ARM菜鸟改造令人烦恼的头文件AT91SAM7S64.H
hotpower 发表于 2005-8-24 23:30 ARM 论坛 ←返回版面 举报该贴
改造原因: 令人烦恼的*AT91C_,使书写更加符合日常习惯.结构及结构指针的写法很烦人.
虽然可能优化代码,但本头文件效率相同.
其他AT91下列有PIO.H等头文件,但对AT91SAM7S64不太适合
文件名: AT91SAM7S64DEF.H
HotPower@126.com 2005.8.24 于西安大雁塔村队部 (首次修改)
#include <AT91SAM7S64.H>
#ifndef AT91SAM7S64DEF_H
#define AT91SAM7S64DEF_H
// REGISTER ADDRESS DEFINITION FOR AT91SAM7S64
// ========== Register definition for SYSC peripheral ==========
#define SYSC_VRPM (*AT91C_SYSC_SYSC_VRPM) // (SYSC) Voltage Regulator Power Mode Register
// ========== Register definition for AIC peripheral ==========
#define AIC_ICCR (*AT91C_AIC_ICCR) // (AIC) Interrupt Clear Command Register
#define AIC_IECR (*AT91C_AIC_IECR) // (AIC) Interrupt Enable Command Register
#define AIC_SMR (*AT91C_AIC_SMR) // (AIC) Source Mode Register
#define AIC_ISCR (*AT91C_AIC_ISCR) // (AIC) Interrupt Set Command Register
#define AIC_EOICR (*AT91C_AIC_EOICR) // (AIC) End of Interrupt Command Register
#define AIC_DCR (*AT91C_AIC_DCR) // (AIC) Debug Control Register (Protect)
#define AIC_FFER (*AT91C_AIC_FFER) // (AIC) Fast Forcing Enable Register
#define AIC_SVR (*AT91C_AIC_SVR) // (AIC) Source Vector Register
#define AIC_SPU (*AT91C_AIC_SPU) // (AIC) Spurious Vector Register
#define AIC_FFDR (*AT91C_AIC_FFDR) // (AIC) Fast Forcing Disable Register
#define AIC_FVR (*AT91C_AIC_FVR) // (AIC) FIQ Vector Register
#define AIC_FFSR (*AT91C_AIC_FFSR) // (AIC) Fast Forcing Status Register
#define AIC_IMR (*AT91C_AIC_IMR) // (AIC) Interrupt Mask Register
#define AIC_ISR (*AT91C_AIC_ISR) // (AIC) Interrupt Status Register
#define AIC_IVR (*AT91C_AIC_IVR) // (AIC) IRQ Vector Register
#define AIC_IDCR (*AT91C_AIC_IDCR) // (AIC) Interrupt Disable Command Register
#define AIC_CISR (*AT91C_AIC_CISR) // (AIC) Core Interrupt Status Register
#define AIC_IPR (*AT91C_AIC_IPR) // (AIC) Interrupt Pending Register
// ========== Register definition for DBGU peripheral ==========
#define DBGU_C2R (*AT91C_DBGU_C2R) // (DBGU) Chip ID2 Register
#define DBGU_THR (*AT91C_DBGU_THR) // (DBGU) Transmitter Holding Register
#define DBGU_CSR (*AT91C_DBGU_CSR) // (DBGU) Channel Status Register
#define DBGU_CSR (*AT91C_DBGU_CSR) // (DBGU) Interrupt Disable Register
#define DBGU_CSR (*AT91C_DBGU_CSR) // (DBGU) Mode Register
#define DBGU_FNTR (*AT91C_DBGU_FNTR) // (DBGU) Force NTRST Register
#define DBGU_C1R (*AT91C_DBGU_C1R) // (DBGU) Chip ID1 Register
#define DBGU_BRGR (*AT91C_DBGU_BRGR) // (DBGU) Baud Rate Generator Register
#define DBGU_RHR (*AT91C_DBGU_RHR) // (DBGU) Receiver Holding Register
#define DBGU_IMR (*AT91C_DBGU_IMR) // (DBGU) Interrupt Mask Register
#define DBGU_IER (*AT91C_DBGU_IER) // (DBGU) Interrupt Enable Register
#define DBGU_CR (*AT91C_DBGU_CR) // (DBGU) Control Register
// ========== Register definition for PDC_DBGU peripheral ==========
#define DBGU_TNCR (*AT91C_DBGU_TNCR) // (PDC_DBGU) Transmit Next Counter Register
#define DBGU_RNCR (*AT91C_DBGU_RNCR) // (PDC_DBGU) Receive Next Counter Register
#define DBGU_PTCR (*AT91C_DBGU_PTCR) // (PDC_DBGU) PDC Transfer Control Register
#define DBGU_PTSR (*AT91C_DBGU_PTSR) // (PDC_DBGU) PDC Transfer Status Register
#define DBGU_RCR (*AT91C_DBGU_RCR) // (PDC_DBGU) Receive Counter Register
#define DBGU_TCR (*AT91C_DBGU_TCR) // (PDC_DBGU) Transmit Counter Register
#define DBGU_RPR (*AT91C_DBGU_RPR) // (PDC_DBGU) Receive Pointer Register
#define DBGU_RPR (*AT91C_DBGU_RPR) // (PDC_DBGU) Transmit Pointer Register
#define DBGU_RNPR (*AT91C_DBGU_RNPR) // (PDC_DBGU) Receive Next Pointer Register
#define DBGU_TNPR (*AT91C_DBGU_TNPR) // (PDC_DBGU) Transmit Next Pointer Register
// ========== Register definition for PIOA peripheral ==========
#define PIO_IMR (*AT91C_PIOA_IMR) // (PIOA) Interrupt Mask Register
#define PIO_IER (*AT91C_PIOA_IER) // (PIOA) Interrupt Enable Register
#define PIO_OWDR (*AT91C_PIOA_OWDR) // (PIOA) Output Write Disable Register
#define PIO_ISR (*AT91C_PIOA_ISR) // (PIOA) Interrupt Status Register
#define PIO_PPUDR (*AT91C_PIOA_PPUDR) // (PIOA) Pull-up Disable Register
#define PIO_MDSR (*AT91C_PIOA_MDSR) // (PIOA) Multi-driver Status Register
#define PIO_MDER (*AT91C_PIOA_MDER) // (PIOA) Multi-driver Enable Register
#define PIO_PER (*AT91C_PIOA_PER) // (PIOA) PIO Enable Register
#define PIO_PSR (*AT91C_PIOA_PSR) // (PIOA) PIO Status Register
#define PIO_OER (*AT91C_PIOA_OER) // (PIOA) Output Enable Register
#define PIO_BSR (*AT91C_PIOA_BSR) // (PIOA) Select B Register
#define PIO_PPUER (*AT91C_PIOA_PPUER) // (PIOA) Pull-up Enable Register
#define PIO_MDDR (*AT91C_PIOA_MDDR) // (PIOA) Multi-driver Disable Register
#define PIO_PDR (*AT91C_PIOA_PDR) // (PIOA) PIO Disable Register
#define PIO_ODR (*AT91C_PIOA_ODR) // (PIOA) Output Disable Registerr
#define PIO_IFDR (*AT91C_PIOA_IFDR) // (PIOA) Input Filter Disable Register
#define PIO_ABSR (*AT91C_PIOA_ABSR) // (PIOA) AB Select Status Register
#define PIO_ASR (*AT91C_PIOA_ASR) // (PIOA) Select A Register
#define PIO_PPUSR (*AT91C_PIOA_PPUSR8) // (PIOA) Pad Pull-up Status Register
#define PIO_ODSR (*AT91C_PIOA_ODSR) // (PIOA) Output Data Status Register
#define PIO_SODR (*AT91C_PIOA_SODR) // (PIOA) Set Output Data Register
#define PIO_IFSR (*AT91C_PIOA_IFSR) // (PIOA) Input Filter Status Register
#define PIO_IFER (*AT91C_PIOA_IFER) // (PIOA) Input Filter Enable Register
#define PIO_OSR (*AT91C_PIOA_OSR) // (PIOA) Output Status Register
#define PIO_IDR (*AT91C_PIOA_IDR) // (PIOA) Interrupt Disable Register
#define PIO_PDSR (*AT91C_PIOA_PDSR) // (PIOA) Pin Data Status Register
#define PIO_CODR (*AT91C_PIOA_CODR) // (PIOA) Clear Output Data Register
#define PIO_OWSR (*AT91C_PIOA_OWSR) // (PIOA) Output Write Status Register
#define PIO_OWER (*AT91C_PIOA_OWER) // (PIOA) Output Write Enable Register
// ========== Register definition for CKGR peripheral ==========
#define CKGR_PLLR (*AT91C_CKGR_PLLR) // (CKGR) PLL Register
#define CKGR_MCFR (*AT91C_CKGR_MCFR) // (CKGR) Main Clock Frequency Register
#define CKGR_MOR (*AT91C_CKGR_MOR) // (CKGR) Main Oscillator Register
// ========== Register definition for PMC peripheral ==========
#define PMC_SCSR (*AT91C_PMC_SCSR) // (PMC) System Clock Status Register
#define PMC_SCER (*AT91C_PMC_SCER) // (PMC) System Clock Enable Register
#define PMC_IMR (*AT91C_PMC_IMR) // (PMC) Interrupt Mask Register
#define PMC_IDR (*AT91C_PMC_IDR) // (PMC) Interrupt Disable Register
#define PMC_PCDR (*AT91C_PMC_PCDR) // (PMC) Peripheral Clock Disable Register
#define PMC_SCDR (*AT91C_PMC_SCDR) // (PMC) System Clock Disable Register
#define PMC_SR (*AT91C_PMC_SR) // (PMC) Status Register
#define PMC_IER (*AT91C_PMC_IER) // (PMC) Interrupt Enable Register
#define PMC_MCKR (*AT91C_PMC_MCKR) // (PMC) Master Clock Register
#define PMC_MOR (*AT91C_PMC_MOR) // (PMC) Main Oscillator Register
#define PMC_PCER (*AT91C_PMC_PCER) // (PMC) Peripheral Clock Enable Register
#define PMC_PCSR (*AT91C_PMC_PCSR) // (PMC) Peripheral Clock Status Register
#define PMC_PLLR (*AT91C_PMC_PLLR) // (PMC) PLL Register
#define PMC_MCFR (*AT91C_PMC_MCFR) // (PMC) Main Clock Frequency Register
#define PMC_PCKR (*AT91C_PMC_PCKR) // (PMC) Programmable Clock Register
// ========== Register definition for RSTC peripheral ==========
#define RSTC_SR (*AT91C_RSTC_RSR) // (RSTC) Reset Status Register
#define RSTC_MR (*AT91C_RSTC_RMR) // (RSTC) Reset Mode Register
#define RSTC_CR (*AT91C_RSTC_RCR) // (RSTC) Reset Control Register
// ========== Register definition for RTTC peripheral ==========
#define RTT_SR (*AT91C_RTTC_RTSR) // (RTTC) Real-time Status Register
#define RTT_AR (*AT91C_RTTC_RTAR) // (RTTC) Real-time Alarm Register
#define RTT_VR (*AT91C_RTTC_RTVR) // (RTTC) Real-time Value Register
#define RTT_MR (*AT91C_RTTC_RTMR) // (RTTC) Real-time Mode Register
// ========== Register definition for PITC peripheral ==========
#define PIT_PIIR (*AT91C_PITC_PIIR) // (PITC) Period Interval Image Register
#define PIT_SR (*AT91C_PITC_PISR) // (PITC) Period Interval Status Register
#define PIT_PIVR (*AT91C_PITC_PIVR) // (PITC) Period Interval Value Register
#define PIT_MR (*AT91C_PITC_PIMR) // (PITC) Period Interval Mode Register
// ========== Register definition for WDTC peripheral ==========
#define WDT_MR (*AT91C_WDTC_WDMR) // (WDTC) Watchdog Mode Register
#define WDT_SR (*AT91C_WDTC_WDSR) // (WDTC) Watchdog Status Register
#define WDT_CR (*AT91C_WDTC_WDCR) // (WDTC) Watchdog Control Register
// ========== Register definition for MC peripheral ==========
#define MC_FCR (*AT91C_MC_FCR) // (MC) MC Flash Command Register
#define MC_ASR (*AT91C_MC_ASR) // (MC) MC Abort Status Register
#define MC_FSR (*AT91C_MC_FSR) // (MC) MC Flash Status Register
#define MC_FMR (*AT91C_MC_FMR) // (MC) MC Flash Mode Register
#define MC_AASR (*AT91C_MC_AASR) // (MC) MC Abort Address Status Register
#define MC_RCR (*AT91C_MC_RCR) // (MC) MC Remap Control Register
// ========== Register definition for PDC_SPI peripheral ==========
#define SPI_PTCR (*AT91C_SPI_PTCR) // (PDC_SPI) PDC Transfer Control Register
#define SPI_TNPR (*AT91C_SPI_TNPR) // (PDC_SPI) Transmit Next Pointer Register
#define SPI_RNPR (*AT91C_SPI_RNPR) // (PDC_SPI) Receive Next Pointer Register
#define SPI_TPR (*AT91C_SPI_TPR) // (PDC_SPI) Transmit Pointer Register
#define SPI_RPR (*AT91C_SPI_RPR) // (PDC_SPI) Receive Pointer Register
#define SPI_PTSR (*AT91C_SPI_PTSR) // (PDC_SPI) PDC Transfer Status Register
#define SPI_TNCR (*AT91C_SPI_TNCR) // (PDC_SPI) Transmit Next Counter Register
#define SPI_RNCR (*AT91C_SPI_RNCR) // (PDC_SPI) Receive Next Counter Register
#define SPI_TCR (*AT91C_SPI_TCR) // (PDC_SPI) Transmit Counter Register
#define SPI_RCR (*AT91C_SPI_RCR) // (PDC_SPI) Receive Counter Register
// ========== Register definition for SPI peripheral ==========
#define SPI_CSR (*AT91C_SPI_CSR) // (SPI) Chip Select Register
#define SPI_IDR (*AT91C_SPI_IDR) // (SPI) Interrupt Disable Register
#define SPI_SR (*AT91C_SPI_SR) // (SPI) Status Register
#define SPI_RDR (*AT91C_SPI_RDR) // (SPI) Receive Data Register
#define SPI_CR (*AT91C_SPI_CR) // (SPI) Control Register
#define SPI_IMR (*AT91C_SPI_IMR) // (SPI) Interrupt Mask Register
#define SPI_IER (*AT91C_SPI_IER) // (SPI) Interrupt Enable Register
#define SPI_TDR (*AT91C_SPI_TDR) // (SPI) Transmit Data Register
#define SPI_MR (*AT91C_SPI_MR) // (SPI) Mode Register
// ========== Register definition for PDC_ADC peripheral ==========
#define ADC_PTCR (*AT91C_ADC_PTCR) // (PDC_ADC) PDC Transfer Control Register
#define ADC_TNPR (*AT91C_ADC_TNPR) // (PDC_ADC) Transmit Next Pointer Register
#define ADC_RNPR (*AT91C_ADC_RNPR) // (PDC_ADC) Receive Next Pointer Register
#define ADC_TPR (*AT91C_ADC_TPR) // (PDC_ADC) Transmit Pointer Register
#define ADC_RPR (*AT91C_ADC_RPR) // (PDC_ADC) Receive Pointer Register
#define ADC_PTSR (*AT91C_ADC_PTSR) // (PDC_ADC) PDC Transfer Status Register
#define ADC_TNCR (*AT91C_ADC_TNCR) // (PDC_ADC) Transmit Next Counter Register
#define ADC_RNCR (*AT91C_ADC_RNCR) // (PDC_ADC) Receive Next Counter Register
#define ADC_TCR (*AT91C_ADC_TCR) // (PDC_ADC) Transmit Counter Register
#define ADC_RCR (*AT91C_ADC_RCR) // (PDC_ADC) Receive Counter Register
// ========== Register definition for ADC peripheral ==========
#define ADC_IMR (*AT91C_ADC_IMR) // (ADC) ADC Interrupt Mask Register
#define ADC_CDR4 (*AT91C_ADC_CDR4) // (ADC) ADC Channel Data Register 4
#define ADC_CDR2 (*AT91C_ADC_CDR2) // (ADC) ADC Channel Data Register 2
#define ADC_CDR0 (*AT91C_ADC_CDR0) // (ADC) ADC Channel Data Register 0
#define ADC_CDR7 (*AT91C_ADC_CDR7) // (ADC) ADC Channel Data Register 7
#define ADC_CDR1 (*AT91C_ADC_CDR1) // (ADC) ADC Channel Data Register 1
#define ADC_CDR3 (*AT91C_ADC_CDR3) // (ADC) ADC Channel Data Register 3
#define ADC_CDR5 (*AT91C_ADC_CDR5) // (ADC) ADC Channel Data Register 5
#define ADC_MR (*AT91C_ADC_MR) // (ADC) ADC Mode Register
#define ADC_CDR6 (*AT91C_ADC_CDR6) // (ADC) ADC Channel Data Register 6
#define ADC_CR (*AT91C_ADC_CR) // (ADC) ADC Control Register
#define ADC_CHER (*AT91C_ADC_CHER) // (ADC) ADC Channel Enable Register
#define ADC_CHSR (*AT91C_ADC_CHSR) // (ADC) ADC Channel Status Register
#define ADC_IER (*AT91C_ADC_IER) // (ADC) ADC Interrupt Enable Register
#define ADC_SR (*AT91C_ADC_SR) // (ADC) ADC Status Register
#define ADC_CHDR (*AT91C_ADC_CHDR) // (ADC) ADC Channel Disable Register
#define ADC_IDR (*AT91C_ADC_IDR) // (ADC) ADC Interrupt Disable Register
#define ADC_LCDR (*AT91C_ADC_LCDR) // (ADC) ADC Last Converted Data Register
// ========== Register definition for PDC_SSC peripheral ==========
#define SSC_PTCR (*AT91C_SSC_PTCR) // (PDC_SSC) PDC Transfer Control Register
#define SSC_TNPR (*AT91C_SSC_TNPR) // (PDC_SSC) Transmit Next Pointer Register
#define SSC_RNPR (*AT91C_SSC_RNPR) // (PDC_SSC) Receive Next Pointer Register
#define SSC_TPR (*AT91C_SSC_TPR) // (PDC_SSC) Transmit Pointer Register
#define SSC_RPR (*AT91C_SSC_RPR) // (PDC_SSC) Receive Pointer Register
#define SSC_PTSR (*AT91C_SSC_PTSR) // (PDC_SSC) PDC Transfer Status Register
#define SSC_TNCR (*AT91C_SSC_TNCR) // (PDC_SSC) Transmit Next Counter Register
#define SSC_RNCR (*AT91C_SSC_RNCR) // (PDC_SSC) Receive Next Counter Register
#define SSC_TCR (*AT91C_SSC_TCR) // (PDC_SSC) Transmit Counter Register
#define SSC_RCR (*AT91C_SSC_RCR) // (PDC_SSC) Receive Counter Register
// ========== Register definition for SSC peripheral ==========
#define SSC_RFMR (*AT91C_SSC_RFMR) // (SSC) Receive Frame Mode Register
#define SSC_CMR (*AT91C_SSC_CMR) Clock Mode Register
#define SSC_IDR (*AT91C_SSC_IDR) // (SSC) Interrupt Disable Register
#define SSC_SR (*AT91C_SSC_SR) // (SSC) Status Register
#define SSC_RC0R (*AT91C_SSC_RC0R) // (SSC) Receive Compare 0 Register
#define SSC_RSHR (*AT91C_SSC_RSHR) // (SSC) Receive Sync Holding Register
#define SSC_RHR (*AT91C_SSC_RHR) // (SSC) Receive Holding Register
#define SSC_TCMR (*AT91C_SSC_TCMR) // (SSC) Transmit Clock Mode Register
#define SSC_RCMR (*AT91C_SSC_RCMR) // (SSC) Receive Clock ModeRegister
#define SSC_CR (*AT91C_SSC_CR) // (SSC) Control Register
#define SSC_IMR (*AT91C_SSC_IMR) // (SSC) Interrupt Mask Register
#define SSC_IER (*AT91C_SSC_IER) // (SSC) Interrupt Enable Register
#define SSC_RC1R (*AT91C_SSC_RC1R) // (SSC) Receive Compare 1 Register
#define SSC_TSHR (*AT91C_SSC_TSHR) // (SSC) Transmit Sync Holding Register
#define SSC_THR (*AT91C_SSC_THR) // (SSC) Transmit Holding Register
#define SSC_TFMR (*AT91C_SSC_TFMR) // (SSC) Transmit Frame Mode Register
// ========== Register definition for PDC_US1 peripheral ==========
#define US1_PTSR (*AT91C_US1_PTSR) // (PDC_US1) PDC Transfer Status Register
#define US1_TNCR (*AT91C_US1_TNCR) // (PDC_US1) Transmit Next Counter Register
#define US1_RNCR (*AT91C_US1_RNCR) // (PDC_US1) Receive Next Counter Register
#define US1_TCR (*AT91C_US1_TCR) // (PDC_US1) Transmit Counter Register
#define US1_RCR (*AT91C_US1_RCR) // (PDC_US1) Receive Counter Register
#define US1_PTCR (*AT91C_US1_PTCR) // (PDC_US1) PDC Transfer Control Register
#define US1_TNPR (*AT91C_US1_TNPR) // (PDC_US1) Transmit Next Pointer Register
#define US1_RNPR (*AT91C_US1_RNPR) // (PDC_US1) Receive Next Pointer Register
#define US1_TPR (*AT91C_US1_TPR) // (PDC_US1) Transmit Pointer Register
#define US1_RPR (*AT91C_US1_RPR) // (PDC_US1) Receive Pointer Register
// ========== Register definition for US1 peripheral ==========
#define US1_XXR (*AT91C_US1_XXR) // (US1) XON_XOFF Register
#define US1_RHR (*AT91C_US1_RHR) // (US1) Receiver Holding Register
#define US1_IMR (*AT91C_US1_IMR) // (US1) Interrupt Mask Register
#define US1_IER (*AT91C_US1_IER) // (US1) Interrupt Enable Register
#define US1_CR (*AT91C_US1_CR) // (US1) Control Register
#define US1_RTOR (*AT91C_US1_RTOR) // (US1) Receiver Time-out Register
#define US1_THR (*AT91C_US1_THR) // (US1) Transmitter Holding Register
#define US1_CSR (*AT91C_US1_CSR) // (US1) Channel Status Register
#define US1_IDR (*AT91C_US1_IDR) // (US1) Interrupt Disable Register
#define US1_FIDI (*AT91C_US1_FIDI) // (US1) FI_DI_Ratio Register
#define US1_BRGR (*AT91C_US1_BRGR) // (US1) Baud Rate Generator Register
#define US1_TTGR (*AT91C_US1_TTGR) // (US1) Transmitter Time-guard Register
#define US1_IF (*AT91C_US1_IF) // (US1) IRDA_FILTER Register
#define US1_NER (*AT91C_US1_NER) // (US1) Nb Errors Register
#define US1_MR (*AT91C_US1_MR) // (US1) Mode Register
// ========== Register definition for PDC_US0 peripheral ==========
#define US0_PTCR (*AT91C_US0_PTCR) // (PDC_US0) PDC Transfer Control Register
#define US0_TNPR (*AT91C_US0_TNPR) // (PDC_US0) Transmit Next Pointer Register
#define US0_RNPR (*AT91C_US0_RNPR) // (PDC_US0) Receive Next Pointer Register
#define US0_TPR (*AT91C_US0_TPR) // (PDC_US0) Transmit Pointer Register
#define US0_RPR (*AT91C_US0_RPR) // (PDC_US0) Receive Pointer Register
#define US0_PTSR (*AT91C_US0_PTSR) // (PDC_US0) PDC Transfer Status Register
#define US0_TNCR (*AT91C_US0_TNCR) // (PDC_US0) Transmit Next Counter Register
#define US0_RNCR (*AT91C_US0_RNCR) // (PDC_US0) Receive Next Counter Register
#define US0_TCR (*AT91C_US0_TCR) // (PDC_US0) Transmit Counter Register
#define US0_RCR (*AT91C_US0_RCR) // (PDC_US0) Receive Counter Register
// ========== Register definition for US0 peripheral ==========
#define US0_TTGR (*AT91C_US0_TTGR) // (US0) Transmitter Time-guard Register
#define US0_BRGR (*AT91C_US0_BRGR) // (US0) Baud Rate Generator Register
#define US0_RHR (*AT91C_US0_RHR) // (US0) Receiver Holding Register
#define US0_IMR (*AT91C_US0_IMR) // (US0) Interrupt Mask Register
#define US0_NER (*AT91C_US0_NER) // (US0) Nb Errors Register
#define US0_RTOR (*AT91C_US0_RTOR) // (US0) Receiver Time-out Register
#define US0_XXR (*AT91C_US0_XXR) // (US0) XON_XOFF Register
#define US0_FIDI (*AT91C_US0_FIDI) // (US0) FI_DI_Ratio Register
#define US0_CR (*AT91C_US0_CR) // (US0) Control Register
#define US0_IER (*AT91C_US0_IER) // (US0) Interrupt Enable Register
#define US0_IF (*AT91C_US0_IF) // (US0) IRDA_FILTER Register
#define US0_MR (*AT91C_US0_MR) // (US0) Mode Register
#define US0_IDR (*AT91C_US0_IDR) // (US0) Interrupt Disable Register
#define US0_CSR (*AT91C_US0_CSR) // (US0) Channel Status Register
#define US0_THR (*AT91C_US0_THR) // (US0) Transmitter Holding Register
// ========== Register definition for TWI peripheral ==========
#define TWI_RHR (*AT91C_TWI_RHR) // (TWI) Receive Holding Register
#define TWI_IDR (*AT91C_TWI_IDR) // (TWI) Interrupt Disable Register
#define TWI_SR (*AT91C_TWI_SR) // (TWI) Status Register
#define TWI_CWGR (*AT91C_TWI_CWGR) // (TWI) Clock Waveform Generator Register
#define TWI_SMR (*AT91C_TWI_SMR) // (TWI) Slave Mode Register
#define TWI_CR (*AT91C_TWI_CR) // (TWI) Control Register
#define TWI_THR (*AT91C_TWI_THR) // (TWI) Transmit Holding Register
#define TWI_IMR (*AT91C_TWI_IMR) // (TWI) Interrupt Mask Register
#define TWI_IER (*AT91C_TWI_IER) // (TWI) Interrupt Enable Register
#define TWI_IADR (*AT91C_TWI_IADR) // (TWI) Internal Address Register
#define TWI_MMR (*AT91C_TWI_MMR) // (TWI) Master Mode Register
// ========== Register definition for TC2 peripheral ==========
#define TC2_IMR (*AT91C_TC2_IMR) // (TC2) Interrupt Mask Register
#define TC2_IER (*AT91C_TC2_IER) // (TC2) Interrupt Enable Register
#define TC2_RC (*AT91C_TC2_RC) // (TC2) Register C
#define TC2_RA (*AT91C_TC2_RA) // (TC2) Register A
#define TC2_CMR (*AT91C_TC2_CMR) // (TC2) Channel Mode Register (Capture Mode / Waveform Mode)
#define TC2_IDR (*AT91C_TC2_IDR) // (TC2) Interrupt Disable Register
#define TC2_SR (*AT91C_TC2_SR) // (TC2) Status Register
#define TC2_RB (*AT91C_TC2_RB) // (TC2) Register B
#define TC2_CV (*AT91C_TC2_CV) // (TC2) Counter Value
#define TC2_CCR (*AT91C_TC2_CCR) // (TC2) Channel Control Register
// ========== Register definition for TC1 peripheral ==========
#define TC1_IMR (*AT91C_TC1_IMR) // (TC1) Interrupt Mask Register
#define TC1_IER (*AT91C_TC1_IER) // (TC1) Interrupt Enable Register
#define TC1_RC (*AT91C_TC1_RC) // (TC1) Register C
#define TC1_RA (*AT91C_TC1_RA) // (TC1) Register A
#define TC1_CMR (*AT91C_TC1_CMR) // (TC1) Channel Mode Register (Capture Mode / Waveform Mode)
#define TC1_IDR (*AT91C_TC1_IDR) // (TC1) Interrupt Disable Register
#define TC1_SR (*AT91C_TC1_SR) // (TC1) Status Register
#define TC1_RB (*AT91C_TC1_RB) // (TC1) Register B
#define TC1_CV (*AT91C_TC1_CV) // (TC1) Counter Value
#define TC1_CCR (*AT91C_TC1_CCR) // (TC1) Channel Control Register
// ========== Register definition for TC0 peripheral ==========
#define TC0_IMR (*AT91C_TC0_IMR) // (TC0) Interrupt Mask Register
#define TC0_IER (*AT91C_TC0_IER) // (TC0) Interrupt Enable Register
#define TC0_RC (*AT91C_TC0_RC) // (TC0) Register C
#define TC0_RA (*AT91C_TC0_RA) // (TC0) Register A
#define TC0_CMR (*AT91C_TC0_CMR) // (TC0) Channel Mode Register (Capture Mode / Waveform Mode)
#define TC0_IDR (*AT91C_TC0_IDR) // (TC0) Interrupt Disable Register
#define TC0_SR (*AT91C_TC0_SR) // (TC0) Status Register
#define TC0_RB (*AT91C_TC0_RB) // (TC0) Register B
#define TC0_CV (*AT91C_TC0_CV) // (TC0) Counter Value
#define TC0_CCR (*AT91C_TC0_CCR) // (TC0) Channel Control Register
// ========== Register definition for TCB peripheral ==========
#define TCB_BMR (*AT91C_TCB_BMR) // (TCB) TC Block Mode Register
#define TCB_BCR (*AT91C_TCB_BCR) // (TCB) TC Block Control Register
// ========== Register definition for PWMC_CH3 peripheral ==========
#define CH3_CUPDR (*AT91C_CH3_CUPDR) // (PWMC_CH3) Channel Update Register
#define CH3_CPRDR (*AT91C_CH3_CPRDR) // (PWMC_CH3) Channel Period Register
#define CH3_CMR (*AT91C_CH3_CMR) // (PWMC_CH3) Channel Mode Register
#define CH3_Reserved (*AT91C_CH3_Reserved) // (PWMC_CH3) Reserved
#define CH3_CCNTR (*AT91C_CH3_CCNTR) // (PWMC_CH3) Channel Counter Register
#define CH3_CDTYR (*AT91C_CH3_CDTYR) // (PWMC_CH3) Channel Duty Cycle Register
// ========== Register definition for PWMC_CH2 peripheral ==========
#define CH2_CUPDR (*AT91C_CH2_CUPDR) // (PWMC_CH2) Channel Update Register
#define CH2_CPRDR (*AT91C_CH2_CPRDR) // (PWMC_CH2) Channel Period Register
#define CH2_CMR (*AT91C_CH2_CMR) // (PWMC_CH2) Channel Mode Register
#define CH2_Reserved (*AT91C_CH2_Reserved) // (PWMC_CH2) Reserved
#define CH2_CCNTR (*AT91C_CH2_CCNTR) // (PWMC_CH2) Channel Counter Register
#define CH2_CDTYR (*AT91C_CH2_CDTYR) // (PWMC_CH2) Channel Duty Cycle Register
// ========== Register definition for PWMC_CH1 peripheral ==========
#define CH1_CUPDR (*AT91C_CH1_CUPDR) // (PWMC_CH1) Channel Update Register
#define CH1_CPRDR (*AT91C_CH1_CPRDR) // (PWMC_CH1) Channel Period Register
#define CH1_CMR (*AT91C_CH1_CMR) // (PWMC_CH1) Channel Mode Register
#define CH1_Reserved (*AT91C_CH1_Reserved) // (PWMC_CH1) Reserved
#define CH1_CCNTR (*AT91C_CH1_CCNTR) // (PWMC_CH1) Channel Counter Register
#define CH1_CDTYR (*AT91C_CH1_CDTYR) // (PWMC_CH1) Channel Duty Cycle Register
// ========== Register definition for PWMC_CH0 peripheral ==========
#define CH0_CUPDR (*AT91C_CH0_CUPDR) // (PWMC_CH0) Channel Update Register
#define CH0_CPRDR (*AT91C_CH0_CPRDR) // (PWMC_CH0) Channel Period Register
#define CH0_CMR (*AT91C_CH0_CMR) // (PWMC_CH0) Channel Mode Register
#define CH0_Reserved (*AT91C_CH0_Reserved) // (PWMC_CH0) Reserved
#define CH0_CCNTR (*AT91C_CH0_CCNTR) // (PWMC_CH0) Channel Counter Register
#define CH0_CDTYR (*AT91C_CH0_CDTYR) // (PWMC_CH0) Channel Duty Cycle Register
// ========== Register definition for PWMC peripheral ==========
#define PWMC_VR (*AT91C_PWMC_VR) // (PWMC) PWMC Version Register
#define PWMC_ISR (*AT91C_PWMC_ISR) // (PWMC) PWMC Interrupt Status Register
#define PWMC_IDR (*AT91C_PWMC_IDR) // (PWMC) PWMC Interrupt Disable Register
#define PWMC_SR (*AT91C_PWMC_SR) // (PWMC) PWMC Status Register
#define PWMC_ENA (*AT91C_PWMC_ENA) // (PWMC) PWMC Enable Register
#define PWMC_IMR (*AT91C_PWMC_IMR) // (PWMC) PWMC Interrupt Mask Register
#define PWMC_MR (*AT91C_PWMC_MR) // (PWMC) PWMC Mode Register
#define PWMC_DIS (*AT91C_PWMC_DIS) // (PWMC) PWMC Disable Register
#define PWMC_IER (*AT91C_PWMC_IER) // (PWMC) PWMC Interrupt Enable Register
// ========== Register definition for UDP peripheral ==========
#define UDP_ISR (*AT91C_UDP_ISR) // (UDP) Interrupt Status Register
#define UDP_IDR (*AT91C_UDP_IDR) // (UDP) Interrupt Disable Register
#define UDP_GLBSTATE (*AT91C_UDP_GLBSTATE) // (UDP) Global State Register
#define UDP_FDR (*AT91C_UDP_FDR) // (UDP) Endpoint FIFO Data Register
#define UDP_CSR (*AT91C_UDP_CSR) // (UDP) Endpoint Control and Status Register
#define UDP_RSTEP (*AT91C_UDP_RSTEP) // (UDP) Reset Endpoint Register
#define UDP_ICR (*AT91C_UDP_ICR) // (UDP) Interrupt Clear Register
#define UDP_IMR (*AT91C_UDP_IMR) // (UDP) Interrupt Mask Register
#define UDP_IER (*AT91C_UDP_IER) // (UDP) Interrupt Enable Register
#define UDP_FADDR (*AT91C_UDP_FADDR) // (UDP) Function Address Register
#define UDP_NUM (*AT91C_UDP_NUM) // (UDP) Frame Number Register
/* Port Pins */
#define PA0 (1<<0)
#define PA1 (1<<1)
#define PA2 (1<<2)
#define PA3 (1<<3)
#define PA4 (1<<4)
#define PA5 (1<<5)
#define PA6 (1<<6)
#define PA7 (1<<7)
#define PA8 (1<<8)
#define PA9 (1<<9)
#define PA10 (1<<10)
#define PA11 (1<<11)
#define PA12 (1<<12)
#define PA13 (1<<13)
#define PA14 (1<<14)
#define PA15 (1<<15)
#define PA16 (1<<16)
#define PA17 (1<<17)
#define PA18 (1<<18)
#define PA19 (1<<19)
#define PA20 (1<<20)
#define PA21 (1<<21)
#define PA22 (1<<22)
#define PA23 (1<<23)
#define PA24 (1<<24)
#define PA25 (1<<25)
#define PA26 (1<<26)
#define PA27 (1<<27)
#define PA28 (1<<28)
#define PA29 (1<<29)
#define PA30 (1<<30)
#define PA31 (1<<31)
#endif |
