发表于 2006-11-17 16:35:18
Chip type : ATmega16
Program type : Application
Clock frequency : 16.000000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
#include <mega16.h>
const unsigned char SIN[65]={
0 ,13 ,25 ,37 ,50 ,62 ,74 ,86 ,98 ,109 ,120 ,131 ,142 ,152
,162 ,171 ,180 ,189 ,197 ,205 ,212 ,219 ,225
,231 ,236 ,240 ,244 ,247 ,250 ,252 ,254 ,255
,255 ,255 ,254 ,252 ,250 ,247 ,244 ,240 ,236
,231 ,225 ,219 ,212 ,205 ,197 ,189 ,180 ,171
,162 ,152 ,142 ,131 ,120 ,109 ,98 ,86 ,74 ,62 ,50 ,37 ,25
,13 ,0
unsigned char DEG=0;
unsigned char DEGSTEP=0;
unsigned char ENABLE=0;// External Interrupt 0 service routine //没有编程
interrupt [EXT_INT0] void ext_int0_isr(void) // 收到每步中断执行
unsigned i=0,j=0;
i=DEG;
if (i<65)
PORTD.0=1; // A方向 置1
}else
i=i-64;
PORTD.0=0; // A方向 置 0
j=DEG+32;
if (j>127) j=j-128;
if (j<65)
PORTD.1=1; // B方向 置 1
}else
j=j-64;
PORTD.1=0; // B方向 置 0
PORTA=SIN;
PORTB=SIN[j] ;
if (PINC.0==1) {
DEG=DEG+DEGSTEP; }
else {
if (DEG<DEGSTEP)
DEG=128-DEG;
DEG=DEG-DEGSTEP;}
if (DEG>127) DEG=DEG-128 ;
// Port A initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTA=0x00;
DDRA=0xFF;
// Port B initialization
PORTB=0x00;
DDRB=0xFF;
// Port C initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=P
PORTC=0x01;
DDRC=0x00;
// Port D initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=Out Func0=Out
// State7=P State6=P State5=P State4=T State3=T State2=T State1=0 State0=0
PORTD=0xE0;
DDRD=0x03;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: On
// INT0 Mode: Rising Edge
// INT1: Off
// INT2: Off
GICR|=0x40;
MCUCR=0x03;
MCUCSR=0x00;
GIFR=0x40;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
DEGSTEP=PIND&0B11100000;
DEGSTEP=DEGSTEP>>5;
m=0x00;
if (DEGSTEP==0b00000010) m=16; //2细分
if (DEGSTEP==0b00000100) m=8; //4细分
if (DEGSTEP==0b00000101) m=4; //8细分
if (DEGSTEP==0b00000110) m=2; //16细分
if (DEGSTEP==0b00000111) m=1; //32细分
if (m==0) m=1;
DEGSTEP=m;
#asm("sei")
// Global enable interrupts
while (1)
