10.rapidshare.com/c ... p;dlauth=0123456789
http://rs76p4.rapidshare.com/cgi ... p;dlauth=0123456789
我11.0: Altium Designer 10.1271.26245 [?] — Полный
10月21日 23:31
我可以下载。可以直接复制到迅雷下载。。。。过期不侯。。。
