在网上找资料绝大多数资料都是移植到51上,没有找到到关于移植到430用IAR编译的资料,我菜鸟第一次移植程序,希望大侠们多指点,我将uip\uip.c, uip.c\uip.h, uip.c\uip_arch.h, uip.c\uip_arp.c,uip.c\uip_arp.h , unix\main.c, unix\uip_arch.c, unix\uipopt.h,apps\httpd\所有文件添加到IAR工程里,
且修改了:1、fsdata.h 文件末尾添加:
#define FS_ROOT file_tcp_header_html
#define FS_NUMFILES 14
static const char data_cgi_files[];
static const char data_cgi_stats[];
static const char data_cgi_tcp[];
static const char data_img_bg_png[];
static const char data_about_html[];
static const char data_control_html[];
static const char data_404_html[];
static const char data_files_footer_plain[];
static const char data_files_header_html[];
static const char data_index_html[];
static const char data_stats_footer_plain[];
static const char data_stats_header_html[];
static const char data_tcp_footer_plain[];
static const char data_tcp_header_html[];
const struct fsdata_file file_cgi_files[];
const struct fsdata_file file_cgi_stats[];
const struct fsdata_file file_cgi_tcp[];
const struct fsdata_file file_img_bg_png[];
const struct fsdata_file file_about_html[];
const struct fsdata_file file_control_html[];
const struct fsdata_file file_404_html[];
const struct fsdata_file file_files_footer_plain[];
const struct fsdata_file file_files_header_html[];
const struct fsdata_file file_index_html[];
const struct fsdata_file file_stats_footer_plain[];
const struct fsdata_file file_stats_header_html[];
const struct fsdata_file file_tcp_footer_plain[];
const struct fsdata_file file_tcp_header_html[];
2、 fs.c 第55行删除: #include "fsdata.c"
3、uipopt.h
181行: #define UIP_FIXEDETHADDR 0 -> 1:
299行: #define UIP_ACTIVE_OPEN 1 ->04 、
497行: #define BYTE_ORDER LITTLE_ENDIAN -> BIG_ENDIAN' 、
280行: #define UIP_UDP_APPCALL udp_appcall -> httpd_appcall
文件末尾添加:
#ifndef NULL
#define NULL (void *)0.
#endif /* NULL */
4、 httpd.c
删除以下内容:
extern const struct fsdata_file file_index_html;
extern const struct fsdata_file file_404_html;
220行更改
fs_open(file_index_html.name, &fsfile); => file_index_html->name
224行同上更改
网卡驱动程序还没有写呢,编译的时候出现这个问题Error[e27]: Entry "file_404_html" in module fs ( F:\SongYH\My Work content\uip-0.9\IAR-uip0.9-1\Debug\Obj\fs.r43 ) redefined in module fsdata ( F:\
SongYH\My Work content\uip-0.9\IAR-uip0.9-1\Debug\Obj\fsdata.r43 )
这个问题是出现在FS.c和fsdata.c中,但是我不知道是什么问题,希望各位指点一下小弟啊,谢谢了 |
