发表于 2011-12-7 13:37:34
回复【12楼】kamingli
/* proprietary */
#if defined (hal_pa_lna)
19, /* phytransmitpower for cc2591 */
#elif defined (hal_pa_lna_cc2590)
11, /* phytransmitpower for cc2590 */
#else
0,
19 应该是最大的了. 那就看看发射电流吧.
#if defined HAL_PA_LNA || defined MAC_RUNTIME_CC2591
const uint8 CODE macRadioDefsTxPwrCC2591[] =
20, /* tramsmit power level of the first entry */
(uint8)(int8)10, /* transmit power level of the last entry */
/* 20 dBm */ 0xE5, /* characterized as 20 dBm in datasheet */
/* 19 dBm */ 0xD5, /* characterized as 19 dBm in datasheet */
/* 18 dBm */ 0xC5, /* characterized as 18 dBm in datasheet */
/* 17 dBm */ 0xB5, /* characterized as 17 dBm in datasheet */
/* 16 dBm */ 0xA5, /* characterized as 16 dBm in datasheet */
/* 15 dBm */ 0xA5,
/* 14 dBm */ 0x95, /* characterized as 14.5 dBm in datasheet */
/* 13 dBm */ 0x85, /* characterized as 13 dBm in datasheet */
/* 12 dBm */ 0x85,
/* 11 dBm */ 0x75, /* characterized as 11.5 dBm in datasheet */
/* 10 dBm */ 0x65 /* characterized as 10 dBm in datasheet */
#endif |
