回复: 1
多功能密码锁,绝对可用
发表于 2012-2-18 17:01:51 | 显示全部楼层 |阅读模式
#include <reg52.h>
#define uint unsigned int
uchar code table[10] ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar code led[8] = {0,1,2,3,4,5,6,7};
uchar num,second,temp,count,start_flag = 0,reset_flag,keyflag = 0,stop_flag=0,keylock,sounderflag;
sbit start= P3^2;
sbit fu= P3^1;
sbit stop= P3^4;
sbit key1 = P1^0;
sbit key2 = P1^1;
sbit key3 = P1^2;
sbit key4 = P1^3;
sbit key5 = P1^4;
sbit key6 = P1^5;
sbit key7 = P1^6;
sbit key8 = P1^7;
sbit buzzer = P3^5;
void delay(uchar z)
  uchar x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void display(uchar num,uchar second)
  uchar shi,ge;
  shi=second/10;
  ge=second%10;
  P2=led[0];
  P0=table[num];
  delay(2);
  P2=led[6];
  P0=table[shi];
  delay(2);
  P2=led[7];
  P0=table[ge];
  delay(2);
void sounder()
  buzzer=1;
  delay(10);
  buzzer=0;
  delay(10);
  buzzer=1;
  delay(10);
  buzzer=0;
  delay(10);
  buzzer=1;
  delay(10);
  buzzer=0;
  delay(10);
uchar keyscan()
      P1=0xfe;
         temp=P1;
         temp=temp&0xf0;
    while(temp!=0xf0)
           delay(2);
                 temp=P1;
                 temp=temp&0xf0;
                while(temp!=0xf0)
                    keyflag=1;
                    temp=P1;
                         switch(temp)
                           case 0xee: num=1;
                           case 0xde: num=2;
                           case 0xbe: num=3;
                 case 0x7e: num=4;
                         while(temp!=0xf0)
                          temp=P1;
                          temp=temp&0xf0;
    P1=0xfd;
         temp=P1;
         temp=temp&0xf0;
    while(temp!=0xf0)
           delay(2);
                 temp=P1;
                 temp=temp&0xf0;
                while(temp!=0xf0)
               keyflag=1;
                     temp=P1;
                         switch(temp)
                           case 0xed: num=5;
                           case 0xdd: num=6;
                           case 0xbd: num=7;
                 case 0x7d: num=8;
                         while(temp!=0xf0)
                          temp=P1;
                          temp=temp&0xf0;
    P1=0xfb;
         temp=P1;
         temp=temp&0xf0;
    while(temp!=0xf0)
           delay(2);
                 temp=P1;
                 temp=temp&0xf0;
                while(temp!=0xf0)
                   keyflag=1;
                    temp=P1;
                         switch(temp)
                           case 0xeb: num=9;
                           case 0xdb: num=10;
                           case 0xbb: num=11;
                 case 0x7b: num=12;
                         while(temp!=0xf0)
                          temp=P1;
                          temp=temp&0xf0;
    P1=0xf7;
         temp=P1;
         temp=temp&0xf0;
    while(temp!=0xf0)
           delay(2);
                 temp=P1;
                 temp=temp&0xf0;
                while(temp!=0xf0)
               keyflag=1;
                    temp=P1;
                         switch(temp)
                           case 0xe7: num=13;
                           case 0xd7: num=14;
                           case 0xb7: num=15;
                 case 0x77: num=16;
                         while(temp!=0xf0)
                          temp=P1;
                          temp=temp&0xf0;
return num;
void start1()
  if(start==0)
     delay(5);
       if(start==0)
          start_flag=1;
          TR0=1;
void stop1()
    if(stop==0)
     delay(5);
       if(stop==0)
          stop_flag=1;
          TR0=0;
void init()
  start_flag=0;
  stop_flag=0;
  num=0;
  second=20;
  count=0;
  fu=0;
  TMOD=0X01;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  EA=1;
  ET0=1;
  TR0=0;
  P1=0XFF;
void main()
  init();
        stop1();
   start1();
   if((start_flag==1)&&(keyflag==0)&&(stop_flag!=1))
     num=keyscan();
   display(num,second);
        if((num==0)&&(sounderflag==1))
          sounder();
void timer0() interrupt 1
  count++;
  if(count==20)
     count=0;
     if(second!=0)
     second--;
          if(second==5)
           sounderflag=1;
发表于 2012-2-24 12:59:36 | 显示全部楼层
貌似可用,但没有原理图,不适合初学者。
GMT+8, 2024-8-27 04:33
