发表于 2011-11-4 15:53:03
回复【2楼】kanprin
把配置文件发上来看看
谢谢关注!是lwipopts.h文件吗?opt.h没改,下面是lwipopts.h
#ifndef __LWIPOPTS_H__
#define __LWIPOPTS_H__
//#include "ucos_ii.h"
#define LWIP_DEBUG 1
#define DEFAULT_THREAD_STACKSIZE LWIP_STK_SIZE
#define SLIPIF_THREAD_STACKSIZE LWIP_STK_SIZE
#define PPP_THREAD_STACKSIZE LWIP_STK_SIZE
#define LWIP_HTTPD_SSI 1
#define LWIP_HTTPD_CGI 1
#define LWIP_HTTPD_DYNAMIC_HEADERS 1
#define LWIP_HTTPD_MAX_TAG_NAME_LEN 8
#define TCP_LISTEN_BACKLOG 1
#define ETHARP_TRUST_IP_MAC 1
/*----------------Thread Priority---------------------------------------------*/
#define TCPIP_THREAD_PRIO LWIP_TASK_START_PRIO+1
#define DEFAULT_THREAD_PRIO LWIP_TASK_START_PRIO+2
#define PING_THREAD_PRIO LWIP_TASK_START_PRIO+3
#define HTTPSERVER_THREAD_PRIO LWIP_TASK_START_PRIO+4
* SYS_LIGHTWEIGHT_PROT==1: if you want inter-task protection for certain
* critical regions during buffer allocation, deallocation and memory
* allocation and deallocation.
#define SYS_LIGHTWEIGHT_PROT 0
* NO_SYS==1: Provides VERY minimal functionality. Otherwise,
* use lwIP facilities.
#define NO_SYS 0
/* ---------- Memory options ---------- */
/* MEM_ALIGNMENT: should be set to the alignment of the CPU for which
lwIP is compiled. 4 byte alignment -> define MEM_ALIGNMENT to 4, 2
byte alignment -> define MEM_ALIGNMENT to 2. */
#undef MEM_ALIGNMENT
#define MEM_ALIGNMENT 4
/* MEM_SIZE: the size of the heap memory. If the application will send
a lot of data that needs to be copied, this should be set high. */
#undef MEM_SIZE
#define MEM_SIZE (1600)
/* MEMP_NUM_PBUF: the number of memp struct pbufs. If the application
sends a lot of data out of ROM (or other static memory), this
#undef MEMP_NUM_PBUF
#define MEMP_NUM_PBUF 10
/* MEMP_NUM_UDP_PCB: the number of UDP protocol control blocks. One
per active UDP "connection". */
#undef MEMP_NUM_UDP_PCB
#define MEMP_NUM_UDP_PCB 6
/* MEMP_NUM_TCP_PCB: the number of simulatenously active TCP
connections. */
#undef MEMP_NUM_TCP_PCB
#define MEMP_NUM_TCP_PCB 10
/* MEMP_NUM_TCP_PCB_LISTEN: the number of listening TCP
connections. */
#undef MEMP_NUM_TCP_PCB_LISTEN
#define MEMP_NUM_TCP_PCB_LISTEN 6
/* MEMP_NUM_TCP_SEG: the number of simultaneously queued TCP
segments. */
#undef MEMP_NUM_TCP_SEG
#define MEMP_NUM_TCP_SEG 12
/* MEMP_NUM_SYS_TIMEOUT: the number of simulateously active
timeouts. */
#define MEMP_NUM_SYS_TIMEOUT 10
/* ---------- Pbuf options ---------- */
/* PBUF_POOL_SIZE: the number of buffers in the pbuf pool. */
#undef PBUF_POOL_SIZE
#define PBUF_POOL_SIZE 10
/* PBUF_POOL_BUFSIZE: the size of each pbuf in the pbuf pool. */
#undef PBUF_POOL_BUFSIZE
#define PBUF_POOL_BUFSIZE 1500 /* LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_HLEN) */
/* ---------- TCP options ---------- */
#define LWIP_TCP 1
#undef TCP_TTL
#define TCP_TTL 255
#undef TCPIP_THREAD_STACKSIZE
#define TCPIP_THREAD_STACKSIZE LWIP_STK_SIZE
/* Controls if TCP should queue segments that arrive out of
order. Define to 0 if your device is low on memory. */
#undef TCP_QUEUE_OOSEQ
#define TCP_QUEUE_OOSEQ 0
* TCPIP_MBOX_SIZE: The mailbox size for the tcpip thread messages
* The queue size value itself is platform-dependent, but is passed to
* sys_mbox_new() when tcpip_init is called.
#undef TCPIP_MBOX_SIZE
#define TCPIP_MBOX_SIZE MAX_QUEUE_ENTRIES
* DEFAULT_TCP_RECVMBOX_SIZE: The mailbox size for the incoming packets on a
* NETCONN_TCP. The queue size value itself is platform-dependent, but is passed
* to sys_mbox_new() when the recvmbox is created.
#undef DEFAULT_TCP_RECVMBOX_SIZE
#define DEFAULT_TCP_RECVMBOX_SIZE MAX_QUEUE_ENTRIES
* DEFAULT_ACCEPTMBOX_SIZE: The mailbox size for the incoming connections.
* sys_mbox_new() when the acceptmbox is created.
#undef DEFAULT_ACCEPTMBOX_SIZE
#define DEFAULT_ACCEPTMBOX_SIZE MAX_QUEUE_ENTRIES
/* TCP Maximum segment size. */
#undef TCP_MSS
#define TCP_MSS (1500 - 40) /* TCP_MSS = (Ethernet MTU - IP header size - TCP header size) */
/* TCP sender buffer space (bytes). */
#undef TCP_SND_BUF
#define TCP_SND_BUF (4*TCP_MSS)
/* TCP sender buffer space (pbufs). This must be at least = 2 *
TCP_SND_BUF/TCP_MSS for things to work. */
#undef TCP_SND_QUEUELEN
#define TCP_SND_QUEUELEN ((4 * (TCP_SND_BUF) + (TCP_MSS - 1))/(TCP_MSS))
/* TCP receive window. */
#undef TCP_WND
#define TCP_WND (4 * TCP_MSS)
/* ---------- ICMP options ---------- */
#define LWIP_ICMP 1
/* ---------- DHCP options ---------- */
/* Define LWIP_DHCP to 1 if you want DHCP configuration of
interfaces. DHCP is not implemented in lwIP 0.5.1, however, so
turning this on does currently not work. */
#define LWIP_DHCP 1
/* ---------- UDP options ---------- */
#define LWIP_UDP 1
#undef UDP_TTL
#define UDP_TTL 255
#undef DEFAULT_UDP_RECVMBOX_SIZE
#define DEFAULT_UDP_RECVMBOX_SIZE MAX_QUEUE_ENTRIES
/* -----------RAW options -----------*/
#undef DEFAULT_RAW_RECVMBOX_SIZE
#define DEFAULT_RAW_RECVMBOX_SIZE MAX_QUEUE_ENTRIES
/* ---------- Statistics options ---------- */
#undef LWIP_STATS
#define LWIP_STATS 0
#define LWIP_PROVIDE_ERRNO 1
---------- Checksum options ----------
The STM32F107 allows computing and verifying the IP, UDP, TCP and ICMP checksums by hardware:
- To use this feature let the following define uncommented.
- To disable it and process by CPU comment the the checksum.
//#define CHECKSUM_BY_HARDWARE
#ifdef CHECKSUM_BY_HARDWARE
/* CHECKSUM_GEN_IP==0: Generate checksums by hardware for outgoing IP packets.*/
#undef CHECKSUM_GEN_IP
#define CHECKSUM_GEN_IP 0
/* CHECKSUM_GEN_UDP==0: Generate checksums by hardware for outgoing UDP packets.*/
#undef CHECKSUM_GEN_UDP
#define CHECKSUM_GEN_UDP 0
/* CHECKSUM_GEN_TCP==0: Generate checksums by hardware for outgoing TCP packets.*/
#undef CHECKSUM_GEN_TCP
#define CHECKSUM_GEN_TCP 0
/* CHECKSUM_CHECK_IP==0: Check checksums by hardware for incoming IP packets.*/
#undef CHECKSUM_CHECK_IP
#define CHECKSUM_CHECK_IP 0
/* CHECKSUM_CHECK_UDP==0: Check checksums by hardware for incoming UDP packets.*/
#undef CHECKSUM_CHECK_UDP
#define CHECKSUM_CHECK_UDP 0
/* CHECKSUM_CHECK_TCP==0: Check checksums by hardware for incoming TCP packets.*/
#undef CHECKSUM_CHECK_TCP
#define CHECKSUM_CHECK_TCP 0
#else
/* CHECKSUM_GEN_IP==1: Generate checksums in software for outgoing IP packets.*/
#define CHECKSUM_GEN_IP 1
/* CHECKSUM_GEN_UDP==1: Generate checksums in software for outgoing UDP packets.*/
#define CHECKSUM_GEN_UDP 1
/* CHECKSUM_GEN_TCP==1: Generate checksums in software for outgoing TCP packets.*/
#define CHECKSUM_GEN_TCP 1
/* CHECKSUM_CHECK_IP==1: Check checksums in software for incoming IP packets.*/
#define CHECKSUM_CHECK_IP 1
/* CHECKSUM_CHECK_UDP==1: Check checksums in software for incoming UDP packets.*/
#define CHECKSUM_CHECK_UDP 1
/* CHECKSUM_CHECK_TCP==1: Check checksums in software for incoming TCP packets.*/
#define CHECKSUM_CHECK_TCP 1
---------- Sequential layer options ----------
* LWIP_NETCONN==1: Enable Netconn API (require to use api_lib.c)
#define LWIP_NETCONN 1
---------- Socket options ----------
* LWIP_SOCKET==1: Enable Socket API (require to use sockets.c)
#define LWIP_SOCKET 1
#define LWIP_COMPAT_MUTEX 1
* MEMCPY: override this if you have a faster implementation at hand than the
* one included in your C library
#ifndef MEMCPY
#define MEMCPY(dst,src,len) memcpy((INT8U*)dst,(INT8U*)src,len)
#ifndef SMEMCPY
#define SMEMCPY(dst,src,len) memcpy((INT8U*)dst,(INT8U*)src,len)
#endif /* __LWIPOPTS_H__ */ |
