发表于 2012-1-31 22:48:20
网上找到个说明书,颇为简单:点击此处下载 ourdev_715310IGYNY3.pdf(文件大小:888K) (原文件名:Manual-sprint-15min-4position-rc103814.pdf)
灯有4种状态,说明用蓝色标记了:
INSTRUCTIONS FOR USE
• For the 4-position charger:
- Connect the A/C adapter jack to the socket located on the rear of
the charger.
- Connect the adapter cord to a wall socket
• For the 2-position charger:
- Connect the charger directly to a wall socket, using the power supply
cable
• The "UNIROSS" logo should be illuminated in red.
• Place the rechargeable AA or AAA Ni-MH batteries in the
compartment on the charger.
• Only insert the same type of battery for charging together.
• Check that the positive pole (+) on the battery is in contact with the
charger's sliding metal strip. Press the negative pole on the battery
until it touches the base of the compartment.
• The charger then automatically adjusts the required charge current
depending on the battery format detected. The indicator light for the
battery compartment flashes rapidly, indicating that the charge
process is underway. The cooling fan is started automatically.
• If the indicator light does not come on, the battery is not suitable for
charging.
• When the battery is recharged, a maintenance charge is automatically
triggered to keep the power level in the battery at its maximum, and
the status indicator flashes slowly. You can remove the battery at any
time when this maintenance charge is being supplied.
• When the flashing stops and the indicator stays lit, the charge is
complete.
• Once the batteries have been fully charged, it is recommended to
leave them in the charger for a further 15 min. minimum before
removing them.
• If the charger is no longer to be used, disconnect it and remove the batteries.
回复【15楼】rainyuoko
老大最讨厌这种要注_册才能下附件的网站了,以后最好把附件贴过来吧。 |
