发表于 2012-2-28 00:04:27
下面就是出错的情况。。。。
Build target 'Target 1'
compiling 动态12864.c...
linking...
BL51 BANKED LINKER/LOCATER V6.00 - SN: Eval Version
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2005
"动态12864.obj"
TO "动态12864"
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
SEGMENT: ?PR?_DISPLAYPIC?动蘝12864
SEGMENT: ?PR?_DISPLAYCHINESE?动蘝12864
SEGMENT: ?PR?_DISPLAYDIGIT?动蘝12864
SEGMENT: ?PR?_LOCAL?动蘝12864
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 11B6H BYTE (221%) *
Program Size: data=27.0 xdata=0 code=4594
LINK/LOCATE RUN COMPLETE. 4 WARNING(S), 0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
MODULE: F:\KEIL\C51\LIB\C51S.LIB (-----)
LIMIT: 0800H BYTES
Target not created |
