发表于 2012-1-10 10:34:04
回复【楼主位】laokongzhuang
一下是我在一个网站上找到的,供大家参考一下:
问题:
“I posted this in the Newbie forum, but I am afraid that I may not get a response there. So i'll try here.
Anyone had any luck updating redhat 9. I have been trying every weekend for the past 3 weeks to get it going and no dice. I keep getting errors at make install:
No mptbase found for kernel 2.6.X <- 9 and 8.1
No buslogic found blah blah blah
I have tried following a few different online tutorials, but of course with no luck. I have gotten rid of the buslogic error but no matter what I do I get the darn mptbase error. Any ideas about what configuration setting are linked with fusion mpt?
Thanks in advance!”
解决方案:
prob solved
Case anyone else is in the same boat, I fugured out how to fix the problem.
make bzImage
make modules
make modules_install
cd /etc
edit modules.conf removing alias scsi mptbase and alias scsi mptxxxx <- cant remeber the name
edit modprobe.conf angain removing any reference of mpt anything
cd linux-2.6.x
make install
cd boot/grub
edit grub.conf removing "ro root=LABEL" <- this is not exact either it may be "ro root=/LABEL" or something like it.
Late,
Scotoma |
