最近下载安装了spb16.5的win版,但是没有linux版,
昨晚在看那个破_解包内的说明文件,看到关于pubkey,好像还是比较旧的
原文如下:Generic ECC pubkey replacer by tanker, v1.30, 2009-10-11
2009-10-11 v1.30
Add new option: -f
-f force replace pubkey whateven the tool found with the default public key;
-y say "Yes" to replace, only files have the same pubkey with the first file will be replaced.
2009-10-10 v1.20
Fix bug when searching for pubkey
2009-10-07 v1.10
Support Win32(Can replace pubkey in modelsim & cdslmd.exe)
2009-10-06 v1.00
Add more search patten;
Test with Magma talus;
Add sample license files.
2009-10-06 v0.99
Initial release.
This is a generic ECC pubkey replacer, it will replace target application's ECC public key with a known one.
Then you can use a known ECC private key generate a valid license.
Feature:
1. Replace public key in target application, only modify data segment, not code segment;
2. Buy replacing public key in vendor daemon, you can start floating license(test in cdslmd);
3. Support linux x32 & x64 ELF files, including execution files and libraries.
Usage:
1. Copy the pubkey file to your linux box, in the application directory.
2. Run the "pubkey -d xxx", xxx is the vendor name, for example, pubkey -d cdslmd. The replacer will search public key in files.
3. If ok(sometimes some files can't find pubkey), add "-y" to command line, like pubkey -d cdslmd -y. The replacer will replace all public it found in files.
4. In Windows, run the license generator with a known private key, like lmcrypt_cdslmd.exe. lmcrypt_cdslmd -i xxx.dat -o yyy.dat
5. Copy the new generated license file(yyy.dat) to your linux box, and have fun!
Note:
1. Only support 239bit ECC now, so you must use a 120-char SIGN or SING2;
2. If you want to modify only one file, just run "pubkey -d xxx -y filename"
再直接打开pubkey1.30.exe,这个文件,好像也是引用pubkey这个文件的
那么是否应该就是linux下直接使用pubkey就可以破_解spb16.5?
谁清楚其中的破_解的话,可以尝试一下啊,呵呵
ps:谁有linux的SPB16.5的下载地址啊??? |
