发表于 2013-4-9 17:50:12
要学会看readme:
For visual studio users
There are Visual C/C++ workspace files for working with CppUTest.
Before opening Visual Studio, create this environment variable
CPP_U_TEST=<BookCodeParent>/code/CppUTest
If you are using a later version of Visual Studio, you can let your version
convert the workspace and project files.
Start by building CppUTest in VS. CppUTest has some Visual Studio solution files
for later version. You can use either sln or dsw files to get CppUTest built.
Build only for 'Debug'. 'Release' is not supported for any of the projects.
For each of the book's workspaces, open the dsw file (let later versions of
VS convert). Build and run without debug. You will get the command window
to linger after the test run if you run without debug. To keep feedback fast,
get used to using control-F5 to save all, build and run the tests.
If you did not define the CPP_U_TEST environment variable correctly you will get
compilation errors about not finding CppUTest include files
These are the Visual Studio workspace files:
<BookCodeParent>/code/BookCode.dsw
<BookCodeParent>/code/SandBox/SandBox.dsw
<BookCodeParent>/code/t0
<BookCodeParent>/code/t1
<BookCodeParent>/code/t2
<BookCodeParent>/code/t3
To build a specific code project from the command line
cd <BookCodeParent>/code[/t[0123]]
make |
