发表于 2013-4-25 15:35:06
c = 0;
s1 = 0.12;
s2 = 0.099;
for(i = 0; i < 100000; i++)
c += s1*s2;
s1 += 0.0000002f;
OSTimeDly((OS_TICK)1,(OS_OPT)OS_OPT_TIME_DLY,&err); //1S
if(err != OS_ERR_NONE)
return;
任务切换就进入hardfault
; uC/OS-III
; The Real-Time Kernel
; (c) Copyright 2010; Micrium, Inc.; Weston, FL
; All rights reserved. Protected by international copyright laws.
; ARM Cortex-M4 Port
; File : OS_CPU_A.ASM
; Version : V3.01.2
; By : JJL
; BAN
; For : ARMv7 Cortex-M4
; Mode : Thumb-2 ISA
; Toolchain : RealView Development Suite
; RealView Microcontroller Development Kit (MDK)
; ARM Developer Suite (ADS)
; Keil uVision
; PUBLIC FUNCTIONS
IMPORT OSRunning ; External references
IMPORT OSPrioCur
IMPORT OSPrioHighRdy
IMPORT OSTCBCurPtr
IMPORT OSTCBHighRdyPtr
IMPORT OSIntExit
IMPORT OSTaskSwHook
IMPORT OS_CPU_ExceptStkBase
EXPORT OSStartHighRdy ; Functions declared in this file
EXPORT OSCtxSw
EXPORT OSIntCtxSw
EXPORT PendSV_Handler
;PAGE
; EQUATES
NVIC_INT_CTRL EQU 0xE000ED04 ; Interrupt control state register.
NVIC_SYSPRI14 EQU 0xE000ED22 ; System priority register (priority 14).
NVIC_PENDSV_PRI EQU 0xFF ; PendSV priority value (lowest).
NVIC_PENDSVSET EQU 0x10000000 ; Value to trigger PendSV exception.
; CODE GENERATION DIRECTIVES
PRESERVE8
THUMB
AREA CODE, CODE, READONLY
;PAGE
; START MULTITASKING
; void OSStartHighRdy(void)
; Note(s) : 1) This function triggers a PendSV exception (essentially, causes a context switch) to cause
; the first task to start.
; 2) OSStartHighRdy() MUST:
; a) Setup PendSV exception priority to lowest;
; b) Set initial PSP to 0, to tell context switcher this is first run;
; c) Set the main stack to OS_CPU_ExceptStkBase
; d) Trigger PendSV exception;
; e) Enable interrupts (tasks will run with interrupts enabled).
OSStartHighRdy
LDR R0, =NVIC_SYSPRI14 ; Set the PendSV exception priority
LDR R1, =NVIC_PENDSV_PRI
STRB R1, [R0]
MOVS R0, #0 ; Set the PSP to 0 for initial context switch call
MSR PSP, R0
LDR R0, =OS_CPU_ExceptStkBase ; Initialize the MSP to the OS_CPU_ExceptStkBase
LDR R1, [R0]
MSR MSP, R1
LDR R0, =NVIC_INT_CTRL ; Trigger the PendSV exception (causes context switch)
LDR R1, =NVIC_PENDSVSET
STR R1, [R0]
CPSIE I ; Enable interrupts at processor level
OSStartHang
B OSStartHang ; Should never get here
;PAGE
; PERFORM A CONTEXT SWITCH (From task level) - OSCtxSw()
; Note(s) : 1) OSCtxSw() is called when OS wants to perform a task context switch. This function
; triggers the PendSV exception which is where the real work is done.
OSCtxSw
STR R1, [R0]
BX LR
;PAGE
; PERFORM A CONTEXT SWITCH (From interrupt level) - OSIntCtxSw()
; Note(s) : 1) OSIntCtxSw() is called by OSIntExit() when it determines a context switch is needed as
; the result of an interrupt. This function simply triggers a PendSV exception which will
; be handled when there are no more interrupts active and interrupts are enabled.
OSIntCtxSw
STR R1, [R0]
BX LR
;PAGE
; HANDLE PendSV EXCEPTION
; void OS_CPU_PendSVHandler(void)
; Note(s) : 1) PendSV is used to cause a context switch. This is a recommended method for performing
; context switches with Cortex-M3. This is because the Cortex-M3 auto-saves half of the
; processor context on any exception, and restores same on return from exception. So only
; saving of R4-R11 is required and fixing up the stack pointers. Using the PendSV exception
; this way means that context saving and restoring is identical whether it is initiated from
; a thread or occurs due to an interrupt or exception.
; 2) Pseudo-code is:
; a) Get the process SP, if 0 then skip (goto d) the saving part (first context switch);
; b) Save remaining regs r4-r11 on process stack;
; c) Save the process SP in its TCB, OSTCBCurPtr->OSTCBStkPtr = SP;
; d) Call OSTaskSwHook();
; e) Get current high priority, OSPrioCur = OSPrioHighRdy;
; f) Get current ready thread TCB, OSTCBCurPtr = OSTCBHighRdyPtr;
; g) Get new process SP from TCB, SP = OSTCBHighRdyPtr->OSTCBStkPtr;
; h) Restore R4-R11 from new process stack;
; i) Perform exception return which will restore remaining context.
; 3) On entry into PendSV handler:
; a) The following have been saved on the process stack (by processor):
; xPSR, PC, LR, R12, R0-R3
; b) Processor mode is switched to Handler mode (from Thread mode)
; c) Stack is Main stack (switched from Process stack)
; d) OSTCBCurPtr points to the OS_TCB of the task to suspend
; OSTCBHighRdyPtr points to the OS_TCB of the task to resume
; 4) Since PendSV is set to lowest priority in the system (by OSStartHighRdy() above), we
; know that it will only be run when no other exception or interrupt is active, and
; therefore safe to assume that context being switched out was using the process stack (PSP).
PendSV_Handler
CPSID I ; Prevent interruption during context switch
MRS R0, PSP ; PSP is process stack pointer
CBZ R0, OS_CPU_PendSVHandler_nosave ; Skip register save the first time
;Is the task using the FPU context? If so, push high vfp registers.
tst r14, #0x10
it eq
vstmdbeq r0!, {s16-s31}
SUBS R0, R0, #0x20 ; Save remaining regs r4-11 on process stack
STM R0, {R4-R11}
LDR R1, =OSTCBCurPtr ; OSTCBCurPtr->OSTCBStkPtr = SP;
LDR R1, [R1]
STR R0, [R1] ; R0 is SP of process being switched out
; At this point, entire context of process has been saved
PUSH {R14} ; Save LR exc_return value
LDR R0, =OSTaskSwHook ; OSTaskSwHook();
BLX R0
POP {R14}
LDR R0, =OSPrioCur ; OSPrioCur = OSPrioHighRdy;
LDR R1, =OSPrioHighRdy
LDRB R2, [R1]
STRB R2, [R0]
LDR R0, =OSTCBCurPtr ; OSTCBCurPtr = OSTCBHighRdyPtr;
LDR R1, =OSTCBHighRdyPtr
LDR R2, [R1]
STR R2, [R0]
LDR R0, [R2] ; R0 is new process SP; SP = OSTCBHighRdyPtr->StkPtr;
LDM R0, {R4-R11} ; Restore r4-11 from new process stack
ADDS R0, R0, #0x20
;Is the task using the FPU context? If so, pop the high vfp registers too.
tst r14, #0x10
it eq
vldmiaeq r0!, {s16-s31}
MSR PSP, R0 ; Load PSP with new process SP
ORR LR, LR, #0x04 ; Ensure exception return uses process stack
CPSIE I
BX LR ; Exception return will restore remaining context
END
* uC/OS-III
* The Real-Time Kernel
* (c) Copyright 2009-2010; Micrium, Inc.; Weston, FL
* All rights reserved. Protected by international copyright laws.
* ARM Cortex-M4 Port
* File : OS_CPU_C.C
* Version : V3.01.2
* By : JJL
* BAN
* LICENSING TERMS:
* uC/OS-III is provided in source form for FREE short-term evaluation, for educational use or
* for peaceful research. If you plan or intend to use uC/OS-III in a commercial application/
* product then, you need to contact Micrium to properly license uC/OS-III for its use in your
* application/product. We provide ALL the source code for your convenience and to help you
* experience uC/OS-III. The fact that the source is provided does NOT mean that you can use
* it commercially without paying a licensing fee.
* Knowledge of the source code may NOT be used to develop a similar product.
* Please help us continue to provide the embedded community with the finest software available.
* Your honesty is greatly appreciated.
* You can contact us at www.micrium.com, or by phone at +1 (954) 217-2036.
* For : ARMv7 Cortex-M4
* Mode : Thumb-2 ISA
* Toolchain : RealView
#define OS_CPU_GLOBALS
#ifdef VSC_INCLUDE_SOURCE_FILE_NAMES
const CPU_CHAR *os_cpu_c__c = "$Id: $";
/*$PAGE*/
* INCLUDE FILES
#include <os.h>
* IDLE TASK HOOK
* Description: This function is called by the idle task. This hook has been added to allow you to do
* such things as STOP the CPU to conserve power.
* Arguments : None.
* Note(s) : None.
void OSIdleTaskHook (void)
#if OS_CFG_APP_HOOKS_EN > 0u
if (OS_AppIdleTaskHookPtr != (OS_APP_HOOK_VOID)0) {
(*OS_AppIdleTaskHookPtr)();
/*$PAGE*/
* OS INITIALIZATION HOOK
* Description: This function is called by OSInit() at the beginning of OSInit().
* Arguments : None.
* Note(s) : None.
void OSInitHook (void)
/* 8-byte align the ISR stack. */
OS_CPU_ExceptStkBase = (CPU_STK *)(OSCfg_ISRStkBasePtr + OSCfg_ISRStkSize);
OS_CPU_ExceptStkBase = (CPU_STK *)((CPU_STK)(OS_CPU_ExceptStkBase) & 0xFFFFFFF8);
/*$PAGE*/
* STATISTIC TASK HOOK
* Description: This function is called every second by uC/OS-III's statistics task. This allows your
* application to add functionality to the statistics task.
* Arguments : None.
* Note(s) : None.
void OSStatTaskHook (void)
if (OS_AppStatTaskHookPtr != (OS_APP_HOOK_VOID)0) {
(*OS_AppStatTaskHookPtr)();
/*$PAGE*/
* TASK CREATION HOOK
* Description: This function is called when a task is created.
* Arguments : p_tcb Pointer to the task control block of the task being created.
* Note(s) : None.
void OSTaskCreateHook (OS_TCB *p_tcb)
if (OS_AppTaskCreateHookPtr != (OS_APP_HOOK_TCB)0) {
(*OS_AppTaskCreateHookPtr)(p_tcb);
#else
(void)p_tcb; /* Prevent compiler warning */
/*$PAGE*/
* TASK DELETION HOOK
* Description: This function is called when a task is deleted.
* Arguments : p_tcb Pointer to the task control block of the task being deleted.
* Note(s) : None.
void OSTaskDelHook (OS_TCB *p_tcb)
if (OS_AppTaskDelHookPtr != (OS_APP_HOOK_TCB)0) {
(*OS_AppTaskDelHookPtr)(p_tcb);
#else
/*$PAGE*/
* TASK RETURN HOOK
* Description: This function is called if a task accidentally returns. In other words, a task should
* either be an infinite loop or delete itself when done.
* Arguments : p_tcb Pointer to the task control block of the task that is returning.
* Note(s) : None.
void OSTaskReturnHook (OS_TCB *p_tcb)
if (OS_AppTaskReturnHookPtr != (OS_APP_HOOK_TCB)0) {
(*OS_AppTaskReturnHookPtr)(p_tcb);
#else
/*$PAGE*/
* INITIALIZE A TASK'S STACK
* Description: This function is called by OS_Task_Create() or OSTaskCreateExt() to initialize the stack
* frame of the task being created. This function is highly processor specific.
* Arguments : p_task Pointer to the task entry point address.
* p_arg Pointer to a user supplied data area that will be passed to the task
* when the task first executes.
* p_stk_base Pointer to the base address of the stack.
* stk_size Size of the stack, in number of CPU_STK elements.
* opt Options used to alter the behavior of OS_Task_StkInit().
* (see OS.H for OS_TASK_OPT_xxx).
* Returns : Always returns the location of the new top-of-stack' once the processor registers have
* been placed on the stack in the proper order.
* Note(s) : 1) Interrupts are enabled when task starts executing.
* 2) All tasks run in Thread mode, using process stack.
CPU_STK *OSTaskStkInit (OS_TASK_PTR p_task,
void *p_arg,
CPU_STK *p_stk_base,
CPU_STK *p_stk_limit,
CPU_STK_SIZE stk_size,
OS_OPT opt)
CPU_STK *p_stk;
(void)opt; /* Prevent compiler warning */
p_stk = &p_stk_base[stk_size]; /* Load stack pointer */
/* Align the stack to 8-bytes. */
p_stk = (CPU_STK *)((CPU_STK)(p_stk) & 0xFFFFFFF8);
/* Registers stacked as if auto-saved on exception */
#if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
*--p_stk = (CPU_STK)0x00000000u; /* No Name Register */
*--p_stk = (CPU_STK)0x00001000L; //FPSCR
*--p_stk = (CPU_STK)0x00000015L; //s15
*--p_stk = (CPU_STK)0x00000014L; //s14
*--p_stk = (CPU_STK)0x00000013L; //s13
*--p_stk = (CPU_STK)0x00000012L; //s12
*--p_stk = (CPU_STK)0x00000011L; //s11
*--p_stk = (CPU_STK)0x00000010L; //s10
*--p_stk = (CPU_STK)0x00000009L; //s9
*--p_stk = (CPU_STK)0x00000008L; //s8
*--p_stk = (CPU_STK)0x00000007L; //s7
*--p_stk = (CPU_STK)0x00000006L; //s6
*--p_stk = (CPU_STK)0x00000005L; //s5
*--p_stk = (CPU_STK)0x00000004L; //s4
*--p_stk = (CPU_STK)0x00000003L; //s3
*--p_stk = (CPU_STK)0x00000002L; //s2
*--p_stk = (CPU_STK)0x00000001L; //s1
*--p_stk = (CPU_STK)0x00000000L; //s0
*--p_stk = (CPU_STK)0x01000000u; /* xPSR */
*--p_stk = (CPU_STK)p_task; /* Entry Point */
*--p_stk = (CPU_STK)OS_TaskReturn; /* R14 (LR) */
*--p_stk = (CPU_STK)0x12121212u; /* R12 */
*--p_stk = (CPU_STK)0x03030303u; /* R3 */
*--p_stk = (CPU_STK)0x02020202u; /* R2 */
*--p_stk = (CPU_STK)p_stk_limit; /* R1 */
*--p_stk = (CPU_STK)p_arg; /* R0 : argument */
/* Remaining registers saved on process stack */
*--p_stk = (CPU_STK)0x31313131u; /* S31 */
*--p_stk = (CPU_STK)0x30303030u; /* S30 */
*--p_stk = (CPU_STK)0x29292929u; /* S29 */
*--p_stk = (CPU_STK)0x28282828u; /* S28 */
*--p_stk = (CPU_STK)0x27272727u; /* S27 */
*--p_stk = (CPU_STK)0x26262626u; /* S26 */
*--p_stk = (CPU_STK)0x25252525u; /* S25 */
*--p_stk = (CPU_STK)0x24242424u; /* S24 */
*--p_stk = (CPU_STK)0x23232323u; /* S23 */
*--p_stk = (CPU_STK)0x22222222u; /* S22 */
*--p_stk = (CPU_STK)0x21212121u; /* S21 */
*--p_stk = (CPU_STK)0x20202020u; /* S20 */
*--p_stk = (CPU_STK)0x19191919u; /* S19 */
*--p_stk = (CPU_STK)0x18181818u; /* S18 */
*--p_stk = (CPU_STK)0x17171717u; /* S17 */
*--p_stk = (CPU_STK)0x16161616u; /* S16 */
*--p_stk = (CPU_STK)0x11111111u; /* R11 */
*--p_stk = (CPU_STK)0x10101010u; /* R10 */
*--p_stk = (CPU_STK)0x09090909u; /* R9 */
*--p_stk = (CPU_STK)0x08080808u; /* R8 */
*--p_stk = (CPU_STK)0x07070707u; /* R7 */
*--p_stk = (CPU_STK)0x06060606u; /* R6 */
*--p_stk = (CPU_STK)0x05050505u; /* R5 */
*--p_stk = (CPU_STK)0x04040404u; /* R4 */
return (p_stk);
/*$PAGE*/
* TASK SWITCH HOOK
* Description: This function is called when a task switch is performed. This allows you to perform other
* operations during a context switch.
* Arguments : None.
* Note(s) : 1) Interrupts are disabled during this call.
* 2) It is assumed that the global pointer 'OSTCBHighRdyPtr' points to the TCB of the task
* that will be 'switched in' (i.e. the highest priority task) and, 'OSTCBCurPtr' points
* to the task being switched out (i.e. the preempted task).
void OSTaskSwHook (void)
#if OS_CFG_TASK_PROFILE_EN > 0u
CPU_TS ts;
#ifdef CPU_CFG_INT_DIS_MEAS_EN
CPU_TS int_dis_time;
if (OS_AppTaskSwHookPtr != (OS_APP_HOOK_VOID)0) {
(*OS_AppTaskSwHookPtr)();
ts = OS_TS_GET();
if (OSTCBCurPtr != OSTCBHighRdyPtr) {
OSTCBCurPtr->CyclesDelta = ts - OSTCBCurPtr->CyclesStart;
OSTCBCurPtr->CyclesTotal += (OS_CYCLES)OSTCBCurPtr->CyclesDelta;
OSTCBHighRdyPtr->CyclesStart = ts;
int_dis_time = CPU_IntDisMeasMaxCurReset(); /* Keep track of per-task interrupt disable time */
if (OSTCBCurPtr->IntDisTimeMax < int_dis_time) {
OSTCBCurPtr->IntDisTimeMax = int_dis_time;
#if OS_CFG_SCHED_LOCK_TIME_MEAS_EN > 0u
/* Keep track of per-task scheduler lock time */
if (OSTCBCurPtr->SchedLockTimeMax < OSSchedLockTimeMaxCur) {
OSTCBCurPtr->SchedLockTimeMax = OSSchedLockTimeMaxCur;
OSSchedLockTimeMaxCur = (CPU_TS)0; /* Reset the per-task value */
/*$PAGE*/
* TICK HOOK
* Description: This function is called every tick.
* Arguments : None.
* Note(s) : 1) This function is assumed to be called from the Tick ISR.
void OSTimeTickHook (void)
if (OS_AppTimeTickHookPtr != (OS_APP_HOOK_VOID)0) {
(*OS_AppTimeTickHookPtr)();
/*$PAGE*/
* SYS TICK HANDLER
* Description: Handle the system tick (SysTick) interrupt, which is used to generate the uC/OS-II tick
* interrupt.
* Arguments : None.
* Note(s) : 1) This function MUST be placed on entry 15 of the Cortex-M3 vector table.
void OS_CPU_SysTickHandler (void)
CPU_SR_ALLOC();
CPU_CRITICAL_ENTER();
OSIntNestingCtr++; /* Tell uC/OS-III that we are starting an ISR */
CPU_CRITICAL_EXIT();
OSTimeTick(); /* Call uC/OS-III's OSTimeTick() */
OSIntExit(); /* Tell uC/OS-III that we are leaving the ISR */
/*$PAGE*/
* INITIALIZE SYS TICK
* Description: Initialize the SysTick.
* Arguments : cnts Number of SysTick counts between two OS tick interrupts.
* Note(s) : 1) This function MUST be called after OSStart() & after processor initialization.
void OS_CPU_SysTickInit (CPU_INT32U cnts)
CPU_INT32U prio;
CPU_REG_NVIC_ST_RELOAD = cnts - 1u;
/* Set SysTick handler prio. */
prio = CPU_REG_NVIC_SHPRI3;
prio &= DEF_BIT_FIELD(24, 0);
prio |= DEF_BIT_MASK(OS_CPU_CFG_SYSTICK_PRIO, 24);
CPU_REG_NVIC_SHPRI3 = prio;
/* Enable timer. */
CPU_REG_NVIC_ST_CTRL |= CPU_REG_NVIC_ST_CTRL_CLKSOURCE |
CPU_REG_NVIC_ST_CTRL_ENABLE;
/* Enable timer interrupt. */
CPU_REG_NVIC_ST_CTRL |= CPU_REG_NVIC_ST_CTRL_TICKINT;
