//======头文件=====//
#ifndef _PS2_H
#define _PS2_H
#define PS2_CLK PTJ_PTJ1
#define PS2_RW PORTA_PA1
typedef struct PS2_ValueType {
char PS2_ValueData; /* 码表
Num :77 /:E04A *:7C -:7B
7: 6C 8:75 9:7D +:79
4: 6B 5:73 6:74 +:79
1: 69 2:72 3:7A Enter:E05A
0: 70 .:71
/* 对应返回值
Num :-5 /:-4 *:7C -:-2
7: 7 8:8 9:9 +:-1
4: 4 5:5 6:6 +:-1
1: 1 2:2 3:3 Enter:10
0: 0 .:-3 空格 -6
unsigned char PS2_ValueKind; //0 按下,1松手
}PS2_ValueType;
#endif _PS2_H
//==============================C文件===================//
#include "PS2.h"
#include "MC9S12XS128.h"
//extern unsigned char PS2_Buffer[3];
//extern unsigned char PS2_StopCodeFlag=0;
//从PS/2中获取一个按键
unsigned char PS2_GetData(void)
unsigned char temp,i,res;
for(i=0;i<11;i++) {
while(PS2_CLK);
if(i>0 && i<9) {
res=res>>1;
if(PS2_RW) {
res=res|0x80;
while (!PS2_CLK);
return res;
void Key_Interrupt(void) {
//DDRJ=0X00;
PIEJ_PIEJ1=1;
PPSJ_PPSJ1=0;
void PS2_InsertBuffer(unsigned char *buffer,unsigned char bufferdata)
unsigned char *tempdata=buffer+1;
(*buffer++)=(*tempdata++);
(*buffer++)=(*buffer++);
(*buffer)=bufferdata;
void PS2_GetChar(PS2_ValueType *PS2_Value)
unsigned char temp;
temp=PS2_GetData();
(*PS2_Value).PS2_ValueKind=0;
if(temp!=0xe0 && temp!=0xf0)
switch (temp)
/* 对应返回值
Num :-6 /:-4 *:-5 -:-2
7: 7 8:8 9:9 +:-1
4: 4 5:5 6:6 +:-1
0: 0 .:-3
case 0x70 : (*PS2_Value).PS2_ValueData=0; return;
case 0x69 : (*PS2_Value).PS2_ValueData=1; return;
case 0x72 : (*PS2_Value).PS2_ValueData=2; return;
case 0x7A : (*PS2_Value).PS2_ValueData=3; return;
case 0x6B : (*PS2_Value).PS2_ValueData=4; return;
case 0x73 : (*PS2_Value).PS2_ValueData=5; return;
case 0x74 : (*PS2_Value).PS2_ValueData=6; return;
case 0x6C : (*PS2_Value).PS2_ValueData=7; return;
case 0x75 : (*PS2_Value).PS2_ValueData=8; return;
case 0x7D : (*PS2_Value).PS2_ValueData=9; return;
case 0x71 : (*PS2_Value).PS2_ValueData=-3; return;
case 0x79 : (*PS2_Value).PS2_ValueData=-1; return;
case 0x7B : (*PS2_Value).PS2_ValueData=-2; return;
case 0x7C : (*PS2_Value).PS2_ValueData=-5; return;
case 0x77 : (*PS2_Value).PS2_ValueData=-6; return;
case 0x66 : (*PS2_Value).PS2_ValueData=-7; return;
else if(temp==0xe0)
temp=PS2_GetData();
if(temp==0xf0)
temp=PS2_GetData();
(*PS2_Value).PS2_ValueKind=1;
if(temp==0x5A)
(*PS2_Value).PS2_ValueData=10; return;
else if(temp==0x4A)
(*PS2_Value).PS2_ValueData=-4; return;
if(temp==0x5A)
else if(temp==0x4A)
else if (temp==0xf0)
temp=PS2_GetData();
switch (temp)
/* 对应返回值
7: 7 8:8 9:9 +:-1
4: 4 5:5 6:6 +:-1
0: 0 .:-3 空格 -7
点击此处下载 ourdev_716935F63Z4Y.rar(文件大小:1K) (原文件名:PS2.rar) |
