LOG信息显示:
[ 4.568130] mmc0: new high speed MMC card at address 0001
[ 4.578979] mmcblk0: mmc0:0001 SEM04G 3.68 GiB
[ 4.582337] mmcblk0: p1 p2 p3 p4
[ 4.590506] wifi is off
[ 4.633310] mmc_rescan mmc3, search for SDIO
[ 4.637406] mmc_rescan mmc3, search for SD
[ 4.645599] mmc_rescan mmc3, search for MMC
[ 4.818342] EXT4-fs (mmcblk0p3): recovery complete
[ 4.822747] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: discard,noauto_da_alloc,nodelalloc
[ 4.967827] EXT4-fs (mmcblk0p2): recovery complete
[ 4.972113] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.005797] EXT4-fs (mmcblk0p4): recovery complete
[ 5.011112] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[ 5.041747] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 5.070086] enabling adb
[ 5.071554] adb_open
# [ 5.217126] init: untracked pid 77 exited
[ 5.309086] s5p-ohci s5p-ohci: auto-stop root hub
[ 5.360114] PVR_K:(Warning): SysFinalise: Version string: SGX540 S5PC110 [478, drivers/gpu/pvr/s5pc110/sysconfig.c]
[ 6.566892] hub 1-0:1.0: hub_suspend
[ 6.569015] usb usb1: bus auto-suspend
[ 6.574339] s5p-ohci s5p-ohci: suspend root hub
[ 6.579539] usb usb1: old state 7, set state8
[ 6.582462] usb usb1: new state 8
[ 10.892374] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 11.096797] PVR_K:(Fatal): Debug assertion failed! [263, drivers/gpu/pvr/buffer_manager.c]
[ 11.103679] PVR_K:(Fatal): Debug assertion failed! [2124, drivers/gpu/pvr/sgx/mmu.c]
[ 11.111381] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.119057] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.126786] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.134498] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.142192] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.149922] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.157635] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.165330] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.173059] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.180755] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.188484] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.196196] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.203892] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.211621] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.219334] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.227030] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.234746] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.242478] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.250166] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.257896] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.265592] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.273321] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
[ 11.281034] PVR_K:(Fatal): Debug assertion failed! [1956, drivers/gpu/pvr/sgx/mmu.c]
ANDROID界面已经出来了,但是LOG信息一堆堆FAIL,心理非常不踏实,高手指点一下,到底哪里出来问题,多谢! |
