发表于 2012-2-28 18:27:41
Tab Options
default indent
If no indentation option is set, the default option of 4 spaces will be used (e.g. -s4 --indent=spaces=4).
--indent=spaces / --indent=spaces=# / -s#
Indent using # spaces per indent (e.g. -s6 --indent=spaces=6). # must be between 2 and 20. Not specifying # will result in a default of 4 spaces per indent.
--indent=tab / --indent=tab=# / -t / -t#
Indent using tab characters. Treat each tab as # spaces (e.g. -t6 / --indent=tab=6). # must be between 2 and 20. If no # is set, treats tabs as 4 spaces.
--indent=force-tab / --indent=force-tab=# / -T / -T#
Indent using tab characters. Treat each tab as # spaces (e.g. -T6 / --indent=force-tab=6). Uses tabs as indents where ‑‑indent=tab prefers to use spaces, such as inside multi-line statements. # must be between 2 and 20. If no # is set, treats tabs as 4 spaces. |
