发表于 2011-11-30 21:25:46
LZ主要是想问第二点,“一个geber文件怎么把钻孔的数据都包含进去了”吧?
我之前一个反响寥寥的帖里,也有此困惑
http://www.ourdev.cn/bbs/bbs_content.jsp?bbs_sn=5045316&bbs_page_no=1&search_mode=3&search_text=reflecter&bbs_id=9999
热心网友chunk在7楼及9楼,均给出的很好的答复。
http://www.apcircuits.com/resources/information/nc_codes.html 里给出了ASCII(也就是说,可以用记事本打开你的drill文件)格式的钻孔文件的描述
Computer Numerical Control for Drillers and Routers
% Rewind and Stop
X#Y# Move and Drill
T# Tool Selection
M30 End of Program
M00 End of Program
M25 Beginning of Pattern
M31 Beginning of Pattern
M01 End of Pattern
M02 X#Y# Repeat Pattern
R#M02X#Y# Multiple Repeat Pattern
M02 X#Y# M70 Swap Axis
M02 X#Y# M80 Mirror Image X Axis
M02 X#Y# M90 Mirror Image Y Axis
M08 End of Step and Repeat
N# Block Sequence Number
/ Block Delete
R#X#Y# Repeat Hole
G05, G81 Select Drill Mode
G04 X# Variable Dwell (ignored)
G90 Absolute Mode
G91 Incremental Mode
G92 X#Y# Set Zero
G93 X#Y# Set Zero
M48 Program Header to first "%"
M47 Operator Message CRT Display
M71 Metric Mode
M72 English-Imperial Mode
Snn Spindle Speed (RPM)
Fnn Z axis feed speed (IPM)
于是我在楼主位,给出的N.C.Drill是不能被数控机床及viewMate之类看Gerber的软件识别的 |
