// MSP430x24x Demo - USCI_A0, Ultra-Low Pwr UART 9600 RX/TX, 32kHz ACLK
// Description: This program demonstrates a full-duplex 9600-baud UART using
// USCI_A0 and a 32kHz crystal. The program will wait in LPM3, and receive
// a string1 into RAM, and echo back the complete string.
// ACLK = BRCLK = LFXT1 = 32768Hz, MCLK = SMCLK = DCO ~1.045Mhz
// Baud rate divider with 32768Hz XTAL @9600 = 32768Hz/9600 = 3.41
// //* An external watch crystal is required on XIN XOUT for ACLK *//
// MSP430F249
// /|\| XIN|-
// | | | 32kHz
// --|RST XOUT|-
// | P3.4/UCA0TXD|------------>
// | | 9600 - 8N1
// | P3.5/UCA0RXD|<------------
// B. Nisarga
// Texas Instruments Inc.
// September 2007
// Built with IAR Embedded Workbench Version: 3.42A
#include "msp430x24x.h"
char string1[8];
char i;
char j = 0;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P1DIR = 0xFF; // All P1.x outputs
P1OUT = 0; // All P1.x reset
P2DIR = 0xFF; // All P2.x outputs
P2OUT = 0; // All P2.x reset
P3SEL = 0x30; // P3.4,5 = USCI_A0 TXD/RXD
P3DIR = 0xFF; // All P3.x outputs
P3OUT = 0; // All P3.x reset
P4DIR = 0xFF; // All P4.x outputs
P4OUT = 0; // All P4.x reset
UCA0CTL1 |= UCSSEL_1; // CLK = ACLK
UCA0BR0 = 0x03; // 32kHz/9600 = 3.41
UCA0BR1 = 0x00; //
UCA0MCTL = UCBRS1 + UCBRS0; // Modulation UCBRSx = 3
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
__bis_SR_register(LPM3_bits + GIE); // Enter LPM3, interrupts enabled
// USCI A0/B0 Transmit ISR
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
UCA0TXBUF = string1[i++]; // TX next character
if (i == sizeof string1) // TX over?
IE2 &= ~UCA0TXIE; // Disable USCI_A0 TX interrupt
// USCI A0/B0 Receive ISR
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
string1[j++] = UCA0RXBUF;
if (j > sizeof string1 - 1)
i = 0;
j = 0;
IE2 |= UCA0TXIE; // Enable USCI_A0 TX interrupt
我分析的 格式 odd,8,1,9600
程序说的是 发什么 接收窗显示什么 端口号 我绝对没有错
我的错误状况是
发送任意字符串后 接收在字节数在自加 接手区无显示 (非十六进制显示)
接收在字节数在自加 接收到若干 00 (十六进制显示)
求教 我哪里出了问题! |
