发表于 2012-2-17 07:17:18
Atmel AVR Studio is the Integrated Development Environment (IDE) for developing and debugging embedded Atmel AVR applications
The AVR Studio® 5.1 editor simplifies code editing and lets you write code more efficiently. It supports all 8- and 32-bit AVR microcontrollers, and connects seamlessly to Atmel AVR debuggers and development kits.
The AVR Studio 5.1 IDE gives you a seamless and easy-to-use environment to write, build, and debug your C/C++ and assembler code.
What's new:
New version of AVR Software Framework (ASF), version 2.11.0
Availability and installation of new ASF versions through extension manager, without having to upgrade Studio 5
Support for side by side versioning of ASF, with the ability to upgrade projects
Syntax highlighting and better debugging support for C++ projects
Support for importing AVR 32 Studio C++ projects
New version of AVR Toolchain, version 3.3.1
New command line utility (atprogram) with support for all Atmel AVR tools and devices
Enhancements to programming dialog including support for ELF programming
New version of Visual Assist with several enhancements and bugfixes
Support for 45 new devices
Learn more
Key Features
Write and debug code for ALL AVR 8- and 32-bit microcontrollers
Support for new devices
AVR Software Framework is an extension
Improved programming dialog
New version of Visual Assist X
New version of AVR Toolchain |
