DMA_InitTypeDef DMA_InitStructure;
// __IO uint32_t Timeout = TIMEOUT_MAX;
/* Enable DMA clock */
RCC_AHB1PeriphClockCmd(DMA_STREAM_CLOCK, ENABLE);
// RCC_AHB1PeriphResetCmd(RCC_AHB1Periph_DMA2, ENABLE);
/* Reset DMA Stream registers (for debug purpose) */
DMA_DeInit(DMA_STREAM);
/* Check if the DMA Stream is disabled before enabling it.
Note that this step is useful when the same Stream is used multiple times:
enabled, then disabled then re-enabled... In this case, the DMA Stream disable
will be effective only at the end of the ongoing data transfer and it will
not be possible to re-configure it before making sure that the Enable bit
has been cleared by hardware. If the Stream is used only once, this step might
be bypassed. */
while (DMA_GetCmdStatus(DMA_STREAM) != DISABLE)
/* Configure DMA Stream */
DMA_InitStructure.DMA_Channel = DMA_CHANNEL;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SPI1_DR_Address;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)LCDBuffer;
DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
DMA_InitStructure.DMA_BufferSize = (uint32_t)COLUMN_NUM-4;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA_STREAM, &DMA_InitStructure);
/* DMA Stream enable */
DMA_Cmd(DMA_STREAM, ENABLE);
while(DMA_GetCmdStatus(DMA_STREAM)!=ENABLE); //就在这停了
之前用spi的时候是使能dma成功,并且进入中断了,但是在中断中关dma,然后出了中断后执行
while(DMA_GetCmdStatus(DMA_STREAM)==ENABLE){}时停下了,我的学习就卡在这里了,串口和spi都是调好了的,能成功发送数据,就是在dma这卡住的。
请大家帮帮忙啊 |
