用的UIP协议。UDP通信。UCOS-II系统驱动
主函数如下:
void uIPMain(void)
u8_t i, arptimer,count;
uip_eth_hdr *BUF = (uip_eth_hdr*)uip_buf;
u32 j = 0;
u32 size;
count =0;
/* Initialize the uIP TCP/IP stack. */
uip_init();
/* Initialize the HTTP server. */
httpd_init();
arptimer = 0;
for(j = 0; j<0x100000; j++);
//if(uip_connect(uip_conn->ripaddr, 8080) == NULL) {
// uip_abort();
//uip_ipaddr(ipaddr, 110,184,108,37);
// uip_ipaddr(ipaddr, sysinformation.MyServerIP[0],sysinformation.MyServerIP[1],
// sysinformation.MyServerIP[2],sysinformation.MyServerIP[3]);
uip_ipaddr(ipaddr, TCP_IP[0],TCP_IP[1],TCP_IP[2],TCP_IP[3]);
//uip_connect(ipaddr, HTONS(8080));
uip_connect(ipaddr, HTONS(TCP_IP_HTONS));
// uip_connect(ipaddr, HTONS(8080));
/// uip_udp_new(ipaddr, HTONS(8080));
// PlayIntroDelay = 20;
// while(PlayIntroDelay != 0);
//while(JoyState()!= Up)
/* Let the tapdev network device driver read an entire IP packet
into the uip_buf. If it must wait for more than 0.5 seconds, it
will return with the return value 0. If so, we know that it is
time to call upon the uip_periodic(). Otherwise, the tapdev has
received an IP packet that is to be processed by uIP. */
//for(j = 0; j<0x500; j++);
OSTimeDlyHMSM(0,0,0,8);
count ++;
if(count >= 100)
count =0;
if(recon == 0)
// uip_connect(ipaddr, HTONS(TCP_IP_HTONS));
// PlayIntroDelay = 1;
size = ENET_HandleRxPkt(uip_buf);
if (size > 0)
uip_len = size;
if(uip_len <= 0x0)
for(i = 0; i < UIP_CONNS; i++) //tcp 连接
uip_periodic(i);
/* If the above function invocation resulted in data that
should be sent out on the network, the global variable
uip_len is set to a value > 0. */
if(uip_len > 0)
uip_arp_out();
TransmitPacket();
#if UIP_UDP
for(i = 0; i < UIP_UDP_CONNS; i++)
uip_udp_periodic(i);
if(uip_len > 0)
uip_arp_out();
TransmitPacket();
#endif /* UIP_UDP */
/* Call the ARP timer function every 10 seconds. */
if(++arptimer == 20)
uip_arp_timer();
arptimer = 0;
else //接到数据大于0
if(BUF->type == htons(UIP_ETHTYPE_IP)) //IP头
uip_arp_ipin(); //arp 表
uip_input(); //数据处理
if(uip_len > 0)
uip_arp_out(); //
TransmitPacket(); //真正的发送函数
else if(BUF->type == htons(UIP_ETHTYPE_ARP)) //ARP头
uip_arp_arpin(); //arp 输入
if(uip_len > 0)
TransmitPacket();
UIP协议两个(或以上)客户端跟同一个服务端器端口通信为什么有一个老是超时重连。
两个客户端老是有一个重连,而且重连是相互交替的,例如我两个客户端的IP尾数分别是20跟22,他们不停的(0.2S)给服务器端口发送数据。服务器显示:先是20的客户端连上了通信正常。22的没连上,过了一会儿(3S)22的连上了,20的却掉线了,再过一会儿20的又重连上了,22的掉线了。无限循环下去。不知道该怎么解决这个问题,求大神相助。我用的是标准的UIP协议。ARM芯片来驱动。只连接一个客户端一点问题都没有。两个客户端就有上述问题,仿真观察 是发送超时,然后连接被关闭。然后又轮询打开。我不知道该怎么改了。
求大神相助。
顺便问一下,UIP协议支持多个客户端同时向一台服务器通信吗
