发表于 2012-2-26 15:31:49
/* The cJSON structure: */
typedef struct cJSON {
struct cJSON *next,*prev; /* next/prev allow you to walk array/object chains. Alternatively, use GetArraySize/GetArrayItem/GetObjectItem */
struct cJSON *child; /* An array or object item will have a child pointer pointing to a chain of the items in the array/object. */
int type; /* The type of the item, as above. */
char *valuestring; /* The item's string, if type==cJSON_String */
int valueint; /* The item's number, if type==cJSON_Number */
double valuedouble; /* The item's number, if type==cJSON_Number */
char *string; /* The item's name string, if this item is the child of, or is in the list of subitems of an object. */
} cJSON;
static void *(*cJSON_malloc)(rt_size_t sz) = rt_malloc;
static void (*cJSON_free)(void *ptr) = rt_free;
/* Internal constructor. */
static cJSON *cJSON_New_Item()
cJSON* node = (cJSON*)cJSON_malloc(sizeof(cJSON));
if (node) memset(node,0,sizeof(cJSON));
return node;
/* Delete a cJSON structure. */
void cJSON_Delete(cJSON *c)
cJSON *next;
while (c)
next=c->next;
if (!(c->type&cJSON_IsReference) && c->child) cJSON_Delete(c->child);
if (!(c->type&cJSON_IsReference) && c->valuestring) cJSON_free(c->valuestring);
if (c->string) cJSON_free(c->string);
cJSON_free(c);
c=next;
