之前发过一个帖子 关于在定时器中进行按键消抖的
但是 有几十个人去浏览了 没有头回复的 我想高手不可能是不屑于回答这个问题 但是还有一些跟我一样初学的人遇到了这种问题
我在网上搜过关于在定时器中按键消抖程序 但是 几乎 没找到 今天花了一下午的时间 逃了数字电路课 研究出来了 希望对那些跟我一样在这部分疑惑的初学者有所帮助
高手莫喷 高手也是从菜鸟慢慢成长起来的
#include<reg52.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
sbit RS=P2^4;
sbit RW=P2^5;
sbit E=P2^6;
uint8 code screen1[]="passcode:";
uint8 code screen2[]="right!";
uint8 code screen3[]="wrong!";
uint8 code passcode[6]={0,1,2,3,4,5};
uint8 key;
uint8 number[6]={0};
uint8 num;
bit flag=0;
void delay(uint16 x)
while(x--);
void write_1602(uint8 cdcode,bit cd)
E=0;
RS=cd;
RW=0;
P0=cdcode;
delay(100);
E=1;
delay(100);
E=0;
void init_1602()
write_1602(0x38,0);
write_1602(0x0c,0);
write_1602(0x06,0);
write_1602(0x01,0);
void write_string(uint8 screen[])
uint8 *p=screen;
write_1602(0x80,0);
while((*p)!='\0')
write_1602(*p,1);
p++;
delay(1000);
void init_timer0()
TMOD|=0X01;
TH0=0XFC;
TL0=0X18;
TR0=1;
EA=1;
ET0=1;
uint8 key_scan2()
uint8 temp1,temp2,temp2_2;
static uint8 i=0;
P3=0x0f;
temp1=P3&0X0F;
if(temp1!=0X0F)
if(flag)
flag=0;
i++;
if(i==20)
i=0;
if(temp1!=0X0F)
P3=temp1|0xf0;
temp2_2=temp2=P3&0xf0;
while(temp2_2!=0xf0)
temp2_2=P3&0xf0;
return (temp1+temp2);
uint8 key_scan1()
uint8 temp,i=0;
temp=key_scan2();
switch(temp)
case 0xee:return 0;break;
case 0xde:return 1;break;
case 0xbe:return 2;break;
case 0x7e:return 3;break;
case 0xed:return 4;break;
case 0xdd:return 5;break;
case 0xbd:return 6;break;
case 0x7d:return 7;break;
case 0xeb:return 8;break;
case 0xdb:return 9;break;
default: break;
return 10;
void main()
static uint8 i;
bit wrong=0,right=0;
init_timer0();
init_1602();
write_string(screen1);
write_1602(0x80+0x40,0);
write_1602(0x0f,0);
while(number[5]==0)
num=key_scan1();
if(num!=10)
number[i]=num;
write_1602(number[i]+'0',1);
i++;
delay(50000);
for(i=0;i<6;i++)
if(number[i]!=passcode[i])
right=0;
wrong=1;
if(wrong)
write_1602(0x01,0);
write_1602(0x80,0);
write_string(screen3);
if(!right)
write_1602(0x01,0);
write_1602(0x80,0);
write_string(screen2);
while(1);
void timer0_int() interrupt 1
TH0=0XFC;
TL0=0X18;
flag=1;
这是一个密码锁的程序 用1602液晶显示 4乘4矩阵键盘输入
第二次发帖 见笑了
