在NXP申请一块LPC1788,UART例程烧进去怎么没有反应。。。。
@How to run:
Hardware configuration:
This example was tested on:
1. NXP LPC17xx base board and LPC1788 core board
- JP11: OFF
- JP12: OFF
- JP13: OFF
Running mode:
This example can run on FLASH mode.
If want to burn hex file to board by using Flash Magic, these jumpers need
to be connected.
- JP11: ON
- JP12: ON
- JP13: ON
"UART2" in the board is actually UART0 of the micro.
Step to run:
- Step 1: Build example.
- Step 2: Run
- Step 3: connect UART1 or UART2 with PC
- Step 4: Open "Tera Term Pro" on PC, and config the suitable serial port with:
Baud rate: 9600; Data Lenth: 8 bit; No Parity and 1 bit stop, none flow control
- Step 5: Run
- Step 6: MCU will send back to PC the data received from PC
其中Running mode与Hardware configuration有什么区别啊!!! |
