1-
A.H定义了:
#define Esc 3
b.h
要引用这个Esc该做些如何做呢?直接引用编译要报错。
2
while(KeYsCanFuc() != 2 || KeYsCanFuc() != 3){
//Per = KeYsCanFuc();
另外为什么这样检测不到按键值呢?如果单独任意一个是没问题的。
3
void LCD1602wRITESTring(unsigned char X,unsigned char Y,unsigned char *Date)
LCD1602WRITEData((0x80 + (X << 6) + Y),0); //如果X为1左移6为则刚好是0x40
while(*Date != '\0'){
LCD1602WRITEData(*Date,1); //写数据
Date++; //地址++
LCD1602dELAY(50); //适当延时
这个写字符触串的没什么问题吧?
void TimeSetFuc(void)
// unsigned char Per;
DS1302TimeRead(TimEdata);
LCD1602CLEARDisplaY();
LCD1602wRITESTring(0,0,"NNNNN"); //如果加上这句,采后菜单就不能动了,去掉就可以怎么回事啊
struct MenuItem code SysTemSet[5] = //系统菜单
{5,"1.DatA Set ",TimeDisPlaYFuc,&Null,MainMenu},
{5,"2.TimE Set ",TimeSetFuc ,&Null,MainMenu}, //上面的函数写在这里面的!
{5,"3.AlarM Set ",&Null,&Null,MainMenu},
{5,"4.BacKLed Set ",&Null,&Null,MainMenu},
{5,"5.Password Set ",&Null,&Null, &Null},
麻烦大家帮助一下,谢谢了,每次梯子都要陈希望这次不要! |
