发表于 2012-4-2 10:38:08
这是我写的程序,大家看看问题在哪里
#include"reg51.h"
sbit s17=P3^2; //按键
#define uint unsigned int
void one();
void two();
void three();
void delay(uint time);
uchar c;
uchar k,temp;
void main()
uchar time;
if(s17==0)
delay(20);
if(s17==0)
c++;
if(c==1)
{time=0;}
if(c==4)
{c=0;}
if(++time>=150)
switch(c)
case 1:
one();
case 2:
two();
case 3:
three();
default :
uint i,j;
for(i=0;i<time;i++)
for(j=0;j<50;j++);
void one()
uchar code nu[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
for(k=0;k<8;k++)
P1=nu[k];
delay(1500);
void two()
uchar code num[7]={0x3f,0x9f,0xcf,0xe7,0xf3,0xf9,0xfc};
for(k=0;k<7;k++)
P1=num[k];
delay(1500);
void three()
uchar code numm[6]={0x1f,0x8f,0xc7,0xe3,0xf1,0xf8};
for(k=0;k<6;k++)
P1=numm[k];
delay(1500);
