#include "reg52.h"
#define uint unsigned int
sbit rs=P1^0;//H数据,L命令
sbit lcden=P1^1;//高脉冲使能,使能脉宽最小150ns
sbit kong=P1^2;
sbit ok=P1^3;
sbit jia=P1^4;
uchar code table1[]="error!";
uchar code table2[]="0123456789";
uchar code table3[]="SetSpeed:";
uchar code table4[]=" OK! ";
uchar code table5[]="Return.";
uchar pp=0;
uchar biaozhi=0;
uchar jishu=0;
uchar oksign=0;
uchar anjiang=0;
uchar dingshi=0;
void zhongduan_init(void)
IT0=1;
EX0=1;
TMOD=0x02;
ET0=1;
TH0=TL0=(256-200);
//EA=1;
void delay(uchar x)//1MS定时
{ uint y;
for(;x>0;x--)
for(y=123;y>0;y--)
void lcdwrdata(uchar dat)
{ rs=1;//写数据时RS拉高
lcden=1;
P2=dat;
delay(6);
lcden=0;
delay(6);
void lcdwrcom(uchar cdat)//写指令数据到LCD
{ rs=0;//写指令时RS拉低
lcden=1;
P2=cdat;//
delay(6);//不加此延时将导致不能写入指令,但能写入显示数据
lcden=0;
delay(6);
void lcd_init()
lcdwrcom(0x38);//0x38设置显示模式为:16X2 显示,5X7 点阵,8 位数据接口
lcdwrcom(0x0c);//打开显示光标闪烁
lcdwrcom(0x06);//
lcdwrcom(0x01);//
void key(void)
jia=1;
ok=1;
if(anjiang==0)
if(jia==0)
jia=1;
if(jia==0)
delay(70);
if(jia==0)
jishu++;
if(ok==0)
ok=1;
if(ok==0)
delay(70);
if(ok==0)
oksign=1;
void lcd_dong(uchar aj,uchar ao)
uchar n=0;
static uchar xiaobiao=0;
if(jishu>5)
lcdwrcom(0x01);
lcdwrcom(0x00|0x80);
for(n=0;n<6;n++)
lcdwrdata(table1[n]);
//delay(30);
lcdwrcom(0x45|0x80);
for(n=0;n<7;n++)
lcdwrdata(table4[n]);
// delay(30);
jishu=0;
xiaobiao=1;
if(xiaobiao==0)
lcdwrcom(0x09|0x80);
lcdwrdata(table2[aj]);
//delay(100);
if(anjiang==0)
if(ao==1)
oksign=0;
anjiang=1;
for(n=0;n<7;n++)
lcdwrdata(table5[n]);
// delay(30);
EA=1;
else if(anjiang==1)
if(ao==1)
oksign=0;
anjiang=0;
for(n=0;n<7;n++)
// delay(30);
kong=1;
EA=0;
jishu=0;
if(ao==1)
for(n=0;n<9;n++)
lcdwrdata(table3[n]);
// delay(30);
xiaobiao=0;
oksign=0;
void main()
{ uchar n;
kong=1;
jishu=0;
zhongduan_init();
delay(200);
lcden=0;
lcd_init();
for(n=0;n<9;n++)
delay(100);
for(n=0;n<7;n++)
delay(100);
/* if(biaozhi==1)
delay(3);
if(pp>=1)
kong=0;
delay(3);
kong=1;
biaozhi=0;*/
lcd_dong(jishu,oksign);
// if(anjiang==0)
key();
void guoling(void) interrupt 0
TR0=1;
kong=1;
//delay(10);
//kong=0;
//delay(9);
//kong=1;
//delay(1);
/*switch (jishu)
case 0: {kong=1;break;}
case 1: {delay(4);kong=0;delay(6);kong=1;break;}
case 2: {delay(3);kong=0;delay(7);kong=1;break;}
case 3: {delay(2);kong=0;delay(8);kong=1;break;}
case 4: {delay(1);kong=0;delay(9);kong=1;break;}
case 5: {kong=0;delay(10);kong=1;break;}
void us(void) interrupt 1 //200us
dingshi++;
/* if(dingshi==10)
kong=1;
if(dingshi==25)
kong=0;
if(dingshi==45)
TR0=0;
dingshi=1;
kong=1;
