回复【楼主位】qqq511153186
#include <reg52.h>
#define uint unsigned int
sbit RS=P1^0;
sbit RW=P1^1;
sbit E =P1^2;
sbit cs=P1^3;
sbit wr=P1^4;
sbit keyu=P1^5;
sbit keyd=P1^6;
uchar code table[]="Kind: val: 5VFreq: HZ";
uchar code table1[]="Fan JuSanSin";
uchar code sin[]={
0x80,0x83,0x86,0x89,0x8D,0x90,0x93,0x96,0x99,0x9C,0x9F,
0xA2,0xA5,0xA8,0xAB,0xAE,0xB1,0xB4,0xB7,0xBA,0xBC,0xBF,0xC2,0xC5,0xC7,
0xCA,0xCC,0xCF,0xD1,0xD4,0xD6,0xD8,0xDA,0xDD,0xDF,0xE1,0xE3,0xE5,0xE7,
0xE9,0xEA,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,
0xFB,0xFC,0xFD,0xFD,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFE,0xFD,0xFD,0xFC,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6,0xF5,
0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEA,0xE9,0xE7,0xE5,0xE3,0xE1,0xDF,0xDD,
0xDA,0xD8,0xD6,0xD4,0xD1,0xCF,0xCC,0xCA,0xC7,0xC5,0xC2,0xBF,0xBC,0xBA,
0xB7,0xB4,0xB1,0xAE,0xAB,0xA8,0xA5,0xA2,0x9F,0x9C,0x99,0x96,0x93,0x90,
0x8D,0x89,0x86,0x83,0x80,0x80,0x7C,0x79,0x76,0x72,0x6F,0x6C,0x69,0x66,
0x63,0x60,0x5D,0x5A,0x57,0x55,0x51,0x4E,0x4C,0x48,0x45,0x43,0x40,0x3D,
0x3A,0x38,0x35,0x33,0x30,0x2E,0x2B,0x29,0x27,0x25,0x22,0x20,0x1E,0x1C,
0x1A,0x18,0x16,0x15,0x13,0x11,0x10,0x0E,0x0D,0x0B,0x0A,0x09,0x08,0x07,
0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,
0x09,0x0A,0x0B,0x0D,0x0E,0x10,0x11,0x13,0x15,0x16,0x18,0x1A,0x1C,0x1E,
0x20,0x22,0x25,0x27,0x29,0x2B,0x2E,0x30,0x33,0x35,0x38,0x3A,0x3D,0x40,
0x43,0x45,0x48,0x4C,0x4E,0x51,0x55,0x57,0x5A,0x5D,0x60,0x63,0x66,0x69,
0x6C,0x6F,0x72,0x76,0x79,0x7C,0x80 };
void write_com(uchar com);
uchar key=0;
uchar qian,bai,ge,shi,rate=1;
uint Y;
void delayms(uint j)
uchar i;
for(;j>0;j--)
for(i=110;i>0;i--);
void init()
TMOD=0x01;
TH0=(65536-3922/rate)/256;
TL0=(65536-3922/rate)%256;
EA=1;
ET0=1;
TR0=1;
IT0=1;
EX0=1;
cs=0;
wr=0;
write_com(0x0c);
write_com(0x01);
write_com(0x38);
write_com(0x06);
RS=0;
RW=0;
E=0;
P2=com;
delayms(1);
E=1;
delayms(1);
E=0;
void write_date(uchar date)
RS=1;
RW=0;
E=0;
P2=date;
delayms(1);
E=1;
delayms(1);
E=0;
void display()
{ uchar i;
write_com(0x80);
for(i=0;i<16;i++)
write_date(table);
// write_com(0x80+0x40);
// for(i=16;i<26;i++)
// write_date(table);
void write_f()//显示频率
qian=rate/1000;
bai=rate%1000/100;
shi=rate%1000%100/10;
ge=rate%1000%100%10;
write_com(0x80+0x40);//第4格开始显示
write_date(0x30+qian);
write_date(0x30+bai);
write_date(0x30+shi);
write_date(0x30+ge);
void scan()
if(keyu==0)
delayms(5);
if(keyu==0)
while(!keyu);
rate++;
uchar j;
init();
display();
{ scan();
switch(key)
case 3:
write_com(0x80+5);
for(j=0;j<3;j++)
write_date(table1[j]);
write_f();
case 1:
write_com(0x80+5);
for(j=3;j<6;j++)
case 2:
write_com(0x80+5);
for(j=6;j<9;j++)
case 0:
write_com(0x80+5);
for(j=9;j<12;j++)
write_f();
/***************SWITCH结束**************/
/***************外中断0扫描按键**************/
void key_press()interrupt 0
key++;
if(key==4)key=0;
void timer() interrupt 1
uchar i,dir;
TR0=0;
switch(key)
/***************矩形波*******************/
case 3:
P0=0XFF;
delayms(2300-Y);
P0=0;
delayms(2300-Y);
/***************锯齿波*******************/
case 1:
P0=i;
i++;
/***************三角波*******************/
case 2:
P0=i;
delayms(3000);
if(!dir)i++;else i--;
if(i==255||i==0)dir=!dir;
/***************正弦波*******************/
case 0:
P0=sin;
i++;
TR0=1;
