程序就是这样的,电路基本和MK的的电路差不多,只不过反感应电动势检测的引脚不一样而已。我用了ADC3,2,1.
#include <iom8v.h>
#define uint unsigned int
#define PHASE_A_ON PORTD|=0x08;
#define PHASE_A_OFF PORTD&=0xf7;
#define PHASE_B_ON PORTD|=0x10;
#define PHASE_B_OFF PORTD&=0xef;
#define PHASE_C_ON PORTD|=0x20;
#define PHASE_C_OFF PORTD&=0xdf;
#define PWM_A_ON OCR2=pwmduty;
#define PWM_A_OFF OCR2=0;
#define PWM_B_ON OCR1B=pwmduty;
#define PWM_B_OFF OCR1B=0;
#define PWM_C_ON OCR1A=pwmduty;
#define PWM_C_OFF OCR1A=0;
#define AB_ON PWM_B_OFF PWM_C_OFF PHASE_A_OFF PHASE_C_OFF PWM_A_ON PHASE_B_ON
#define AC_ON PWM_C_OFF PWM_B_OFF PHASE_B_OFF PHASE_A_OFF PWM_A_ON PHASE_C_ON
#define BC_ON PWM_A_OFF PWM_C_OFF PHASE_A_OFF PHASE_B_OFF PWM_B_ON PHASE_C_ON
#define BA_ON PWM_A_OFF PWM_C_OFF PHASE_B_OFF PHASE_C_OFF PWM_B_ON PHASE_A_ON
#define CA_ON PWM_A_OFF PWM_B_OFF PHASE_B_OFF PHASE_C_OFF PWM_C_ON PHASE_A_ON
#define CB_ON PWM_A_OFF PWM_B_OFF PHASE_A_OFF PHASE_C_OFF PWM_C_ON PHASE_B_ON
#define TEST_AR ADMUX=0x03; ACSR=0x1a;
#define TEST_BR ADMUX=0x02; ACSR=0x1a;
#define TEST_CR ADMUX=0x01; ACSR=0x1a;
#define TEST_AF ADMUX=0x03; ACSR=0x1b;
#define TEST_BF ADMUX=0x02; ACSR=0x1b;
#define TEST_CF ADMUX=0x01; ACSR=0x1b;
#define STOP 0
#define STARTUP 1
#define RUN 2
uchar pwmduty=80;
uchar state=STOP;
//uchar start
uchar phase=0;
uint startdelay=1000;
uint startdelay2=1000;
uchar chtimes=0;
portinit()
DDRD=0x38;
PORTD=0x00;
DDRB=0xfe;
PORTB=0x00;
DDRC=0x00;
uinit()
UBRRL=51;
UCSRB|=0x88;
sendchar(char ch)
while(!(UCSRA&0x20));
UDR=ch;}
sendstr(char *str)
{unsigned int i;
i=0;
while(str!='\0')
{sendchar(str);
i++;
pwminit()
TCCR1A=0xa1;
TCCR1B=0x01;
OCR1A=0x00;
OCR1B=0x00;
TCCR2=0x61;
OCR2=0x00;
acmpinit()
SFIOR|=0x08;
ACSR=0x12;
ADMUX=0x01;
#pragma interrupt_handler acsvr:17
acsvr()
change_phase();
T0init()
TCCR0=0x01;
TIMSK|=0x01;
SREG|=0x80;
#pragma interrupt_handler t0svr:10
t0svr()
if(state==STARTUP)
if(chtimes<30)
if(!(startdelay2--))
pwmduty=20;
change_phase();
startdelay=startdelay*14/15;
startdelay2=startdelay;
chtimes++;
return;
else run();
startup()
ACSR=0x12;
pwmduty=5;
TCCR0=0x02;
startdelay=1000;
startdelay2=10000;
chtimes=0;
change_phase();
state=STARTUP;
run()
ACSR=0x1a;
state==RUN;
change_phase()
if(phase==0){AB_ON phase=1;TEST_CF sendstr("PHASE 0\r\n"); return;}
if(phase==1){AC_ON phase=2;TEST_BR sendstr("PHASE 1\r\n"); return;}
if(phase==2){BC_ON phase=3;TEST_AF sendstr("PHASE 2\r\n"); return;}
if(phase==3){BA_ON phase=4;TEST_CR sendstr("PHASE 3\r\n"); return;}
if(phase==4){CA_ON phase=5;TEST_BF sendstr("PHASE 4\r\n"); return;}
if(phase==5){CB_ON phase=0;TEST_AR sendstr("PHASE 5\r\n"); return;}
main()
portinit();
pwminit();
T0init();
acmpinit();
uinit();
//startup();
run();
哎,还是转不起来,示波器看引脚的波形,很乱。。![](http://cache.amobbs.com/bbs_upload782111/files_53/ourdev_725745HA3E7C.jpg)
(原文件名:Image00000.jpg) |
